[PATCH rtems 2/2] bsps/imxrt: Simplify linkcmds and make it flexible
Sebastian Huber
Mon Jun 21 13:00:11 UTC 2021
On 19/06/2021 16:35, dufault at hda.com wrote:
> I'm getting back to this as I have the HyperRAM working so I'm trying to set up appropriate linker settings.
>> On Jun 10, 2021, at 01:43 , Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>> The initial stack needs to be in an accessible memory area. Currently it is placed in this linker output section:
>> .rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
>> bsp_section_rtemsstack_begin = .;
>> *(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
>> bsp_section_rtemsstack_end = .;
>> } > REGION_WORK AT > REGION_WORK
>> bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
>> Maybe we should place the .rtemsstack.interrupt input section into the REGION_VECTOR memory region.
> On the "imxrt" REGION_VECTOR is in FLASH, at least ".vector' in the app I'm testing is at 0x6004653c which is in HyperFLASH.
Then place the .rtemsstack.interrupt input section into the REGION_STACK
memory region and make sure REGIION_STACK is located in the OCRAM.
> In HyperRAM I see these regions allocated:
> REGION_DATA: .rwbarrier
> REGION_DATA_LOAD: .data, .rtemsrwset
> REGION_BSS: .bss
> REGION_WORK: .rtemsstack, .work
> REGION_STACK: .stack
> So I put REGION_WORK in the OCRAM to get .rtemsstack out of HyperRAM to get started. My application is now running out of HyperFLASH and HyperRAM though I'm sure I'll find issues.
> - What's in "REGION_WORK"? Does that have anything to do with the RTEMS work space?
Yes, the RTEMS Workspace and C Program Heap use this region.
> - What's the proper solution? I don't particularly want to redo my HyperRAM initialization to avoid using stack since I'm calling some NXP functions. I'd like a small amount of stack available in the context of bsp_start_hook_0() to set up the external RAM.
> - What's going on in the shared ARM _start with bsp_start_hook_0_done and the branch to bsp_start_hook_0()?
Some arm BSPs don't have a boot loader and relocate during startup from
flash to RAM. See comment in start.S.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
