[PATCH rtems] bsps/powerpc, bsps/shared: Move remaining legacy networking header files
Vijay Kumar Banerjee
vijay at rtems.org
Wed Jun 23 19:31:36 UTC 2021
On Wed, Jun 23, 2021 at 1:24 PM Joel Sherrill <joel at rtems.org> wrote:
> Assuming you built the bsps in question, I'm ok with this.
I tested the build and install for both the bsps involved.
> Any insight info the tftp code? Did it really need rtems_bsdnet.h?
It looks like, the tftp code uses the hostname and
rtems_bsdnet_bootp_server_address from the legacy stack. The
rtems_bsdnet.h has the extern declaration for it. I couldn't come up
with a clean solution to add the values to tftp code. Any suggestion?
Or we can make copies of this in each stack.
I'm planning to work on two different networking submodule
"net-services" and "net-drivers" for the common services and to expand
the driver support for each stack. This can shift to the services repo
later if we make copies of it as a temporary workaround.
> On Wed, Jun 23, 2021, 2:21 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> bsps/headers.am | 3 -
>> bsps/include/grlib/greth.h | 165 --
>> bsps/include/grlib/network_interface_add.h | 47 -
>> bsps/powerpc/beatnik/headers.am | 3 -
>> bsps/powerpc/beatnik/include/bsp/if_em_pub.h | 22 -
>> bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h | 30 -
>> bsps/powerpc/beatnik/include/bsp/if_mve_pub.h | 426 -----
>> bsps/shared/grlib/net/greth.c | 1663 -----------------
>> spec/build/bsps/objgrlib.yml | 2 -
>> .../build/bsps/powerpc/beatnik/bspbeatnik.yml | 3 -
>> 10 files changed, 2364 deletions(-)
>> delete mode 100644 bsps/include/grlib/greth.h
>> delete mode 100644 bsps/include/grlib/network_interface_add.h
>> delete mode 100644 bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> delete mode 100644 bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> delete mode 100644 bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> delete mode 100644 bsps/shared/grlib/net/greth.c
>> diff --git a/bsps/headers.am b/bsps/headers.am
>> index b89e5c2b28..b5821564b1 100644
>> --- a/bsps/headers.am
>> +++ b/bsps/headers.am
>> @@ -82,7 +82,6 @@ include_grlib_HEADERS += ../../bsps/include/grlib/gradcdac.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/grascs.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/grcan.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/grctm.h
>> -include_grlib_HEADERS += ../../bsps/include/grlib/greth.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/grgpio.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/griommu.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/grlib.h
>> @@ -102,7 +101,6 @@ include_grlib_HEADERS += ../../bsps/include/grlib/l2c.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/l4stat.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/mctrl.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/memscrub.h
>> -include_grlib_HEADERS += ../../bsps/include/grlib/network_interface_add.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/occan.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/pcif.h
>> include_grlib_HEADERS += ../../bsps/include/grlib/satcan.h
>> @@ -118,7 +116,6 @@ include_libchip_HEADERS += ../../bsps/include/libchip/ata.h
>> include_libchip_HEADERS += ../../bsps/include/libchip/ata_internal.h
>> include_libchip_HEADERS += ../../bsps/include/libchip/disp_hcms29xx.h
>> include_libchip_HEADERS += ../../bsps/include/libchip/ds1375-rtc.h
>> -include_libchip_HEADERS += ../../bsps/include/libchip/greth.h
>> include_libchip_HEADERS += ../../bsps/include/libchip/i2c-2b-eeprom.h
>> include_libchip_HEADERS += ../../bsps/include/libchip/i2c-ds1621.h
>> include_libchip_HEADERS += ../../bsps/include/libchip/i2c-sc620.h
>> diff --git a/bsps/include/grlib/greth.h b/bsps/include/grlib/greth.h
>> deleted file mode 100644
>> index e7970a79f7..0000000000
>> --- a/bsps/include/grlib/greth.h
>> +++ /dev/null
>> @@ -1,165 +0,0 @@
>> - * Cobham Gaisler ethernet MAC driver
>> - * adapted from Opencores driver by Marko Isomaki
>> - * The license and distribution terms for this file may be
>> - * found in found in the file LICENSE in this distribution or at
>> - * http://www.rtems.org/license/LICENSE.
