[PATCH rtems-docs] user/bsps/imxrt: Info about ARM PLL frequency
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Jun 21 14:58:44 UTC 2021
user/bsps/arm/imxrt.rst | 20 ++++++++++++++++++++
1 file changed, 20 insertions(+)
diff --git a/user/bsps/arm/imxrt.rst b/user/bsps/arm/imxrt.rst
index 8a5ee28..3f8b270 100644
--- a/user/bsps/arm/imxrt.rst
+++ b/user/bsps/arm/imxrt.rst
@@ -123,6 +123,26 @@ with your FDT source names)::
Make sure that your new C file is compiled and linked into the application.
+PLL Settings
+The commercial variant of the i.MXRT1052 on the evaluation board allows a clock
+up to 600MHz for the ARM core. For some industrial variants only up to 528MHz
+are specified. To make it possible to adapt to these variants the application
+can overwrite the following constant:
+.. code-block:: c
+ #include "fsl_clock_config.h"
+ const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
+ .loopDivider = 100,
+ .src = 0,
+With the default configuration of a 24MHz oscillator, the loopDivider has to be
+88 for the 528MHz.
Clock Driver
2.26.2
