New API directives to enable/disable interrupt vectors
Fri Jun 18 05:25:00 UTC 2021
On 18/06/2021 03:30, Chris Johns wrote:
> The list does not capture things like rtems_interrupt_mask which is a typedef.
The rtems_interrupt_mask is a constant object:
  * @ingroup RTEMSAPIClassicModes
  * @brief This task mode constant has the same value as
#RTEMS_INTERRUPT_MASK.
  * @par Notes
  * This task mode constant is used by bindings from languages other
than C and
  * C++.
extern const uint32_t rtems_interrupt_mask;
> My concern is:
> rtems_interrupt_disable
> rtems_interrupt_enable
The two macros above are a legacy interface available only in
uniprocessor configurations.
> rtems_interrupt_local_disable
> rtems_interrupt_local_enable
> and then we add:
> rtems_interrupt_vector_disable
> rtems_interrupt_vector_enable
So basically we have to compare these two variants. I think the names
which include "local" and "vector" are clear enough from my point of
view. The primary use case for the vector enable/disable is probably
test code.
> How do each of these enable/disable pairs interact with the other parts of the API?
> This also seems to pull back to Sebastian's initial comment about the
> enable/disable being occupied and I wonder if that concern highlights the need
> for some cleaning in the API? It is does it may take a release or 2 to migrate
> users but it may be worth it in the long run if the API is made clearer.
I will send a patch set in the next days with a proposal for some new
directives. I would not change what we have.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