>> -#ifndef __GRETH_H__
>> -#define __GRETH_H__
>> -#ifdef __cplusplus
>> -extern "C" {
>> -#endif
>> -/* Ethernet configuration registers */
>> -typedef struct _greth_regs {
>> - volatile uint32_t ctrl; /* Ctrl Register */
>> - volatile uint32_t status; /* Status Register */
>> - volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
>> - volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
>> - volatile uint32_t mdio_ctrl; /* MDIO control and status */
>> - volatile uint32_t txdesc; /* Transmit descriptor pointer */
>> - volatile uint32_t rxdesc; /* Receive descriptor pointer */
>> - volatile uint32_t edcl; /* EDCL IP register */
>> - volatile uint32_t ht_msb; /* Multicast MSB hash */
>> - volatile uint32_t ht_lsb; /* Multicast LSB hash */
>> -} greth_regs;
>> -#define GRETH_TOTAL_BD 128
>> -#define GRETH_MAXBUF_LEN 1520
>> -/* Tx BD */
>> -#define GRETH_TXD_ENABLE 0x0800 /* Tx BD Enable */
>> -#define GRETH_TXD_WRAP 0x1000 /* Tx BD Wrap (last BD) */
>> -#define GRETH_TXD_IRQ 0x2000 /* Tx BD IRQ Enable */
>> -#define GRETH_TXD_MORE 0x20000 /* Tx BD More (more descs for packet) */
>> -#define GRETH_TXD_IPCS 0x40000 /* Tx BD insert ip chksum */
>> -#define GRETH_TXD_TCPCS 0x80000 /* Tx BD insert tcp chksum */
>> -#define GRETH_TXD_UDPCS 0x100000 /* Tx BD insert udp chksum */
>> -#define GRETH_TXD_UNDERRUN 0x4000 /* Tx BD Underrun Status */
>> -#define GRETH_TXD_RETLIM 0x8000 /* Tx BD Retransmission Limit Status */
>> -#define GRETH_TXD_LATECOL 0x10000 /* Tx BD Late Collision */
>> -#define GRETH_TXD_STATS (GRETH_TXD_UNDERRUN | \
>> - GRETH_TXD_RETLIM | \
>> - GRETH_TXD_LATECOL)
>> -#define GRETH_TXD_CS (GRETH_TXD_IPCS | \
>> - GRETH_TXD_TCPCS | \
>> - GRETH_TXD_UDPCS)
>> -/* Rx BD */
>> -#define GRETH_RXD_ENABLE 0x0800 /* Rx BD Enable */
>> -#define GRETH_RXD_WRAP 0x1000 /* Rx BD Wrap (last BD) */
>> -#define GRETH_RXD_IRQ 0x2000 /* Rx BD IRQ Enable */
>> -#define GRETH_RXD_DRIBBLE 0x4000 /* Rx BD Dribble Nibble Status */
>> -#define GRETH_RXD_TOOLONG 0x8000 /* Rx BD Too Long Status */
>> -#define GRETH_RXD_CRCERR 0x10000 /* Rx BD CRC Error Status */
>> -#define GRETH_RXD_OVERRUN 0x20000 /* Rx BD Overrun Status */
>> -#define GRETH_RXD_LENERR 0x40000 /* Rx BD Length Error */
>> -#define GRETH_RXD_ID 0x40000 /* Rx BD IP Detected */
>> -#define GRETH_RXD_IR 0x40000 /* Rx BD IP Chksum Error */
>> -#define GRETH_RXD_UD 0x40000 /* Rx BD UDP Detected*/
>> -#define GRETH_RXD_UR 0x40000 /* Rx BD UDP Chksum Error */
>> -#define GRETH_RXD_TD 0x40000 /* Rx BD TCP Detected */
>> -#define GRETH_RXD_TR 0x40000 /* Rx BD TCP Chksum Error */
>> -#define GRETH_RXD_STATS (GRETH_RXD_OVERRUN | \
>> - GRETH_RXD_DRIBBLE | \
>> - GRETH_RXD_TOOLONG | \
>> - GRETH_RXD_CRCERR)
>> -/* CTRL Register */
>> -#define GRETH_CTRL_TXEN 0x00000001 /* Transmit Enable */
>> -#define GRETH_CTRL_RXEN 0x00000002 /* Receive Enable */
>> -#define GRETH_CTRL_TXIRQ 0x00000004 /* Transmit Enable */
>> -#define GRETH_CTRL_RXIRQ 0x00000008 /* Receive Enable */
>> -#define GRETH_CTRL_FULLD 0x00000010 /* Full Duplex */
>> -#define GRETH_CTRL_PRO 0x00000020 /* Promiscuous (receive all) */
>> -#define GRETH_CTRL_RST 0x00000040 /* Reset MAC */
>> -#define GRETH_CTRL_SP 0x00000080 /* 100MBit speed mode */
>> -#define GRETH_CTRL_GB 0x00000100 /* 1GBit speed mode */
>> -#define GRETH_CTRL_MCE 0x00000800 /* Multicast Enable */
>> -#define GRETH_CTRL_DD 0x00001000 /* Disable EDCL Duplex Detection */
>> -#define GRETH_CTRL_ED 0x00004000 /* EDCL Disable */
>> -#define GRETH_CTRL_MC 0x02000000 /* Multicast available */
>> -#define GRETH_CTRL_ME 0x04000000 /* MDIO interrupts enabled */
>> -#define GRETH_CTRL_GA 0x08000000 /* Gigabit MAC available */
>> -/* Status Register */
>> -#define GRETH_STATUS_RXERR 0x00000001 /* Receive Error */
>> -#define GRETH_STATUS_TXERR 0x00000002 /* Transmit Error IRQ */
>> -#define GRETH_STATUS_RXIRQ 0x00000004 /* Receive Frame IRQ */
>> -#define GRETH_STATUS_TXIRQ 0x00000008 /* Transmit Error IRQ */
>> -#define GRETH_STATUS_RXAHBERR 0x00000010 /* Receiver AHB Error */
>> -#define GRETH_STATUS_TXAHBERR 0x00000020 /* Transmitter AHB Error */
>> -#define GRETH_STATUS_NRD 0x0f000000 /* Number of descriptors */
>> -/* MDIO Control */
>> -#define GRETH_MDIO_WRITE 0x00000001 /* MDIO Write */
>> -#define GRETH_MDIO_READ 0x00000002 /* MDIO Read */
>> -#define GRETH_MDIO_LINKFAIL 0x00000004 /* MDIO Link failed */
>> -#define GRETH_MDIO_BUSY 0x00000008 /* MDIO Link Busy */
>> -#define GRETH_MDIO_REGADR 0x000007C0 /* Register Address */
>> -#define GRETH_MDIO_PHYADR 0x0000F800 /* PHY address */
>> -#define GRETH_MDIO_DATA 0xFFFF0000 /* MDIO DATA */
>> -/* MII registers */
>> -#define GRETH_MII_EXTADV_1000FD 0x00000200
>> -#define GRETH_MII_EXTADV_1000HD 0x00000100
>> -#define GRETH_MII_EXTPRT_1000FD 0x00000800
>> -#define GRETH_MII_EXTPRT_1000HD 0x00000400
>> -#define GRETH_MII_100T4 0x00000200
>> -#define GRETH_MII_100TXFD 0x00000100
>> -#define GRETH_MII_100TXHD 0x00000080
>> -#define GRETH_MII_10FD 0x00000040
>> -#define GRETH_MII_10HD 0x00000020
>> -/* Attach routine */
>> -void greth_register_drv(void);
>> -/* PHY data */
>> -struct phy_device_info
>> - int vendor;
>> - int device;
>> - int rev;
>> - int adv;
>> - int part;
>> - int extadv;
>> - int extpart;
>> -/* Limit speed modes advertised during auto-negotiation */
>> -#define GRETH_ADV_10_HD 0x0001
>> -#define GRETH_ADV_10_FD 0x0002
>> -#define GRETH_ADV_100_HD 0x0004
>> -#define GRETH_ADV_100_FD 0x0008
>> -#define GRETH_ADV_1000_HD 0x0010
>> -#define GRETH_ADV_1000_FD 0x0020
>> -#define GRETH_ADV_ALL 0x003f
>> -#ifdef CPU_U32_FIX
>> -void ipalign(struct mbuf *m);
>> -#endif
>> -#ifdef __cplusplus
>> -#endif
>> -#endif
>> diff --git a/bsps/include/grlib/network_interface_add.h b/bsps/include/grlib/network_interface_add.h
>> index b04a96f003..0000000000
>> --- a/bsps/include/grlib/network_interface_add.h
>> +++ /dev/null
>> @@ -1,47 +0,0 @@
>> -/* Network interface register help function
>> - * COPYRIGHT (c) 2008.
