[PATCH v2] covoar: Store address-to-line info outside of DWARF
Alex White alex.white at oarcorp.com
Thu Jun 17 03:01:09 UTC 2021
On Mon, Jun 7, 2021 at 8:14 PM Chris Johns <chrisj at rtems.org> wrote:
> On 8/6/21 1:44 am, Joel Sherrill wrote:
> > On Mon, Jun 7, 2021 at 7:00 AM Alex White <alex.white at oarcorp.com
> > <mailto:alex.white at oarcorp.com>> wrote:
> >     On Wed, Jun 2, 2021 at 7:37 PM Chris Johns <chrisj at rtems.org
> >     <mailto:chrisj at rtems.org>> wrote:
> >     > Looking good with a single comment below ...
> >     > On 3/6/21 6:08 am, Alex White wrote:
> >     > > This adds the AddressToLineMapper class and supporting classes to
> >     > > assume responsibility of tracking address-to-line information.
> >     > > This allows the DWARF library to properly cleanup all of its resources
> >     > > and leads to significant memory savings.
> >     > > Closes #4383
> >     > >  rtemstoolkit/rld-dwarf.cpp           |   5 +
> >     > >  rtemstoolkit/rld-dwarf.h             |   5 +
> >     > >  tester/covoar/AddressToLineMapper.cc | 104 +++++++++++++
> >     > >  tester/covoar/AddressToLineMapper.h  | 211 +++++++++++++++++++++++++++
> >     > >  tester/covoar/ExecutableInfo.cc      |  73 +++++----
> >     > >  tester/covoar/ExecutableInfo.h       |  11 +-
> >     > >  tester/covoar/wscript                |   1 +
> >     > >  7 files changed, 368 insertions(+), 42 deletions(-)
> >     > >  create mode 100644 tester/covoar/AddressToLineMapper.cc
> >     > >  create mode 100644 tester/covoar/AddressToLineMapper.h
> >     > > diff --git a/rtemstoolkit/rld-dwarf.cpp b/rtemstoolkit/rld-dwarf.cpp
> >     > > index 2fce0e4..1eae50c 100644
> >     > > --- a/rtemstoolkit/rld-dwarf.cpp
> >     > > +++ b/rtemstoolkit/rld-dwarf.cpp
> >     > > @@ -1893,6 +1893,11 @@ namespace rld
> >     > >        return false;
> >     > > +    const addresses& compilation_unit::get_addresses () const
> >     > > +      return addr_lines_;
> >     > >      functions&
> >     > >      compilation_unit::get_functions ()
> >     > > diff --git a/rtemstoolkit/rld-dwarf.h b/rtemstoolkit/rld-dwarf.h
> >     > > index 1210813..eadb50d 100644
> >     > > --- a/rtemstoolkit/rld-dwarf.h
> >     > > +++ b/rtemstoolkit/rld-dwarf.h
> >     > > @@ -707,6 +707,11 @@ namespace rld
> >     > >        unsigned int pc_high () const;
> >     > > +       * The addresses associated with this compilation unit.
> >     > > +      const addresses& get_addresses () const;
> >     > >         * Get the source and line for an address. If the address does
> >     not match
> >     > >         * false is returned the file is set to 'unknown' and the line is
> >     set to
> >     > > diff --git a/tester/covoar/AddressToLineMapper.cc
> >     b/tester/covoar/AddressToLineMapper.cc
> >     > > new file mode 100644
> >     > > index 0000000..c305e3b
> >     > > --- /dev/null
> >     > > +++ b/tester/covoar/AddressToLineMapper.cc
> >     > > @@ -0,0 +1,104 @@
> >     > > +/*! @file AddressToLineMapper.cc
> >     > > + *  @brief AddressToLineMapper Implementation
> >     > > + *  This file contains the implementation of the functionality
> >     > > + *  of the AddressToLineMapper class.
