[PATCH 07/10] bsps/sparc: Use rtems_interrupt_handler_install()
Wed Jun 23 06:49:33 UTC 2021
Avoid using set_vector() which depends on _ISR_Vector_table().  Prepare for a
statically initialized trap table.
Update #4458.
 bsps/sparc/erc32/clock/ckinit.c | 10 ++++++++--
 bsps/sparc/erc32/include/bsp.h  |  2 ++
 bsps/sparc/erc32/include/tm27.h | 24 +++++++++++++++++++-----
 bsps/sparc/leon2/clock/ckinit.c | 14 +++++++-------
 bsps/sparc/leon2/include/bsp.h  |  2 ++
 bsps/sparc/leon2/include/tm27.h | 24 +++++++++++++++++++-----
 bsps/sparc/leon3/include/bsp.h  |  2 ++
 bsps/sparc/leon3/include/tm27.h | 24 +++++++++++++++++++-----
 bsps/sparc/leon3/mpci/mpisr.c   |  9 +++++++--
 bsps/sparc/leon3/start/bspsmp.c | 18 +++++++++++++-----
 10 files changed, 98 insertions(+), 31 deletions(-)
diff --git a/bsps/sparc/erc32/clock/ckinit.c b/bsps/sparc/erc32/clock/ckinit.c
index 6d6a335fed..83cafb73c3 100644
--- a/bsps/sparc/erc32/clock/ckinit.c
+++ b/bsps/sparc/erc32/clock/ckinit.c
@@ -23,7 +23,7 @@
 #include <bsp.h>
-#include <bspopts.h>
+#include <rtems/irq-extension.h>
 #include <rtems/sysinit.h>
 #include <rtems/timecounter.h>
 #include <rtems/score/sparcimpl.h>
@@ -105,7 +105,13 @@ RTEMS_SYSINIT_ITEM(
 #define CLOCK_VECTOR ERC32_TRAP_TYPE( ERC32_INTERRUPT_REAL_TIME_CLOCK )
 #define Clock_driver_support_install_isr( _new ) \
-  set_vector( _new, CLOCK_VECTOR, 1 )
+  (void) rtems_interrupt_handler_install( \
+    ERC32_INTERRUPT_REAL_TIME_CLOCK, \
+    "Clock", \
+    RTEMS_INTERRUPT_SHARED, \
+    _new, \
+    NULL \
 #define Clock_driver_support_set_interrupt_affinity( _online_processors ) \
   do { \
diff --git a/bsps/sparc/erc32/include/bsp.h b/bsps/sparc/erc32/include/bsp.h
index 300202bff5..7fb2fa9d72 100644
--- a/bsps/sparc/erc32/include/bsp.h
+++ b/bsps/sparc/erc32/include/bsp.h
@@ -46,6 +46,8 @@
 extern "C" {
 #endif
+#define BSP_FEATURE_IRQ_EXTENSION
  *  BSP provides its own Idle thread body
diff --git a/bsps/sparc/erc32/include/tm27.h b/bsps/sparc/erc32/include/tm27.h
index 958036fbf0..2ed4f2b78c 100644
--- a/bsps/sparc/erc32/include/tm27.h
+++ b/bsps/sparc/erc32/include/tm27.h
@@ -58,14 +58,28 @@
 #define TEST_INTERRUPT_SOURCE ERC32_INTERRUPT_EXTERNAL_1
 #define TEST_INTERRUPT_SOURCE2 (ERC32_INTERRUPT_EXTERNAL_1+1)
-#define TEST_VECTOR ERC32_TRAP_TYPE( TEST_INTERRUPT_SOURCE )
-#define TEST_VECTOR2 ERC32_TRAP_TYPE( TEST_INTERRUPT_SOURCE2 )
 #define MUST_WAIT_FOR_INTERRUPT 1
-#define Install_tm27_vector( handler ) \
-  set_vector( (handler), TEST_VECTOR, 1 ); \
-  set_vector( (handler), TEST_VECTOR2, 1 );
+static inline void Install_tm27_vector(
+  void ( *handler )( rtems_vector_number )
+    TEST_INTERRUPT_SOURCE,
+    "tm27 low",
+    (rtems_interrupt_handler) handler,
+    NULL
+    TEST_INTERRUPT_SOURCE2,
+    "tm27 high",
+    NULL
 #define Cause_tm27_intr() \
   do { \
diff --git a/bsps/sparc/leon2/clock/ckinit.c b/bsps/sparc/leon2/clock/ckinit.c
index ba97894861..8b6ce9a00b 100644
--- a/bsps/sparc/leon2/clock/ckinit.c
+++ b/bsps/sparc/leon2/clock/ckinit.c
@@ -93,14 +93,14 @@ uint32_t _CPU_Counter_frequency(void)
   return LEON2_TIMER_1_FREQUENCY;
- *  The Real Time Clock Counter Timer uses this trap type.
