[PATCH v2 09/12] bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT
Wed Jun 23 17:45:39 UTC 2021
On 23/06/2021 18:07, Gedare Bloom wrote:
>> diff --git a/bsps/m68k/genmcf548x/irq/irq.c b/bsps/m68k/genmcf548x/irq/irq.c
>> index d010865152..547e851cdd 100644
>> --- a/bsps/m68k/genmcf548x/irq/irq.c
>> +++ b/bsps/m68k/genmcf548x/irq/irq.c
>> @@ -19,7 +19,7 @@
>>   static inline bool is_valid_vector(rtems_vector_number vector)
>>     return 1 <= vector
>> -    && vector <= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX;
>> +    && vector < (rtems_vector_number) BSP_INTERRUPT_VECTOR_COUNT;
> This one is weird. I don't know if there's an elegant solution though.
> The "BSP_INTERRUPT_VECTOR_COUNT" isn't actually the number of vectors
> in this BSP, since 0 is not a valid vector. However, I'm ok because
> BSP_INTERRUPT_VECTOR_COUNT is an upper bound on the number of vectors.
> Probably, this point needs to be documented carefully at least for
> this particular BSP.
This irq.c of this BSP is already not an elegant solution. I had to add
this hacked together glue layer to be able to use the interrupt server
for libbsd support. There is no functional change for this BSP.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
