[PATCH] part of implimenting a monotonic clock in rtems part of this is not the final patch.
Christian Mauderer
oss at c-mauderer.de
Fri Jun 18 08:01:18 UTC 2021
Hello Zack,
On 18/06/2021 04:34, zack_on_the_speed_chanel wrote:
> so I tested it with the but I have not made a new test file I'll do that soon. How do I add a new test? All the tests that test the timer functionality do work. I"m confident that all the changes I had to made to implement a monotonic clock should be there.
Regarding a new test: Just grep for example for psxtimer01 in the
sources and add the new test simmilar to the existing one.
The most relevant files are spec/build/testsuites/psxtests/*.yml for the
waf based build system and testsuites/psxtests/Makefile.am and
.../configure.ac for the old build system.
But please check whether you need a new test program. If you basically
only copy the test routine of psxtimer01 or psxtimer02 and replace all
CLOCK_REALTIME by CLOCK_MONOTONIC then you shouldn't add a new test.
Instead create a function in the test that is called once with
CLOCK_REALTIME and once with CLOCK_MONOTONIC.
Please make sure that the test not only tests the API but also whether
the timer work as expected. A timer with CLOCK_REALTIME can be affected
by changes in the wall clock. CLOCK_MONOTONIC should not be affected. So
please make sure that your test checks whether that is really the case.
Best regards
Christian
> Thanks
> Zack
> Sent with ProtonMail Secure Email.
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Tuesday, June 15th, 2021 at 7:29 AM, Christian Mauderer <oss at c-mauderer.de> wrote:
>> If you add a new functionallity you should add a test that tests the
>> expected behaviour. You just shouldn't replace one but add a new test or
>> a new test case to an existing test.
>> Best regards
>> Christian
>> On 14/06/2021 22:18, zack_on_the_speed_chanel wrote:
>>> also i'll revert the posix test that I changed back to normal because it was only for testing.
>>> On Monday, June 14th, 2021 at 8:14 PM, zack_on_the_speed_chanel zack_on_the_speed_chanel at protonmail.ch wrote:
>>>> I've made most of the corrections to the code. I fixed up the formatting but I still don't know if I have to add anything for the settime and delete_timer(). i assume as the monotonic clock only affects the value I think it's all I have to do. I also can try to modify a posix test to check my theory.
>>>> Thanks
>>>> Zack
>>>> On Saturday, June 12th, 2021 at 9:31 AM, Christian Mauderer oss at c-mauderer.de wrote:
>>>>> Hello Zack,
>>>>> I don't really know a lot about the timer toppic. So this is more of a
>>>>> style and general suggestion review.
>>>>> On 09/06/2021 20:27, zack wrote:
>>>>>> From: zack zack_on_the_speed_chanel at protonmail.ch
>>>>>> cpukit/include/rtems/posix/timer.h | 6 ++-
>>>>>> cpukit/posix/src/psxtimercreate.c | 5 +-
>>>>>> cpukit/posix/src/timergettime.c | 61 ++++++++++++++++++++---
>>>>>> testsuites/psxtests/psxtimer02/psxtimer.c | 26 +++++++---
>>>>>> 4 files changed, 81 insertions(+), 17 deletions(-)
>>>>>> diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
>>>>>> index bcbf07a65a..f8cf6115b2 100644
>>>>>> --- a/cpukit/include/rtems/posix/timer.h
>>>>>> +++ b/cpukit/include/rtems/posix/timer.h
>>>>>> @@ -21,7 +21,7 @@
>>>>>> #include <rtems/score/objectdata.h>
>>>>>> #include <rtems/score/watchdog.h>
>>>>> I think the blank line separated rtems includes from others. So please
>>>>> don't remove it.
>>>>>> +#include <time.h>
>>>>>> #include <pthread.h>
>>>>>> #ifdef __cplusplus
>>>>>> @@ -47,7 +47,9 @@ typedef struct {
>>>>>> struct itimerspec timer_data; /* Timing data of the timer /
>>>>>> uint32_t ticks; / Number of ticks of the initialization /
>>>>>> uint32_t overrun; / Number of expirations of the timer */
>>>>>> - struct timespec time; /* Time at which the timer was started */
>>>>> Not sure what changed in that line. Looks like a whitespace change.