>> - * Cobham Gaisler AB.
>> - * This function adds a network interface to the
>> - * rtems_bsdnet_config.ifconfig linked list of interfaces.
>> - * The interface configuration is taken from the user defined
>> - * array interface_configs. This function is useful for PnP
>> - * systems when an unknown number of interfaces are available.
>> -#ifndef __NETWORK_INTERFACE_ADD_H__
>> -#define __NETWORK_INTERFACE_ADD_H__
>> -#include <rtems/rtems_bsdnet.h>
>> -#ifdef __cplusplus
>> -extern "C" {
>> -#endif
>> -/* Interface configuration description */
>> -struct ethernet_config {
>> - char *ip_addr; /* IP address */
>> - char *ip_netmask; /* IP Netmask */
>> - char eth_adr[6]; /* Ethernet hardware MAC address */
>> -/* Array with configurations for all interfaces in the system
>> - * Must be defined by the user.
>> -extern struct ethernet_config interface_configs[];
>> -/* Routine adding interface to rtems_bsdnet_config.ifconfig linked
>> - * list of interfaces.
>> -int network_interface_add(struct rtems_bsdnet_ifconfig *interface);
>> -#ifdef __cplusplus
>> -#endif
>> -#endif /* _RTEMS_NETWORKCONFIG_H_ */
>> diff --git a/bsps/powerpc/beatnik/headers.am b/bsps/powerpc/beatnik/headers.am
>> index 36df3cd759..364ea222a8 100644
>> --- a/bsps/powerpc/beatnik/headers.am
>> +++ b/bsps/powerpc/beatnik/headers.am
>> @@ -16,7 +16,4 @@ include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gti2cr
>> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gtintrreg.h
>> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gtpcireg.h
>> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gtreg.h
>> -include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> -include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> -include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/irq.h
>> diff --git a/bsps/powerpc/beatnik/include/bsp/if_em_pub.h b/bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> index eb970e465b..0000000000
>> --- a/bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> +++ /dev/null
>> @@ -1,22 +0,0 @@
>> -#ifndef RTEMS_BSDNET_IF_EM_PUBLIC_SYMBOLS_H
>> -#define RTEMS_BSDNET_IF_EM_PUBLIC_SYMBOLS_H
>> -#include <rtems.h>
>> -#include <bsp/early_enet_link_status.h>
>> -#ifdef __cplusplus
>> - extern "C" {
>> -#endif
>> -extern int rtems_em_attach(struct rtems_bsdnet_ifconfig *, int);
>> -extern int rtems_em_pci_setup(int);
>> -extern rtems_bsdnet_early_link_check_ops rtems_em_early_link_check_ops;
>> -#ifdef __cplusplus
>> -#endif
>> -#endif
>> diff --git a/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h b/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> index 8ea849efb1..0000000000
>> --- a/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> +++ /dev/null
>> @@ -1,30 +0,0 @@
>> -#ifndef RTEMS_BSDNET_IF_GFE_PUBLIC_SYMBOLS_H
>> -#define RTEMS_BSDNET_IF_GFE_PUBLIC_SYMBOLS_H
>> -#include <rtems.h>
>> -#include <net/ethernet.h>
>> -#ifdef __cplusplus
>> - extern "C" {
>> -#endif
>> -extern int
>> -rtems_gfe_attach(struct rtems_bsdnet_ifconfig *, int);
>> -/* enet_addr must be 6 bytes long */
>> -int
>> -rtems_gfe_setup(int unit, char *enet_addr, uint32_t base_addr);
>> -rtems_gfe_early_link_check_ops;
>> -#ifdef __cplusplus
>> -#endif
>> -#endif
>> diff --git a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h b/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> index 46cc4ccd23..0000000000
>> --- a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> +++ /dev/null
>> @@ -1,426 +0,0 @@
>> -#ifndef RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
>> -#define RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
>> - * Authorship
>> - * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
>> - * created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
>> - * Stanford Linear Accelerator Center, Stanford University.
>> - * Acknowledgement of sponsorship
>> - * The 'beatnik' BSP was produced by
>> - * the Stanford Linear Accelerator Center, Stanford University,
>> - * under Contract DE-AC03-76SFO0515 with the Department of Energy.
>> - * Government disclaimer of liability
>> - * Neither the United States nor the United States Department of Energy,
>> - * nor any of their employees, makes any warranty, express or implied, or
>> - * assumes any legal liability or responsibility for the accuracy,
>> - * completeness, or usefulness of any data, apparatus, product, or process
>> - * disclosed, or represents that its use would not infringe privately owned
>> - * rights.
>> - * Stanford disclaimer of liability
>> - * Stanford University makes no representations or warranties, express or
>> - * implied, nor assumes any liability for the use of this software.
