[PATCH 5/6] bsps/aarch64: add physical secure timer
Wed Jun 23 04:29:56 UTC 2021
 .../shared/clock/arm-generic-timer-aarch64.c    |  8 ++++++++
 bsps/aarch64/xilinx-versal/include/bsp/irq.h    |  1 +
 spec/build/bsps/aarch64/optgtuseps.yml          | 17 +++++++++++++++++
 spec/build/bsps/aarch64/optgtusevirt.yml        | 16 ++++++++++++++++
 4 files changed, 42 insertions(+)
 create mode 100644 spec/build/bsps/aarch64/optgtuseps.yml
 create mode 100644 spec/build/bsps/aarch64/optgtusevirt.yml
diff --git a/bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c b/bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
index 977910ff3a..9ed1a8ccdd 100644
--- a/bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+++ b/bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
@@ -43,6 +43,8 @@ uint64_t arm_gt_clock_get_compare_value(void)
   __asm__ volatile (
 #ifdef AARCH64_GENERIC_TIMER_USE_VIRTUAL
     "mrs %[val], cntv_cval_el0"
+#elif defined(AARCH64_GENERIC_TIMER_USE_PHYSICAL_SECURE)
+    "mrs %[val], cntps_cval_el1"
 #else
     "mrs %[val], cntp_cval_el0"
 #endif
@@ -56,6 +58,8 @@ void arm_gt_clock_set_compare_value(uint64_t cval)
   __asm__ volatile (
     "msr cntv_cval_el0, %[cval]"
+    "msr cntps_cval_el1, %[cval]"
 #else
     "msr cntp_cval_el0, %[cval]"
 #endif
@@ -83,6 +87,8 @@ void arm_gt_clock_set_control(uint32_t ctl)
   __asm__ volatile (
     "msr cntv_ctl_el0, %[ctl]"
+    "msr cntps_ctl_el1, %[ctl]"
 #else
     "msr cntp_ctl_el0, %[ctl]"
 #endif
@@ -102,6 +108,8 @@ void arm_generic_timer_get_config( uint32_t *frequency, uint32_t *irq )
 #ifdef ARM_GENERIC_TIMER_USE_VIRTUAL
   *irq = BSP_TIMER_VIRT_PPI;
+  *irq = BSP_TIMER_PHYS_S_PPI;
 #else
   *irq = BSP_TIMER_PHYS_NS_PPI;
 #endif
diff --git a/bsps/aarch64/xilinx-versal/include/bsp/irq.h b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
index d7ec5b7c4a..af92bcde05 100644
--- a/bsps/aarch64/xilinx-versal/include/bsp/irq.h
+++ b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
@@ -52,6 +52,7 @@ extern "C" {
 /* Interrupts vectors */
 #define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_S_PPI 29
 #define BSP_TIMER_PHYS_NS_PPI 30
 #define VERSAL_IRQ_UART_0 50
 #define VERSAL_IRQ_UART_1 51
diff --git a/spec/build/bsps/aarch64/optgtuseps.yml b/spec/build/bsps/aarch64/optgtuseps.yml
new file mode 100644
index 0000000000..3c85f08e17
--- /dev/null
+++ b/spec/build/bsps/aarch64/optgtuseps.yml
@@ -0,0 +1,17 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+default: false
+default-by-variant: []
+description: |
+  If set to true, and AARCH64_GENERIC_TIMER_USE_VIRTUAL is false, then
+  the clock driver uses the Physical Secure Timer of the AARCH64
+  Generic Timer, otherwise it uses the Physical Non-Secure Timer (EL1).
+enabled-by: true
+links: []
+name: AARCH64_GENERIC_TIMER_USE_PHYSICAL_SECURE
+type: build
diff --git a/spec/build/bsps/aarch64/optgtusevirt.yml b/spec/build/bsps/aarch64/optgtusevirt.yml
index 0000000000..919eb86c32
--- /dev/null
+++ b/spec/build/bsps/aarch64/optgtusevirt.yml
@@ -0,0 +1,16 @@
+actions:
+build-type: option
+copyrights:
+default: false
+description: |
+  If set to true, then the clock driver uses the Virtual Timer of the AARCH64
+enabled-by: true
+links: []
+name: AARCH64_GENERIC_TIMER_USE_VIRTUAL
+type: build
2.25.1