> >     > > +#include "AddressToLineMapper.h"
> >     > > +namespace Coverage {
> >     > > +  uint64_t SourceLine::location() const
> >     > > +    return address;
> >     > > +  bool SourceLine::is_an_end_sequence() const
> >     > > +    return is_end_sequence;
> >     > > +  const std::string& SourceLine::path() const
> >     > > +    return path_;
> >     > > +  int SourceLine::line() const
> >     > > +    return line_num;
> >     > > +  void AddressLineRange::addSourceLine(const rld::dwarf::address& address)
> >     > > +    auto insertResult = sourcePaths.insert(address.path());
> >     > > +    sourceLines.emplace_back(
> >     > > +      SourceLine (
> >     > > +        address.location(),
> >     > > +        *insertResult.first,
> >     > > +        address.line(),
> >     > > +        address.is_an_end_sequence()
> >     > > +  const SourceLine& AddressLineRange::getSourceLine(uint32_t address) const
> >     > > +    if (address < lowAddress || address > highAddress) {
> >     > > +      throw SourceNotFoundError(std::to_string(address));
> >     > > +    const SourceLine* last_line = nullptr;
> >     > > +    for (const auto &line : sourceLines) {
> >     > > +      if (address <= line.location())
> >     > > +        if (address == line.location())
> >     > > +          last_line = &line;
> >     > > +        break;
> >     > > +    if (last_line == nullptr) {
> >     > > +    return *last_line;
> >     > How often is this function being called? If it is a hot spot are there other
> >     > ways to search for the address? I suppose it depends on the number of lines in
> >     > the vector.
> >     According to a quick gprof run, this function is being called a decent
> >     amount, somewhere around 1.5 million times for a full ARM coverage run.
> >     But it only takes up a very small amount (less than 0.02%) of cumulative
> >     execution time so I don't believe it is an issue.
> > Glad we have profiling data to guide optimizations. I also suspect that as
> > the code is c-plus-plus-ified more, some performance improvements will
> > occur naturally. I know you (Alex) have mentioned some performance
> > improvements just from this alone. But this discussion reminded me of
> > an XKCD and remarks by Dijkstra which are always good to remember.
> > https://m.xkcd.com/1691/ <https://m.xkcd.com/1691/>
> > Dijkstra is famously remembered for a number of variants on the premature
> > optimization theme:
> > "Programmers waste enormous amounts of time thinking about, or worrying about,
> > the speed of noncritical parts of their programs, and these attempts at
> > efficiency actually have a strong negative impact when debugging and maintenance
> > are considered. We should forget about small efficiencies, say about 97% of the
> > time: premature optimization is the root of all evil. Yet we should not pass up
> > our opportunities in that critical 3%."
> > I'd add that I want RTEMS to stay algorithmically optimized instead of
> > tricks. "Optimize" for memory usage, readability, testability, maintainability,
> > etc. If we had focused on tricks 30+ years ago, all of those tricks would
> > likely be  inappropriate and burdens now which only served to negatively
> > impacts.
> Agreed. I was drawn to the code because it uses a pointer and I was looking for
> a C++ approach that did not use a pointer.
So is this ok to push now that it is known to have an insignificant performance impact or is a different approach still warranted?
Thanks,
Alex
> > <old man stops yelling at clouds now>
> How did you know I was? ;)
> Chris
> > --joel
> >     Alex
> >     > If the sourcesLines vector was sorted can this loop be replaced with some form
> >     > of std::upper_bound? That is ...
> >     >  auto last_line =
> >     >     std::upper_bound(sourceLines.begin(),
> >     >                      sourceLines.end(),
> >     >                      address,
> >     >                      [&address](const SourceLine& sl) {
> >     >                        return address < sl.location();
> >     > [ not sure if the code I posted would work and if I got the lamda right :) ]
> >     > Just wondering.