>> - * Stanford disclaimer of copyright
>> - * Stanford University, owner of the copyright, hereby disclaims its
>> - * copyright and all other rights in this software. Hence, anyone may
>> - * freely use it for any purpose without restriction.
>> - * Maintenance of notices
>> - * In the interest of clarity regarding the origin and status of this
>> - * SLAC software, this and all the preceding Stanford University notices
>> - * are to remain affixed to any copy or derivative of this software made
>> - * or distributed by the recipient and are to be affixed to any copy of
>> - * software made or distributed by the recipient that contains a copy or
>> - * derivative of this software.
>> - * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
>> -#include <rtems.h>
>> -#include <stdint.h>
>> -#ifdef __cplusplus
>> - extern "C" {
>> -#endif
>> -extern int rtems_mve_attach(struct rtems_bsdnet_ifconfig *, int);
>> -extern rtems_bsdnet_early_link_check_ops rtems_mve_early_link_check_ops;
>> -/* Low-level Driver API.
>> - * This provides driver access to applications that want to use e.g., the second
>> - * ethernet interface w/o running the BSD TCP/IP stack.
>> -/* Opaque handle */
>> -struct mveth_private;
>> -/* Direct assignment of MVE flags to user API relies on irqs and x-irqs not overlapping */
>> -#define BSP_MVE_IRQ_RX (1<<2)
>> -#define BSP_MVE_IRQ_TX (1<<0)
>> -#define BSP_MVE_IRQ_LINK (1<<16)
>> -/* Setup an interface.
>> - * Allocates resources for descriptor rings and sets up the driver software structure.
>> - * Arguments:
>> - * unit:
>> - * interface # (1..2). The interface must not be attached to BSD.
>> - * driver_tid:
>> - * ISR posts RTEMS event # ('unit' - 1) to task with ID 'driver_tid' and disables interrupts
>> - * from this interface.
>> - * void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred):
>> - * Pointer to user-supplied callback to release a buffer that had been sent
>> - * by BSP_mve_send_buf() earlier. The callback is passed 'cleanup_txbuf_arg'
>> - * and a flag indicating whether the send had been successful.
>> - * The driver no longer accesses 'user_buf' after invoking this callback.
>> - * CONTEXT: This callback is executed either by BSP_mve_swipe_tx() or
>> - * BSP_mve_send_buf(), BSP_mve_init_hw(), BSP_mve_stop_hw() (the latter
>> - * ones calling BSP_mve_swipe_tx()).
>> - * void *cleanup_txbuf_arg:
>> - * Closure argument that is passed on to 'cleanup_txbuf()' callback;
>> - * void *(*alloc_rxbuf)(int *p_size, unsigned long *p_data_addr),
>> - * Pointer to user-supplied callback to allocate a buffer for subsequent
>> - * insertion into the RX ring by the driver.
>> - * RETURNS: opaque handle to the buffer (which may be a more complex object
>> - * such as an 'mbuf'). The handle is not used by the driver directly
>> - * but passed back to the 'consume_rxbuf()' callback.
>> - * Size of the available data area and pointer to buffer's data area
>> - * in '*psize' and '*p_data_area', respectively.
>> - * If no buffer is available, this routine should return NULL in which
>> - * case the driver drops the last packet and re-uses the last buffer
>> - * instead of handing it out to 'consume_rxbuf()'.
>> - * CONTEXT: Called when initializing the RX ring (BSP_mve_init_hw()) or when
>> - * swiping it (BSP_mve_swipe_rx()).
>> - * void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len);
>> - * Pointer to user-supplied callback to pass a received buffer back to
>> - * the user. The driver no longer accesses the buffer after invoking this
>> - * callback (with 'len'>0, see below). 'user_buf' is the buffer handle
>> - * previously generated by 'alloc_rxbuf()'.
>> - * The callback is passed 'cleanup_rxbuf_arg' and a 'len'
>> - * argument giving the number of bytes that were received.
>> - * 'len' may be <=0 in which case the 'user_buf' argument is NULL.
>> - * 'len' == 0 means that the last 'alloc_rxbuf()' had failed,
>> - * 'len' < 0 indicates a receiver error. In both cases, the last packet
>> - * was dropped/missed and the last buffer will be re-used by the driver.
>> - * NOTE: the data are 'prefixed' with two bytes, i.e., the ethernet packet header
>> - * is stored at offset 2 in the buffer's data area. Also, the FCS (4 bytes)
>> - * is appended. 'len' accounts for both.
>> - * CONTEXT: Called from BSP_mve_swipe_rx().
>> - * void *cleanup_rxbuf_arg:
>> - * Closure argument that is passed on to 'consume_rxbuf()' callback;
>> - * rx_ring_size, tx_ring_size:
>> - * How many big to make the RX and TX descriptor rings. Note that the sizes
>> - * may be 0 in which case a reasonable default will be used.
>> - * If either ring size is < 0 then the RX or TX will be disabled.
>> - * Note that it is illegal in this case to use BSP_mve_swipe_rx() or
>> - * BSP_mve_swipe_tx(), respectively.
>> - * irq_mask:
>> - * Interrupts to enable. OR of flags from above.
>> -struct mveth_private *
>> -BSP_mve_setup(
>> - int unit,
>> - rtems_id driver_tid,
>> - void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
>> - void *cleanup_txbuf_arg,
>> - void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
>> - void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len),
>> - void *consume_rxbuf_arg,
>> - int rx_ring_size,
>> - int tx_ring_size,
>> - int irq_mask
>> - * Alternate 'setup' routine allowing the user to install an ISR rather
>> - * than a task ID.
>> - * All parameters (other than 'isr' / 'isr_arg') and the return value
>> - * are identical to the BSP_mve_setup() entry point.
>> -BSP_mve_setup_1(
>> - int unit,
>> - void (*isr)(void *isr_arg),
>> - void *isr_arg,
>> - int rx_ring_size,
>> - int tx_ring_size,
>> - int irq_mask
>> - * Initialize interface hardware
>> - * 'mp' handle obtained by from BSP_mve_setup().
