New API directives to enable/disable interrupt vectors
Thu Jun 17 05:40:25 UTC 2021
On 16/06/2021 20:36, Gedare Bloom wrote:
> Looks like the existing irq-extension.h uses 'vector', so
> rtems_interrupt_disable_vector() is a possibility, or else
> rtems_interrupt_controller_disable_vector() is more wordy but if we
> want to treat 'interrupt controller' as its own category of API
> separate from 'interrupt'.
Yes, mixing "vector" into the name a good idea.  What about
rtems_interrupt_vector_enable() and rtems_interrupt_vector_disable()?
I am not that fond of using "interrupt controller" since I don't want to
change the existing API and it would result in very long directive names.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