> >     > Chris
> >     > > +  void AddressToLineMapper::getSource(
> >     > > +    uint32_t address,
> >     > > +    std::string& sourceFile,
> >     > > +    int& sourceLine
> >     > > +  ) const {
> >     > > +    const SourceLine default_sourceline = SourceLine();
> >     > > +    const SourceLine* match = &default_sourceline;
> >     > > +    for (const auto &range : addressLineRanges) {
> >     > > +      try {
> >     > > +        const SourceLine& potential_match = range.getSourceLine(address);
> >     > > +        if (match->is_an_end_sequence() ||
> >     !potential_match.is_an_end_sequence()) {
> >     > > +          match = &potential_match;
> >     > > +      } catch (const AddressLineRange::SourceNotFoundError&) {}
> >     > > +    sourceFile = match->path();
> >     > > +    sourceLine = match->line();
> >     > > +  AddressLineRange& AddressToLineMapper::makeRange(
> >     > > +    uint32_t low,
> >     > > +    uint32_t high
> >     > > +    addressLineRanges.emplace_back(
> >     > > +      AddressLineRange(low, high)
> >     > > +    return addressLineRanges.back();
> >     > > diff --git a/tester/covoar/AddressToLineMapper.h
> >     b/tester/covoar/AddressToLineMapper.h
> >     > > index 0000000..e6ab4a8
> >     > > --- /dev/null
> >     > > +++ b/tester/covoar/AddressToLineMapper.h
> >     > > @@ -0,0 +1,211 @@
> >     > > +/*! @file AddressToLineMapper.h
> >     > > + *  @brief AddressToLineMapper Specification
> >     > > + *  This file contains the specification of the AddressToLineMapper class.
> >     > > +#ifndef __ADDRESS_TO_LINE_MAPPER_H__
> >     > > +#define __ADDRESS_TO_LINE_MAPPER_H__
> >     > > +#include <cstdint>
> >     > > +#include <set>
> >     > > +#include <string>
> >     > > +#include <vector>
> >     > > +#include <rld-dwarf.h>
> >     > > +  /*! @class SourceLine
> >     > > +   *  This class stores source information for a specific address.
> >     > > +  class SourceLine {
> >     > > +  public:
> >     > > +    SourceLine()
> >     > > +    : address(0),
> >     > > +      path_("unknown"),
> >     > > +      line_num(-1),
> >     > > +      is_end_sequence(true)
> >     > > +    SourceLine(
> >     > > +      uint64_t addr,
> >     > > +      const std::string& src,
> >     > > +      int line,
> >     > > +      bool end_sequence
> >     > > +    ) : address(addr),
> >     > > +        path_(src),
> >     > > +        line_num(line),
> >     > > +        is_end_sequence(end_sequence)
> >     > > +     *  This method gets the address of this source information.
> >     > > +     *  @return Returns the address of this source information
> >     > > +    uint64_t location() const;
> >     > > +     *  This method gets a value indicating whether this address
> >     represents an
> >     > > +     *  end sequence.
> >     > > +     *  @return Returns whether this address represents an end sequence
> >     or not
> >     > > +    bool is_an_end_sequence() const;
> >     > > +     *  This method gets the source file path of this address.
> >     > > +     *  @return Returns the source file path of this address
> >     > > +    const std::string& path() const;
> >     > > +     *  This method gets the source line number of this address.
> >     > > +     *  @return Returns the source line number of this address
> >     > > +    int line() const;
> >     > > +  private:
> >     > > +     *  The address of this source information.
> >     > > +    uint64_t address;
> >     > > +     *  An iterator pointing to the location in the set that contains the
> >     > > +     *  source file path of the address.
> >     > > +    const std::string& path_;
> >     > > +     *  The source line number of the address.
> >     > > +    int line_num;
> >     > > +     *  Whether the address represents an end sequence or not.
> >     > > +    bool is_end_sequence;
> >     > > +  typedef std::vector<SourceLine> SourceLines;
> >     > > +  typedef std::set<std::string> SourcePaths;
> >     > > +  /*! @class AddressLineRange
> >     > > +   *  This class stores source information for an address range.
> >     > > +  class AddressLineRange {
> >     > > +  public:
> >     > > +    class SourceNotFoundError : public std::runtime_error {
> >     > > +      /* Use the base class constructors. */
> >     > > +      using std::runtime_error::runtime_error;
> >     > > +    AddressLineRange(
> >     > > +      uint32_t low,
> >     > > +      uint32_t high
> >     > > +    ) : lowAddress(low), highAddress(high)
> >     > > +     *  This method adds source and line information for a specified
> >     address.
