GSOC POSIX Compliance: Stuck trying to build Newlib
Matthew Joyce
mfjoyce2004 at gmail.com
Wed Jun 16 16:15:58 UTC 2021
Hi Dr. Joel,
I used the following, based on Vaibhav's blog:
$ export PATH=$HOME/development/rtems/6/bin:$PATH
$ ../newlib-cygwin/configure --target=sparc-rtems6 --disable-shared
--disable-nls --enable-werror --enable-newlib-supplied-syscalls
--enable-interwork --enable-multilib --with-gnu-as --with-gnu-ld
When I enter "type sparc-rtems6-gcc" (I hope I'm understanding that
correctly!), I get sparc-rtems6-gcc is hashed...and then my PATH.
Thanks again!
V/r,
Matt
On Wed, Jun 16, 2021 at 6:06 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jun 16, 2021 at 10:57 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> Hi Dr. Joel,
>> I tried that in newlib/libc and there were at least no errors.
>> (Nothing leading me to believe it was successful either!)
>> However I still got the same error when I sudo make install.
>> (sparc-rtems-ranlib: command not found) (among others!)
> The target should be sparc-rtems6 when you configure newlib.
> This should mean invoking the script like "./j-newlib sparc-rtems6"
> And the RTEMS tools should be in your PATH.
> To be sure.
> --joel
>> Thanks again!
>> Sincerely,
>> Matt
>> On Wed, Jun 16, 2021 at 3:06 PM Joel Sherrill <joel at rtems.org> wrote:
>> > Does adding --no-recursive and running it only from the directory you touched a build system file in help?
>> > It is regenerating a lot you don't want to touch anyway.
>> > --joel
>> > On Wed, Jun 16, 2021, 5:32 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> Hi Eshan,
>> >> Thanks very much for your follow up! Ok, I see now that if I go into
>> >> development/newlib/newlib-cygwin/newlib and run autoreconf -fvi with
>> >> the v2.69 using the PATH that Dr. Joel just showed, it starts to run.
>> >> It always eventually exits with an error though. (please see attached
>> >> .txt). I hope you can read that...I used the command "script" to
>> >> output everything to a text file.
>> >> Do you have any idea where I might be going wrong?
>> >> Thank you!
>> >> Sincerely,
>> >> Matt
>> >> On Tue, Jun 15, 2021 at 8:23 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> >> > Hi matt
>> >> > It would work if run inside newlib instead of newlib-cygwin
>> >> > run command inside of ../newlib-cygwin/newlib
>> >> > instead of ../newlib-cygwin
>> >> > On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> >> Ah, ok will do! Thank you for the tip.
>> >> >> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> >> > Just a note, it's more efficient to capture your terminal dump into a
>> >> >> > text file and attach that, rather than put a screenshot up.
>> >> >> > On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> >> > > Hi Gentlemen,
>> >> >> > > Thanks very much for your quick replies!
>> >> >> > > I just tried both, but perhaps I'm misinterpreting your suggestions.
>> >> >> > > (Could you please see the attached commands / errors!)
>> >> >> > > Eshan,
>> >> >> > > I did see that link, but it wasn't clear to me what the solution was...Sorry!
>> >> >> > > Sincerely,
>> >> >> > > Matt
>> >> >> > > On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> >> >> > > > Hi Matt,
>> >> >> > > > Try running the command with autoconf version 2.69 that's shipped with RTEMS in the rtems bin
>> >> >> > > > That works as well.
>> >> >> > > > Also From a quick google search this is what I found : https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
>> >> >> > > > On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> >> > > >> Hello Dr. Joel and Eshan,
>> >> >> > > >> I have a patch ready to send to Newlib for the sig function prototypes
>> >> >> > > >> and STR2SIG_MAX.
>> >> >> > > >> But to do that, I think I need to have Newlib built, which I must
>> >> >> > > >> still be doing wrong. The error that I am getting is attached below.
>> >> >> > > >> I’ve been trying to follow the steps here:
>> >> >> > > >> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
>> >> >> > > >> and https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
>> >> >> > > >> I even had rebuilt everything from scratch to see if that would help,
>> >> >> > > >> but I still get the same error. Maybe I cloned the newlib source into
>> >> >> > > >> the wrong directory?
>> >> >> > > >> I was hoping to get the patch off to Newlib for review as a first step
>> >> >> > > >> while I work on writing the actual methods. When you get a moment,
>> >> >> > > >> could you please advise? Thank you very much!
>> >> >> > > >> Sincerely,
>> >> >> > > >> Matt
>> >> >> > > _______________________________________________
>> >> >> > > devel mailing list
>> >> >> > > devel at rtems.org
>> >> >> > > http://lists.rtems.org/mailman/listinfo/devel