-#define CLOCK_VECTOR LEON_TRAP_TYPE( LEON_INTERRUPT_TIMER1 )
+    LEON_INTERRUPT_TIMER1, \
+    "Clock", \
+    _new, \
+    NULL \
 #define Clock_driver_support_at_tick() leon2_clock_at_tick()
diff --git a/bsps/sparc/leon2/include/bsp.h b/bsps/sparc/leon2/include/bsp.h
index f97d78ba80..bdd9c1ca70 100644
--- a/bsps/sparc/leon2/include/bsp.h
+++ b/bsps/sparc/leon2/include/bsp.h
@@ -52,6 +52,8 @@ extern "C" {
 /* SPARC CPU variant: LEON2 */
 #define LEON2 1
diff --git a/bsps/sparc/leon2/include/tm27.h b/bsps/sparc/leon2/include/tm27.h
index 7b1afe96af..8d29607c86 100644
--- a/bsps/sparc/leon2/include/tm27.h
+++ b/bsps/sparc/leon2/include/tm27.h
@@ -57,14 +57,28 @@
 #else   /* use a regular asynchronous trap */
 #define TEST_INTERRUPT_SOURCE LEON_INTERRUPT_EXTERNAL_1
-#define TEST_VECTOR LEON_TRAP_TYPE( TEST_INTERRUPT_SOURCE )
 #define TEST_INTERRUPT_SOURCE2 LEON_INTERRUPT_EXTERNAL_1+1
-#define TEST_VECTOR2 LEON_TRAP_TYPE( TEST_INTERRUPT_SOURCE2 )
+    "tm27 low",
+    NULL
+    "tm27 high",
+    NULL
   do { \
diff --git a/bsps/sparc/leon3/include/bsp.h b/bsps/sparc/leon3/include/bsp.h
index 6a96b91bf6..82f1f9f8ac 100644
--- a/bsps/sparc/leon3/include/bsp.h
+++ b/bsps/sparc/leon3/include/bsp.h
 /* SPARC CPU variant: LEON3 */
 #define LEON3 1
diff --git a/bsps/sparc/leon3/include/tm27.h b/bsps/sparc/leon3/include/tm27.h
index 00921d4880..7b73bc4dbd 100644
--- a/bsps/sparc/leon3/include/tm27.h
+++ b/bsps/sparc/leon3/include/tm27.h
@@ -57,14 +57,28 @@
+    "tm27 low",
+    NULL
+    "tm27 high",
+    NULL
   do { \
diff --git a/bsps/sparc/leon3/mpci/mpisr.c b/bsps/sparc/leon3/mpci/mpisr.c
index cdf05293f1..d97b24a87c 100644
--- a/bsps/sparc/leon3/mpci/mpisr.c
+++ b/bsps/sparc/leon3/mpci/mpisr.c
@@ -45,6 +45,11 @@ void Shm_setvec( void )
    * Interrupt driven mode is not currently supported.
    * This is thought to be the interrupt to use.
-  LEON_Unmask_interrupt(LEON3_mp_irq);
-  set_vector((rtems_isr_entry) Shm_isr, LEON_TRAP_TYPE(LEON3_mp_irq), 1);
+    LEON3_mp_irq,
+    "MPCI",
+    (rtems_interrupt_handler) Shm_isr,
+    NULL
diff --git a/bsps/sparc/leon3/start/bspsmp.c b/bsps/sparc/leon3/start/bspsmp.c
index ba41a1fca1..c73c3fd5d0 100644
--- a/bsps/sparc/leon3/start/bspsmp.c
+++ b/bsps/sparc/leon3/start/bspsmp.c
@@ -18,6 +18,7 @@
 #include <bsp/fatal.h>
 #include <leon.h>
 #include <rtems/bspIo.h>
+#include <rtems/score/assert.h>
 #include <rtems/score/smpimpl.h>
@@ -28,10 +29,9 @@ uint32_t _CPU_SMP_Get_current_processor( void )
 #endif
-static rtems_isr bsp_inter_processor_interrupt(
-  rtems_vector_number vector
+static void bsp_inter_processor_interrupt( void *arg )
+  (void) arg;
   _SMP_Inter_processor_interrupt_handler(_Per_CPU_Get());
@@ -57,11 +57,19 @@ void bsp_start_on_secondary_processor(Per_CPU_Control *cpu_self)
 uint32_t _CPU_SMP_Initialize( void )
+  rtems_status_code sc;
   if ( !leon3_data_cache_snooping_enabled() )
     bsp_fatal( LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR );
-  set_vector(bsp_inter_processor_interrupt, LEON_TRAP_TYPE(LEON3_mp_irq), 1);
+  sc = rtems_interrupt_handler_install(
+    LEON3_mp_irq,
+    "IPI",
+    bsp_inter_processor_interrupt,
+    NULL
+  _Assert_Unused_variable_equals( sc, RTEMS_SUCCESSFUL );
   return leon3_get_cpu_count(LEON3_IrqCtrl_Regs);
2.26.2