> >     > > +     *  @param[in] address specifies the DWARF address information
> >     > > +    void addSourceLine(const rld::dwarf::address& address);
> >     > > +     *  This method gets the source file name and line number for a given
> >     > > +     *  address.
> >     > > +     *  @param[in] address specifies the address to look up
> >     > > +     *  @return Returns the source information for the specified address.
> >     > > +    const SourceLine& getSourceLine(uint32_t address) const;
> >     > > +  private:
> >     > > +     *  The low address for this range.
> >     > > +    uint32_t lowAddress;
> >     > > +     *  The high address for this range.
> >     > > +    uint32_t highAddress;
> >     > > +     *  The source information for addresses in this range.
> >     > > +    SourceLines sourceLines;
> >     > > +     *  The set of source file names for this range.
> >     > > +    SourcePaths sourcePaths;
> >     > > +  typedef std::vector<AddressLineRange> AddressLineRanges;
> >     > > +  /*! @class AddressToLineMapper
> >     > > +   *  This class provides address-to-line capabilities.
> >     > > +  class AddressToLineMapper {
> >     > > +  public:
> >     > > +     *  address.
> >     > > +     *  @param[out] sourceFile specifies the name of the source file
> >     > > +     *  @param[out] sourceLine specifies the line number in the source file
> >     > > +    void getSource(
> >     > > +      uint32_t address,
> >     > > +      int& sourceLine
> >     > > +    ) const;
> >     > > +     *  This method creates a new range with the specified addresses.
> >     > > +     *  @param[in] low specifies the low address of the range
> >     > > +     *  @param[in] high specifies the high address of the range
> >     > > +     *  @return Returns a reference to the newly created range
> >     > > +    AddressLineRange& makeRange(uint32_t low, uint32_t high);
> >     > > +  private:
> >     > > +     *  The address and line information ranges.
> >     > > +    AddressLineRanges addressLineRanges;
> >     > > +#endif
> >     > > diff --git a/tester/covoar/ExecutableInfo.cc
> >     b/tester/covoar/ExecutableInfo.cc
> >     > > index 861e60d..a6184e7 100644
> >     > > --- a/tester/covoar/ExecutableInfo.cc
> >     > > +++ b/tester/covoar/ExecutableInfo.cc
> >     > > @@ -40,61 +40,60 @@ namespace Coverage {
> >     > >      executable.begin();
> >     > >      executable.load_symbols(symbols);
> >     > > +    rld::dwarf::file debug;
> >     > >      debug.begin(executable.elf());
> >     > >      debug.load_debug();
> >     > >      debug.load_functions();
> >     > > -    try {
> >     > > -      for (auto& cu : debug.get_cus()) {
> >     > > -        for (auto& func : cu.get_functions()) {
> >     > > -          if (!func.has_machine_code()) {
> >     > > -            continue;
> >     > > +    for (auto& cu : debug.get_cus()) {
> >     > > +      AddressLineRange& range = mapper.makeRange(cu.pc_low(),
> >     cu.pc_high());
> >     > > +      // Does not filter on desired symbols under the assumption that
> >     the test
> >     > > +      // code and any support code is small relative to what is being
> >     tested.
> >     > > +      for (const auto &address : cu.get_addresses()) {
> >     > > +        range.addSourceLine(address);
> >     > > -          if (!SymbolsToAnalyze->isDesired(func.name
> >     <http://func.name>())) {
> >     > > -            continue;
> >     > > +      for (auto& func : cu.get_functions()) {
> >     > > +        if (!func.has_machine_code()) {
> >     > > +          continue;
> >     > > +        if (!SymbolsToAnalyze->isDesired(func.name <http://func.name>())) {
> >     > > +          continue;
> >     > > +        if (func.is_inlined()) {
> >     > > +          if (func.is_external()) {
> >     > > +            // Flag it
> >     > > +            std::cerr << "Function is both external and inlined: "
> >     > > +                      << func.name <http://func.name>() << std::endl;
> >     > > -          if (func.is_inlined()) {
> >     > > -            if (func.is_external()) {
> >     > > -              // Flag it
> >     > > -              std::cerr << "Function is both external and inlined: "
> >     > > -                        << func.name <http://func.name>() << std::endl;
> >     > > -            if (func.has_entry_pc()) {
> >     > > -              continue;
> >     > > -            // If the low PC address is zero, the symbol does not appear in
> >     > > -            // this executable.
