GSOC POSIX Compliance: Stuck trying to build Newlib
Joel Sherrill
joel at rtems.org
Wed Jun 16 16:28:43 UTC 2021
On Wed, Jun 16, 2021 at 11:16 AM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> Hi Matt,
> > On 16-Jun-2021, at 9:27 PM, Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> > Hi Dr. Joel,
> > I tried that in newlib/libc and there were at least no errors.
> > (Nothing leading me to believe it was successful either!)
> > However I still got the same error when I sudo make install.
> > (sparc-rtems-ranlib: command not found) (among others!)
> I make works then there is no need to run make install it just copies the
> build binaries to the root folders.
> If make is build with the changes u made and the symbols that you added
> appear in the binaries you generated.
> Then congratulations :)
> Now you just need to test those changes in the RSB to test they don’t
> break anything in the RTEMS ecosystem.
Or use the same prefix as you did with the RSB installed tools and begin to
add a test to RTEMS for the method.
When you add to newlib and need a test in RTEMS for that functionality, you
end up with a pair of patches. First the newlib one has to be merged, then
your test can be added to RTEMS.
--joel
> > Thanks again!
> > Sincerely,
> > Matt
> >> On Wed, Jun 16, 2021 at 3:06 PM Joel Sherrill <joel at rtems.org> wrote:
> >> Does adding --no-recursive and running it only from the directory you
> touched a build system file in help?
> >> It is regenerating a lot you don't want to touch anyway.
> >> --joel
> >>> On Wed, Jun 16, 2021, 5:32 AM Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
> >>> Hi Eshan,
> >>> Thanks very much for your follow up! Ok, I see now that if I go into
> >>> development/newlib/newlib-cygwin/newlib and run autoreconf -fvi with
> >>> the v2.69 using the PATH that Dr. Joel just showed, it starts to run.
> >>> It always eventually exits with an error though. (please see attached
> >>> .txt). I hope you can read that...I used the command "script" to
> >>> output everything to a text file.
> >>> Do you have any idea where I might be going wrong?
> >>> Thank you!
> >>> Sincerely,
> >>> Matt
> >>> On Tue, Jun 15, 2021 at 8:23 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> >>>> Hi matt
> >>>> It would work if run inside newlib instead of newlib-cygwin
> >>>> run command inside of ../newlib-cygwin/newlib
> >>>> instead of ../newlib-cygwin
> >>>> On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
> >>>>> Ah, ok will do! Thank you for the tip.
> >>>>> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >>>>>> Just a note, it's more efficient to capture your terminal dump into
> a
> >>>>>> text file and attach that, rather than put a screenshot up.
> >>>>>> On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <
> >>>>>>> Hi Gentlemen,
> >>>>>>> Thanks very much for your quick replies!
> >>>>>>> I just tried both, but perhaps I'm misinterpreting your
> suggestions.
> >>>>>>> (Could you please see the attached commands / errors!)
> >>>>>>> Eshan,
> >>>>>>> I did see that link, but it wasn't clear to me what the solution
> was...Sorry!
> >>>>>>> Sincerely,
> >>>>>>> Matt
> >>>>>>> On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <
> eshandhawan51 at gmail.com> wrote:
> >>>>>>>> Hi Matt,
> >>>>>>>> Try running the command with autoconf version 2.69 that's shipped
> with RTEMS in the rtems bin
> >>>>>>>> That works as well.
> >>>>>>>> Also From a quick google search this is what I found :
> https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
> >>>>>>>> On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <
> >>>>>>>>> Hello Dr. Joel and Eshan,
> >>>>>>>>> I have a patch ready to send to Newlib for the sig function
> prototypes
> >>>>>>>>> and STR2SIG_MAX.
> >>>>>>>>> But to do that, I think I need to have Newlib built, which I must
> >>>>>>>>> still be doing wrong. The error that I am getting is attached
> below.
> >>>>>>>>> I’ve been trying to follow the steps here:
> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
> >>>>>>>>> and
> https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
> >>>>>>>>> I even had rebuilt everything from scratch to see if that would
> help,
> >>>>>>>>> but I still get the same error. Maybe I cloned the newlib source
> into
> >>>>>>>>> the wrong directory?
> >>>>>>>>> I was hoping to get the patch off to Newlib for review as a
> first step
> >>>>>>>>> while I work on writing the actual methods. When you get a
> moment,
> >>>>>>>>> could you please advise? Thank you very much!
> >>>>>>>>> Sincerely,
> >>>>>>>>> Matt
> >>>>>>> _______________________________________________
> >>>>>>> devel mailing list
> >>>>>>> devel at rtems.org
> >>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210616/3fd1a839/attachment-0001.html>
