[PATCH v2 01/12] bsps/irq: Remove BSP_INTERRUPT_NO_HEAP_USAGE
Sebastian Huber
Sat Jun 19 14:04:37 UTC 2021
Remove the support for BSP_INTERRUPT_NO_HEAP_USAGE. This was only used
by one BSP and provides no real benefit.
Update #3269.
bsps/include/bsp/irq-generic.h | 8 ------
bsps/powerpc/mpc55xxevb/include/bsp/irq.h | 1 -
bsps/shared/irq/irq-generic.c | 34 ++---------------------
3 files changed, 3 insertions(+), 40 deletions(-)
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 4135aa518c..e888a66cea 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -66,10 +66,6 @@ extern "C" {
#error "if you define BSP_INTERRUPT_USE_INDEX_TABLE, you have to define BSP_INTERRUPT_HANDLER_TABLE_SIZE etc. as well"
#endif
-#if defined(BSP_INTERRUPT_NO_HEAP_USAGE) && !defined(BSP_INTERRUPT_USE_INDEX_TABLE)
- #error "if you define BSP_INTERRUPT_NO_HEAP_USAGE, you have to define BSP_INTERRUPT_USE_INDEX_TABLE etc. as well"
-#endif
#define BSP_INTERRUPT_VECTOR_NUMBER \
(BSP_INTERRUPT_VECTOR_MAX - BSP_INTERRUPT_VECTOR_MIN + 1)
@@ -150,10 +146,6 @@ static inline rtems_vector_number bsp_interrupt_handler_index(
* table will be accessed via a small index table. You can define the size of
* the handler table with @ref BSP_INTERRUPT_HANDLER_TABLE_SIZE.
- * Normally new list entries are allocated from the heap. You may define
- * @ref BSP_INTERRUPT_NO_HEAP_USAGE, if you do not want to use the heap. For
- * this option you have to define @ref BSP_INTERRUPT_USE_INDEX_TABLE as well.
* You have to provide some special routines in your BSP (follow the links for
* the details):
* - bsp_interrupt_facility_initialize()
diff --git a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
index c923859dec..491c120ee8 100644
--- a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
+++ b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
@@ -483,7 +483,6 @@ rtems_status_code mpc55xx_intc_clear_software_irq(rtems_vector_number vector);
#ifdef BSP_INTERRUPT_HANDLER_TABLE_SIZE
#define BSP_INTERRUPT_USE_INDEX_TABLE
- #define BSP_INTERRUPT_NO_HEAP_USAGE
#endif
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index 1e83a6f249..abe732a9d3 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -142,34 +142,6 @@ static inline bool bsp_interrupt_allocate_handler_index(
#endif
-static bsp_interrupt_handler_entry *bsp_interrupt_allocate_handler_entry(void)
- bsp_interrupt_handler_entry *e;
- #ifdef BSP_INTERRUPT_NO_HEAP_USAGE
- rtems_vector_number index = 0;
- if (bsp_interrupt_allocate_handler_index(0, &index)) {
- e = &bsp_interrupt_handler_table [index];
- } else {
- e = NULL;
- #else
- e = rtems_malloc(sizeof(*e));
- #endif
- return e;
-static void bsp_interrupt_free_handler_entry(bsp_interrupt_handler_entry *e)
- bsp_interrupt_clear_handler_entry(e, 0);
- #else
- free(e);
- #endif
void bsp_interrupt_initialize(void)
rtems_status_code sc = RTEMS_SUCCESSFUL;
@@ -318,7 +290,7 @@ static rtems_status_code bsp_interrupt_handler_install(
/* Allocate a new entry */
- current = bsp_interrupt_allocate_handler_entry();
+ current = rtems_malloc(sizeof(*current));
if (current == NULL) {
/* Not enough memory */
bsp_interrupt_unlock();
@@ -433,7 +405,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
match->next = current->next;
bsp_interrupt_enable(level);
- bsp_interrupt_free_handler_entry(current);
+ free(current);
} else if (match == head) {
* The match is the list head and has no successor.
@@ -465,7 +437,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
bsp_interrupt_fence(ATOMIC_ORDER_RELEASE);
- bsp_interrupt_free_handler_entry(match);
+ free(match);
} else {
/* No matching entry found */
2.26.2