>> - * 'promisc' whether to set promiscuous flag.
>> - * 'enaddr' pointer to six bytes with MAC address. Read
>> - * from the device if NULL.
>> - * Note: Multicast filters are cleared by this routine.
>> - * However, in promiscuous mode the mcast filters
>> - * are programmed to accept all multicast frames.
>> -void
>> -BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
>> - * Clear multicast hash filter. No multicast frames are accepted
>> - * after executing this routine (unless the hardware was initialized
>> - * in 'promiscuous' mode).
>> -void
>> -BSP_mve_mcast_filter_clear(struct mveth_private *mp);
>> - * Program multicast filter to accept all multicast frames
>> -void
>> -BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
>> - * Add a MAC address to the multicast filter.
>> - * Existing entries are not changed but note that
>> - * the filter is imperfect, i.e., multiple MAC addresses
>> - * may alias to a single filter entry. Hence software
>> - * filtering must still be performed.
>> - * If a higher-level driver implements IP multicasting
>> - * then multiple IP addresses may alias to the same MAC
>> - * address. This driver maintains a 'reference-count'
>> - * which is incremented every time the same MAC-address
>> - * is passed to this routine; the address is only removed
>> - * from the filter if BSP_mve_mcast_filter_accept_del()
>> - * is called the same number of times (or by BSP_mve_mcast_filter_clear).
>> -void
>> -BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
>> - * Remove a MAC address from the multicast filter.
>> - * This routine decrements the reference count of the given
>> - * MAC-address and removes it from the filter once the
>> - * count reaches zero.
>> -void
>> -BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
>> - * Shutdown hardware and clean out the rings
>> -void
>> -BSP_mve_stop_hw(struct mveth_private *mp);
>> -/* calls BSP_mve_stop_hw(), releases all resources and marks the interface
>> - * as unused.
>> - * RETURNS 0 on success, nonzero on failure.
>> - * NOTE: the handle MUST NOT be used after successful execution of this
>> - * routine.
>> -int
>> -BSP_mve_detach(struct mveth_private *mp);
>> -int
>> -BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len,
>> - void *data_p, int d_len);
>> - * Enqueue a mbuf chain or a raw data buffer for transmission;
>> - * RETURN: #bytes sent or -1 if there are not enough free descriptors
>> - * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
>> - * OTOH, a raw data packet (or a different type of buffer)
>> - * may be send (non-BSD driver) by pointing data_p to the start of
>> - * the data and passing 'len' > 0.
>> - * 'm_head' is passed back to the 'cleanup_txbuf()' callback.
>> - * Comments: software cache-flushing incurs a penalty if the
>> - * packet cannot be queued since it is flushed anyways.
>> - * The algorithm is slightly more efficient in the normal
>> - * case, though.
>> - * RETURNS: # bytes enqueued to device for transmission or -1 if no
>> - * space in the TX ring was available.
>> -int
>> -BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len);
>> -/* Descriptor scavenger; cleanup the TX ring, passing all buffers
>> - * that have been sent to the cleanup_tx() callback.
>> - * This routine is called from BSP_mve_send_buf(), BSP_mve_init_hw(),
>> - * BSP_mve_stop_hw().
>> - * RETURNS: number of buffers processed.
>> -int
>> -BSP_mve_swipe_tx(struct mveth_private *mp);
>> -/* Retrieve all received buffers from the RX ring, replacing them
>> - * by fresh ones (obtained from the alloc_rxbuf() callback). The
>> - * received buffers are passed to consume_rxbuf().
>> -int
>> -BSP_mve_swipe_rx(struct mveth_private *mp);
>> -/* read ethernet address from hw to buffer */
>> -void
>> -BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *eaddr);
>> -/* read/write media word.
>> - * 'cmd': can be SIOCGIFMEDIA, SIOCSIFMEDIA, 0 or 1. The latter
>> - * are aliased to the former for convenience.
>> - * 'parg': pointer to media word.
>> - * RETURNS: 0 on success, nonzero on error
>> - * NOTE: This routine is thread-safe.
>> -int
>> -BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg);
>> -/* Interrupt related routines */
>> -/* Note: the BSP_mve_enable/disable/ack_irqs() entry points
>> - * are deprecated.
>> - * The newer API where the user passes a mask allows
>> - * for more selective control.
>> -/* Enable all supported interrupts at device */
>> -void
>> -BSP_mve_enable_irqs(struct mveth_private *mp);
>> -/* Disable all supported interrupts at device */
>> -void
>> -BSP_mve_disable_irqs(struct mveth_private *mp);
>> -/* Acknowledge (and clear) all supported interrupts.
>> - * RETURNS: interrupts that were raised.
>> -uint32_t
>> -BSP_mve_ack_irqs(struct mveth_private *mp);
>> -/* Enable interrupts included in 'mask' (leaving
>> - * already enabled interrupts on). If the mask
>> - * includes bits that were not passed to the 'setup'
>> - * routine then the behavior is undefined.
>> -void
>> -BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
>> -/* Disable interrupts included in 'mask' (leaving
>> - * other ones that are currently enabled on). If the
>> - * mask includes bits that were not passed to the 'setup'
>> - * RETURNS: Bitmask of interrupts that were enabled upon entry
>> - * into this routine. This can be used to restore the
>> - * previous state.
>> -uint32_t
>> -BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
>> -/* Acknowledge and clear selected interrupts.
>> - * RETURNS: All pending interrupts.
>> - * NOTE: Only pending interrupts contained in 'mask'
>> - * are cleared. Others are left pending.
>> - * This routine can be used to check for pending
>> - * interrupts (pass mask == 0) or to clear all
>> - * interrupts (pass mask == -1).
>> -uint32_t
>> -BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
>> -/* If the PHY link status changes then some
>> - * internal settings in the ethernet controller's
>> - * serial port need to be updated to match the
>> - * PHY settings. Use this routine to perform the
>> - * necessary steps after a link change has been
>> - * detected.