>>>>> Please avoid these.
>>>>>> - clockid_t clock_type;
>>>>> Why a blank line?
>>>>>> } POSIX_Timer_Control;
>>>>>> diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
>>>>>> index a63cf1d100..e78c359bd5 100644
>>>>>> --- a/cpukit/posix/src/psxtimercreate.c
>>>>>> +++ b/cpukit/posix/src/psxtimercreate.c
>>>>>> @@ -40,7 +40,7 @@ int timer_create(
>>>>>> POSIX_Timer_Control *ptimer;
>>>>>> - if ( clock_id != CLOCK_REALTIME )
>>>>>> - if ( clock_id != CLOCK_REALTIME || clock_id != CLOCK_MONOTONIC )
>>>>> Not sure about that one. It's allways a bit difficult whith these
>>>>> constructions but I think this one is allways true and therefore will
>>>>> allways return an error.
>>>>> Let's assume clock_id is CLOCK_MONOTONIC. In that case (clock_id !=
>>>>> CLOCK_REALTIME) is true which means that the function will return with
>>>>> an error. The same works for CLOCK_RREALTIME and the second condition.
>>>>> If you apply De Morgan to the term you see that
>>>>> (clock_id != CLOCK_REALTIME || clock_id != CLOCK_MONOTONIC)
>>>>> is the same as
>>>>> !(clock_id == CLOCK_REALTIME && clock_id == CLOCK_MONOTONIC)
>>>>> The two inner comparisons are exclusive. So that won't work.
>>>>> What you most likely want is a
>>>>> !(clock_id == CLOCK_REALTIME || clock_id == CLOCK_MONOTONIC)
>>>>> or with De Morgan again:
>>>>> (clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC)
>>>>>> rtems_set_errno_and_return_minus_one( EINVAL );
>>>>>> if ( !timerid )
>>>>>> @@ -91,7 +91,8 @@ int timer_create(
>>>>>> ptimer->timer_data.it_value.tv_nsec = 0;
>>>>>> ptimer->timer_data.it_interval.tv_sec = 0;
>>>>>> ptimer->timer_data.it_interval.tv_nsec = 0;
>>>>>> - ptimer->clock_type=clock_id;
>>>>>> - _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
>>>>>> _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
>>>>>> _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
>>>>>> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
>>>>>> index ee2a566f0e..62011cde58 100644
>>>>>> --- a/cpukit/posix/src/timergettime.c
>>>>>> +++ b/cpukit/posix/src/timergettime.c
>>>>>> @@ -28,6 +28,7 @@
>>>>>> #include <rtems/score/todimpl.h>
>>>>>> #include <rtems/score/watchdogimpl.h>
>>>>>> #include <rtems/seterr.h>
>>>>>> +#include <rtems/timespec.h>
>>>>>> - - When a timer is initialized, the value of the time in
>>>>>> @@ -43,21 +44,67 @@ int timer_gettime(
>>>>>> ISR_lock_Context lock_context;
>>>>>> - uint64_t now;
>>>>>> uint32_t remaining;
>>>>>> - Per_CPU_Control *cpu;
>>>>>> - struct timespec * now; // get time now either with
>>>>>> - struct timespec * expire; // expire
>>>>>> - struct timespec * result;// get remaining time
>>>>>> if ( !value )
>>>>>> - rtems_set_errno_and_return_minus_one( EINVAL );
>>>>>> ptimer = _POSIX_Timer_Get( timerid, &lock_context );
>>>>>> - if ( ptimer != NULL ) {
>>>>>> - if(ptimer== NULL ){
>>>>> Style: There should be a space before the ==
>>>>>> +if ( ptimer->clock_type ==CLOCK_REALTIME) {
>>>>> Style again: Space after ==
>>>>> Why that many blank lines?
>>>>>> - cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
>>>>>> - _TOD_Get(now); // get current time
>>>>>> - rtems_timespec_from_ticks (ptimer->Timer.expire,expire ); // get the time to expire
>>>>> That are C++ style comments. We normally have C-Style comments in RTEMS
>>>>> only. Beneath that the comments exceed the line length. And some of them
>>>>> are quite superflous. A _TOD_Get(now) doesn't need any comment. The line
>>>>> is already telling that.
