rtems-docs: Update eclipse/rtems.rst?
Raymond Garza raymond.garza at oarcorp.com
Tue Jun 22 19:13:51 UTC 2021
While going through the docs to update everything for RTEMS 6, I've noticed one particular file to be problematic. Before I do anything to it, I'd like to consult the mailing list.
In the rtems-docs repository, the eclipse -> rtems.rst file describes instructions to build a BSP in Eclipse. For reference, the resulting html page can be found at https://docs.rtems.org/branches/master/eclipse/rtems.html
Now, with the introduction of RTEMS 6, all autoconf/make build instructions are no longer supported. Waf is used instead, and Eclipse offers no support for Waf builds. So, the majority of this article needs to be either replaced with instructions to hack a Waf build into Eclipse, or be deleted. Before I do anything, I'd like some opinions on the matter.
Thanks,
Raymond Garza
raymond.garza at oarcorp.com<mailto:raymond.garza at oarcorp.com>
(Cell) 256-617-3005
[cid:image001.png at 01D76770.D2EEC360]
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210622/a65573c8/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210622/a65573c8/attachment-0001.png>