>> - * RETURNS: 0 on success, -1 if the PHY state
>> - * could not be determined.
>> - * The current state of the media as read
>> - * by BSP_mve_media_ioctl() is returned in
>> - * *pmedia.
>> - * NOTE: This routine calls BSP_mve_media_ioctl().
>> -int
>> -BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia);
>> -/* Retrieve the driver daemon TID that was passed to
>> - * BSP_mve_setup().
>> -rtems_id
>> -BSP_mve_get_tid(struct mveth_private *mp);
>> -/* Dump statistics to file (stdout if NULL)
>> - * NOTE: this routine is not thread safe
>> -void
>> -BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
>> - * Example driver task loop (note: no synchronization of
>> - * buffer access shown!).
>> - * RTEMS_EVENTx = 0,1 or 2 depending on IF unit.
>> - * / * setup (obtain handle) and initialize hw here * /
>> - * do {
>> - * / * ISR disables IRQs and posts event * /
>> - * rtems_event_receive( RTEMS_EVENTx, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
>> - * irqs = BSP_mve_ack_irqs(handle);
>> - * if ( irqs & BSP_MVE_IRQ_TX ) {
>> - * BSP_mve_swipe_tx(handle); / * cleanup_txbuf() callback executed * /
>> - * if ( irqs & BSP_MVE_IRQ_RX ) {
>> - * BSP_mve_swipe_rx(handle); / * alloc_rxbuf() and consume_rxbuf() executed * /
>> - * if ( irqs & BSP_MVE_IRQ_LINK ) {
>> - * / * update serial port settings from current link status * /
>> - * BSP_mve_ack_link_chg(handle, 0);
>> - * BSP_mve_enable_irqs(handle);
>> - * } while (1);
>> -#ifdef __cplusplus
>> -#endif
>> -#endif
>> diff --git a/bsps/shared/grlib/net/greth.c b/bsps/shared/grlib/net/greth.c
>> index 84efcd74ab..0000000000
>> --- a/bsps/shared/grlib/net/greth.c
>> +++ /dev/null
>> @@ -1,1663 +0,0 @@
>> - * Gaisler Research ethernet MAC driver
>> - * 2008-12-10, Converted to driver manager and added support for
>> - * multiple GRETH cores. <daniel at gaisler.com>
>> - * 2007-09-07, Ported GBIT support from 4.6.5
>> -#include <machine/rtems-bsd-kernel-space.h>
>> -#include <rtems.h>
>> -#define CPU_U32_FIX
>> -#include <bsp.h>
>> -#ifdef GRETH_SUPPORTED
>> -#include <inttypes.h>
>> -#include <errno.h>
>> -#include <rtems/bspIo.h>
>> -#include <stdlib.h>
>> -#include <stdio.h>
>> -#include <string.h>
>> -#include <stdarg.h>
>> -#include <rtems/error.h>
>> -#include <grlib/greth.h>
>> -#include <drvmgr/drvmgr.h>
>> -#include <grlib/ambapp_bus.h>
>> -#include <grlib/ambapp.h>
>> -#include <sys/param.h>
>> -#include <sys/mbuf.h>
>> -#include <sys/socket.h>
>> -#include <sys/sockio.h>
>> -#include <net/if.h>
>> -#include <netinet/in.h>
>> -#include <netinet/if_ether.h>
>> -#ifdef malloc
>> -#undef malloc
>> -#endif
>> -#ifdef free
>> -#undef free
>> -#endif
>> -#include <grlib/grlib_impl.h>
>> -#if defined(__m68k__)
>> -extern m68k_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
>> -#else
>> -extern rtems_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
>> -#endif
>> -/* #define GRETH_DEBUG */
>> -#ifdef GRETH_DEBUG
>> -#define DBG(args...) printk(args)
>> -#else
>> -#endif
>> -/* #define GRETH_DEBUG_MII */
>> -#ifdef GRETH_DEBUG_MII
>> -#define MIIDBG(args...) printk(args)
>> -#else
>> -#endif
>> -#ifdef CPU_U32_FIX
>> -extern void ipalign(struct mbuf *m);
>> -#endif
>> -/* Used when reading from memory written by GRETH DMA unit */
>> -#ifndef GRETH_MEM_LOAD
>> -#define GRETH_MEM_LOAD(addr) (*(volatile unsigned int *)(addr))
>> -#endif
>> - * Number of OCs supported by this driver
>> -#define NOCDRIVER 1
>> - * Receive buffer size -- Allow for a full ethernet packet including CRC
>> -#define RBUF_SIZE 1518
>> -#define ET_MINLEN 64 /* minimum message length */
>> - * RTEMS event used by interrupt handler to signal driver tasks.
>> - * This must not be any of the events used by the network task synchronization.
>> -#define INTERRUPT_EVENT RTEMS_EVENT_1
>> - * RTEMS event used to start transmit daemon.
>> - * This must not be the same as INTERRUPT_EVENT.
