[PATCH] user/bsps: add aarch64 xilinx-versal
Gedare Bloom
gedare at rtems.org
Wed Jun 23 04:30:49 UTC 2021
user/bsps/aarch64/xilinx-versal.rst | 39 +++++++++++++++++++++++++++++
user/bsps/bsps-aarch64.rst | 1 +
2 files changed, 40 insertions(+)
create mode 100644 user/bsps/aarch64/xilinx-versal.rst
diff --git a/user/bsps/aarch64/xilinx-versal.rst b/user/bsps/aarch64/xilinx-versal.rst
new file mode 100644
index 0000000..51489f2
--- /dev/null
+++ b/user/bsps/aarch64/xilinx-versal.rst
@@ -0,0 +1,39 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2021 Gedare Bloom
+.. _BSP_aarch64_qemu_xilinx_versal_ilp32_qemu:
+.. _BSP_aarch64_qemu_xilinx_versal_lp64_qemu:
+Qemu Xilinx Versal
+This BSP supports two variants, `xilinx-versal-ilp32-qemu` and
+`xilinx-versal-lp64-qemu`. The basic hardware initialization is performed by the
+BSP. These BSPs support the GICv3 interrupt controller present in the Xilinx
+Versal Adaptive Compute Acceleration Platform (ACAP) systems. The BSPs
+currently only work when started in the secure mode.
+Boot via ELF
+The executable image is booted by Qemu in ELF format.
+Clock Driver
+The clock driver uses the `ARM Generic Timer`.
+Console Driver
+The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART.
+There are some differences between the PL011 and the UART used by actual Versal
+ACAP hardware systems.
+Running Executables
+Executables generated by these BSPs can be run using the following command::
+qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
+ -machine xlnx-versal-virt -m 4096 -kernel example.exe
diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
index 566a750..933370f 100644
--- a/user/bsps/bsps-aarch64.rst
+++ b/user/bsps/bsps-aarch64.rst
@@ -7,4 +7,5 @@ aarch64 (AArch64)
.. include:: aarch64/a53.rst
.. include:: aarch64/a72.rst
+.. include:: aarch64/xilinx-versal.rst
.. include:: aarch64/xilinx-zynqmp.rst
2.25.1