>>>>> Again: Blank lines. I won't mention the further blank lines below!
>>>>>> - if (now->tv_nsec+now->tv_sec > expire->tv_nsec+expire->tv_sec) { // check if the time expired
>>>>>> - rtems_timespec_subtract (now ,expire , result); //
>>>>> Empty comment at the end of the line?
>>>>>> - remaining = (uint32_t) result->tv_nsec+result->tv_sec;
>>>>>> - } else {
>>>>>> - remaining = 0;
>>>>>> - _Timespec_From_ticks( remaining, &value->it_value );
>>>>>> - value->it_interval = ptimer->timer_data.it_interval;
>>>>>> - _POSIX_Timer_Release( cpu, &lock_context );
>>>>>> - return 0;
>>>>>> +if ( ptimer->clock_type ==CLOCK_MONOTONIC) {
>>>>> Odd indentation and missing blank before the closing bracket.
>>>>> Indentation and some blanks on brackets seems to be a problem on quite
>>>>> some more lines too.
>>>>>> - now = cpu->Watchdog.ticks;
>>>>>> - _Timecounter_Nanouptime(now );
>>>>>> - rtems_timespec_subtract (now, expire, result);
>>>>>> - if ( now < ptimer->Timer.expire ) {
>>>>>> - remaining = (uint32_t) ( ptimer->Timer.expire - now );
>>>>>> } else {
>>>>>> remaining = 0;
>>>>>> diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
>>>>>> index 9f79d33c42..029e638c76 100644
>>>>>> --- a/testsuites/psxtests/psxtimer02/psxtimer.c
>>>>>> +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
>>>>>> @@ -59,17 +59,31 @@ void *POSIX_Init (
>>>>>> fatal_posix_service_status_errno( status, EINVAL, "bad clock id" );
>>>>>> puts( "timer_create - bad timer id pointer - EINVAL" );
>>>>>> - status = timer_create( CLOCK_REALTIME, &event, NULL );
>>>>>> - status = timer_create( CLOCK_MONOTONIC, &event, NULL );
>>>>>> fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>>>>> It seems that you replace the test for REALTIME timers. Are they no
>>>>> longer supported with your changes? I'm not sure whether that is a good
>>>>> idea because it would break all existing applications that use REALTIME
>>>>> timer.
>>>>>> puts( "timer_create - OK" );
>>>>>> - status = timer_create( CLOCK_REALTIME, NULL, &timer );
>>>>>> - status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
>>>>>> posix_service_failed( status, "timer_create OK" );
>>>>>> puts( "timer_create - too many - EAGAIN" );
>>>>>> - status = timer_create( CLOCK_REALTIME, NULL, &timer1 );
>>>>>> - status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
>>>>>> fatal_posix_service_status_errno( status, EAGAIN, "too many" );
>>>>>> - puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
>>>>>> - fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>>>>>> - puts( "timer_create (Monotonic) - OK" );
>>>>>> - posix_service_failed( status, "timer_create OK" );
>>>>>> - puts( "timer_create (monotonic)- too many - EAGAIN" );
>>>>>> - fatal_posix_service_status_errno( status, EAGAIN, "too many" );
>>>>>> - puts( "timer_delete - bad id - EINVAL" );
>>>>>> status = timer_delete( timer1 + 1 );
>>>>>> fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>>>>>> @@ -100,14 +114,14 @@ void *POSIX_Init (
>>>>>> status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
>>>>>> fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #2" );
>>>>>> - clock_gettime( CLOCK_REALTIME, &now );
>>>>>> - clock_gettime( CLOCK_MONOTONIC, &now );
>>>>>> itimer.it_value = now;
>>>>>> itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
>>>>>> puts( "timer_settime - bad itimer value - previous time - EINVAL" );
>>>>>> fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
>>>>>> itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
>>>>>> puts( "timer_settime - bad id - EINVAL" );
>>>>>> @@ -129,4 +143,4 @@ void *POSIX_Init (
>>>>>> TEST_END();
>>>>>> rtems_test_exit (0);
>>>>>> \ No newline at end of file
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