>> -#define START_TRANSMIT_EVENT RTEMS_EVENT_2
>> - /* event to send when tx buffers become available */
>> -#define GRETH_TX_WAIT_EVENT RTEMS_EVENT_3
>> -#if (MCLBYTES < RBUF_SIZE)
>> -# error "Driver must have MCLBYTES > RBUF_SIZE"
>> -#endif
>> -/* 4s Autonegotiation Timeout */
>> -#ifndef GRETH_AUTONEGO_TIMEOUT_MS
>> -#define GRETH_AUTONEGO_TIMEOUT_MS 4000
>> -#endif
>> -const struct timespec greth_tan = {
>> - GRETH_AUTONEGO_TIMEOUT_MS/1000,
>> - (GRETH_AUTONEGO_TIMEOUT_MS % 1000) * 1000000
>> -/* For optimizing the autonegotiation time */
>> -#define GRETH_AUTONEGO_PRINT_TIME
>> -/* Ethernet buffer descriptor */
>> -typedef struct _greth_rxtxdesc {
>> - volatile uint32_t ctrl; /* Length and status */
>> - uint32_t *addr; /* Buffer pointer */
>> -} greth_rxtxdesc;
>> - * Per-device data
>> -struct greth_softc
>> - struct arpcom arpcom;
>> - struct drvmgr_dev *dev; /* Driver manager device */
>> - char devName[32];
>> - greth_regs *regs;
>> - int minor;
>> - int phyaddr; /* PHY Address configured by user (or -1 to autodetect) */
>> - unsigned int edcl_dis;
>> - int greth_rst;
>> - int acceptBroadcast;
>> - rtems_id daemonTid;
>> - unsigned int tx_ptr;
>> - unsigned int tx_dptr;
>> - unsigned int tx_cnt;
>> - unsigned int rx_ptr;
>> - unsigned int txbufs;
>> - unsigned int rxbufs;
>> - greth_rxtxdesc *txdesc;
>> - greth_rxtxdesc *rxdesc;
>> - unsigned int txdesc_remote;
>> - unsigned int rxdesc_remote;
>> - struct mbuf **rxmbuf;
>> - struct mbuf **txmbuf;
>> - rtems_vector_number vector;
>> - /* TX descriptor interrupt generation */
>> - int tx_int_gen;
>> - int tx_int_gen_cur;
>> - struct mbuf *next_tx_mbuf;
>> - int max_fragsize;
>> - /*Status*/
>> - struct phy_device_info phydev;
>> - int phy_read_access;
>> - int phy_write_access;
>> - int fd;
>> - int sp;
>> - int gb;
>> - int gbit_mac;
>> - int auto_neg;
>> - unsigned int advmodes; /* advertise ethernet speed modes. 0 = all modes. */
>> - struct timespec auto_neg_time;
>> - int mc_available;
>> - int num_descs;
>> - * Statistics
>> - unsigned long rxInterrupts;
>> - unsigned long rxPackets;
>> - unsigned long rxLengthError;
>> - unsigned long rxNonOctet;
>> - unsigned long rxBadCRC;
>> - unsigned long rxOverrun;
>> - unsigned long txInterrupts;
>> - unsigned long txDeferred;
>> - unsigned long txHeartbeat;
>> - unsigned long txLateCollision;
>> - unsigned long txRetryLimit;
>> - unsigned long txUnderrun;
>> - /* Spin-lock ISR protection */
>> - SPIN_DECLARE(devlock);
>> -int greth_process_tx_gbit(struct greth_softc *sc);
>> -int greth_process_tx(struct greth_softc *sc);
>> -static char *almalloc(int sz, int alignment)
>> - char *tmp;
>> - tmp = grlib_calloc(1, sz + (alignment-1));
>> - tmp = (char *) (((int)tmp+alignment) & ~(alignment -1));
>> - return(tmp);
>> -/* GRETH interrupt handler */
>> -static void greth_interrupt (void *arg)
>> - uint32_t status;
>> - uint32_t ctrl;
>> - rtems_event_set events = 0;
>> - struct greth_softc *greth = arg;
>> - SPIN_ISR_IRQFLAGS(flags);
>> - /* read and clear interrupt cause */
>> - status = greth->regs->status;
>> - greth->regs->status = status;
>> - SPIN_LOCK(&greth->devlock, flags);
>> - ctrl = greth->regs->ctrl;
>> - /* Frame received? */
>> - if ((ctrl & GRETH_CTRL_RXIRQ) && (status & (GRETH_STATUS_RXERR | GRETH_STATUS_RXIRQ)))
>> - greth->rxInterrupts++;
>> - /* Stop RX-Error and RX-Packet interrupts */
>> - ctrl &= ~GRETH_CTRL_RXIRQ;
>> - events |= INTERRUPT_EVENT;
>> - if ( (ctrl & GRETH_CTRL_TXIRQ) && (status & (GRETH_STATUS_TXERR | GRETH_STATUS_TXIRQ)) )
>> - greth->txInterrupts++;
>> - ctrl &= ~GRETH_CTRL_TXIRQ;
>> - events |= GRETH_TX_WAIT_EVENT;
>> - /* Clear interrupt sources */
>> - greth->regs->ctrl = ctrl;
>> - SPIN_UNLOCK(&greth->devlock, flags);
>> - /* Send the event(s) */
>> - if ( events )
>> - rtems_bsdnet_event_send(greth->daemonTid, events);
>> -static uint32_t read_mii(struct greth_softc *sc, uint32_t phy_addr, uint32_t reg_addr)
>> - sc->phy_read_access++;
>> - while (sc->regs->mdio_ctrl & GRETH_MDIO_BUSY) {}
>> - sc->regs->mdio_ctrl = (phy_addr << 11) | (reg_addr << 6) | GRETH_MDIO_READ;
>> - if (!(sc->regs->mdio_ctrl & GRETH_MDIO_LINKFAIL)) {
>> - MIIDBG("greth%d: mii read[%d] OK to %" PRIx32 ".%" PRIx32
>> - " (0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
>> - sc->minor, sc->phy_read_access, phy_addr, reg_addr,
>> - sc->regs->ctrl, sc->regs->mdio_ctrl);
>> - return((sc->regs->mdio_ctrl >> 16) & 0xFFFF);
>> - } else {
>> - printf("greth%d: mii read[%d] failed to %" PRIx32 ".%" PRIx32
>> - return (0xffff);
>> -static void write_mii(struct greth_softc *sc, uint32_t phy_addr, uint32_t reg_addr, uint32_t data)
>> - sc->phy_write_access++;
>> - ((data & 0xFFFF) << 16) | (phy_addr << 11) | (reg_addr << 6) | GRETH_MDIO_WRITE;
>> - MIIDBG("greth%d: mii write[%d] OK to to %" PRIx32 ".%" PRIx32
>> - "(0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
>> - sc->minor, sc->phy_write_access, phy_addr, reg_addr,
>> - } else {
>> - printf("greth%d: mii write[%d] failed to to %" PRIx32 ".%" PRIx32
>> -static void print_init_info(struct greth_softc *sc)
>> - printf("greth: driver attached\n");
>> - if ( sc->auto_neg == -1 ){
>> - printf("Auto negotiation timed out. Selecting default config\n");
>> - printf("**** PHY ****\n");
>> - printf("Vendor: %x Device: %x Revision: %d\n",sc->phydev.vendor, sc->phydev.device, sc->phydev.rev);
>> - printf("Current Operating Mode: ");
>> - if (sc->gb) {
>> - printf("1000 Mbit ");
>> - } else if (sc->sp) {
>> - printf("100 Mbit ");
>> - } else {
>> - printf("10 Mbit ");
>> - if (sc->fd) {
>> - printf("Full Duplex\n");
>> - } else {
>> - printf("Half Duplex\n");
>> -#ifdef GRETH_AUTONEGO_PRINT_TIME
>> - if ( sc->auto_neg ) {
>> - printf("Autonegotiation Time: %" PRIdMAX "ms\n",
>> - (intmax_t)sc->auto_neg_time.tv_sec * 1000 +
>> - sc->auto_neg_time.tv_nsec / 1000000);
>> -#endif
>> - * Generates the hash words based on CRCs of the enabled MAC addresses that are
>> - * allowed to be received. The allowed MAC addresses are maintained in a linked
>> - * "multi-cast" list available in the arpcom structure.