> >     > > -            if (func.pc_low() == 0) {
> >     > > -              continue;
> >     > > +          if (func.has_entry_pc()) {
> >     > > +            continue;
> >     > > -          // We can't process a zero size function.
> >     > > -          if (func.pc_high() == 0) {
> >     > > +          // If the low PC address is zero, the symbol does not appear in
> >     > > +          // this executable.
> >     > > +          if (func.pc_low() == 0) {
> >     > >              continue;
> >     > > -          createCoverageMap (cu.name <http://cu.name>(), func.name
> >     <http://func.name>(),
> >     > > -                              func.pc_low(), func.pc_high() - 1);
> >     > > +        // We can't process a zero size function.
> >     > > +        if (func.pc_high() == 0) {
> >     > > +          continue;
> >     > > +        createCoverageMap (cu.name <http://cu.name>(), func.name
> >     > > +                            func.pc_low(), func.pc_high() - 1);
> >     > > -    } catch (...) {
> >     > > -      debug.end();
> >     > > -      throw;
> >     > > -    // Can't cleanup handles until the destructor because the
> >     information is
> >     > > -    // referenced elsewhere. NOTE: This could cause problems from too
> >     many open
> >     > > -    // file descriptors.
> >     > >    ExecutableInfo::~ExecutableInfo()
> >     > > -    debug.end();
> >     > >    void ExecutableInfo::dumpCoverageMaps( void ) {
> >     > > @@ -197,7 +196,7 @@ namespace Coverage {
> >     > >      std::string file;
> >     > >      int         lno;
> >     > > -    debug.get_source (address, file, lno);
> >     > > +    mapper.getSource (address, file, lno);
> >     > >      std::ostringstream ss;
> >     > >      ss << file << ':' << lno;
> >     > >      line = ss.str ();
> >     > > diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
> >     > > index 5d5a595..dfc71aa 100644
> >     > > --- a/tester/covoar/ExecutableInfo.h
> >     > > +++ b/tester/covoar/ExecutableInfo.h
> >     > > @@ -15,6 +15,7 @@
> >     > >  #include <rld-files.h>
> >     > >  #include <rld-symbols.h>
> >     > >  #include "CoverageMapBase.h"
> >     > >  #include "SymbolTable.h"
> >     > > @@ -157,11 +158,6 @@ namespace Coverage {
> >     > > -     *  The DWARF data to the ELF executable.
> >     > > -    rld::dwarf::file debug;
> >     > >       *  The executable's file name.
> >     > > @@ -172,6 +168,11 @@ namespace Coverage {
> >     > >      rld::symbols::table symbols;
> >     > > +     *  The address-to-line mapper for this executable.
> >     > > +    AddressToLineMapper mapper;
> >     > >       *  This map associates a symbol with its coverage map.
> >     > > diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> >     > > index 82599b0..a928b1b 100644
> >     > > --- a/tester/covoar/wscript
> >     > > +++ b/tester/covoar/wscript
> >     > > @@ -83,6 +83,7 @@ def build(bld):
> >     > >      bld.stlib(target = 'ccovoar',
> >     > >                source = ['app_common.cc',
> >     > > +                        'AddressToLineMapper.cc',
> >     > >                          'CoverageFactory.cc',
> >     > >                          'CoverageMap.cc',
> >     > >                          'CoverageMapBase.cc',
> >     > _______________________________________________
> >     > devel mailing list
> >     > devel at rtems.org <mailto:devel at rtems.org>
> >     > http://lists.rtems.org/mailman/listinfo/devel
> >     <http://lists.rtems.org/mailman/listinfo/devel>
> >     devel mailing list
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210617/4a146e94/attachment-0001.html>