>> - * Returns the number of MAC addresses that were processed (in the list)
>> -static int
>> -greth_mac_filter_calc(struct arpcom *ac, uint32_t *msb, uint32_t *lsb)
>> - struct ether_multistep step;
>> - struct ether_multi *enm;
>> - int cnt = 0;
>> - uint32_t crc, htindex, ht[2] = {0, 0};
>> - /* Go through the Ethernet Multicast addresses one by one and add their
>> - * CRC contribution to the MAC filter.
>> - ETHER_FIRST_MULTI(step, ac, enm);
>> - while (enm) {
>> - crc = ether_crc32_be((uint8_t *)enm->enm_addrlo, 6);
>> - htindex = crc & 0x3f;
>> - ht[htindex >> 5] |= (1 << (htindex & 0x1F));
>> - cnt++;
>> - ETHER_NEXT_MULTI(step, enm);
>> - if (cnt > 0) {
>> - *msb = ht[1];
>> - *lsb = ht[0];
>> - return cnt;
>> - * Initialize the ethernet hardware
>> -static int greth_mac_filter_set(struct greth_softc *sc)
>> - struct ifnet *ifp = &sc->arpcom.ac_if;
>> - uint32_t hash_msb, hash_lsb, ctrl;
>> - SPIN_IRQFLAGS(flags);
>> - hash_msb = 0;
>> - hash_lsb = 0;
>> - ctrl = 0;
>> - if (ifp->if_flags & IFF_PROMISC) {
>> - /* No need to enable multi-cast when promiscous mode accepts all */
>> - ctrl |= GRETH_CTRL_PRO;
>> - } else if(!sc->mc_available) {
>> - return EINVAL; /* no hardware support for multicast filtering. */
>> - } else if (ifp->if_flags & IFF_ALLMULTI) {
>> - /* We should accept all multicast addresses */
>> - ctrl |= GRETH_CTRL_MCE;
>> - hash_msb = 0xFFFFFFFF;
>> - hash_lsb = 0xFFFFFFFF;
>> - } else if (greth_mac_filter_calc(&sc->arpcom, &hash_msb, &hash_lsb) > 0) {
>> - /* Generate hash for MAC filtering out multicast addresses */
>> - } else {
>> - /* Multicast list is empty .. disable multicast */
>> - SPIN_LOCK_IRQ(&sc->devlock, flags);
>> - sc->regs->ht_msb = hash_msb;
>> - sc->regs->ht_lsb = hash_lsb;
>> - sc->regs->ctrl = (sc->regs->ctrl & ~(GRETH_CTRL_PRO | GRETH_CTRL_MCE)) |
>> - ctrl;
>> - SPIN_UNLOCK_IRQ(&sc->devlock, flags);
>> - return 0;
>> -static void
>> -greth_initialize_hardware (struct greth_softc *sc)
>> - struct mbuf *m;
>> - int i;
>> - int phyaddr;
>> - int phyctrl;
>> - int phystatus;
>> - int tmp1;
>> - int tmp2;
>> - struct timespec tstart, tnow;
>> - greth_regs *regs;
>> - unsigned int advmodes, speed, tabsize;
>> - regs = sc->regs;
>> - /* Reset the controller. */
>> - sc->rxInterrupts = 0;
>> - sc->rxPackets = 0;
>> - if (sc->greth_rst) {
>> - /* Reset ON */
>> - regs->ctrl = GRETH_CTRL_RST | GRETH_CTRL_DD | GRETH_CTRL_ED;
>> - for (i = 0; i<100 && (regs->ctrl & GRETH_CTRL_RST); i++)
>> - speed = 0; /* probe mode below */
>> - } else {
>> - /* inherit EDCL mode for now */
>> - speed = sc->regs->ctrl & (GRETH_CTRL_GB|GRETH_CTRL_SP|GRETH_CTRL_FULLD);
>> - /* Reset OFF and RX/TX DMA OFF. SW do PHY Init */
>> - regs->ctrl = GRETH_CTRL_DD | GRETH_CTRL_ED | speed;
>> - /* Check if mac is gbit capable*/
>> - sc->gbit_mac = (regs->ctrl >> 27) & 1;
>> - /* Get the phy address which assumed to have been set
>> - correctly with the reset value in hardware*/
>> - if ( sc->phyaddr == -1 ) {
>> - phyaddr = (regs->mdio_ctrl >> 11) & 0x1F;
>> - } else {
>> - phyaddr = sc->phyaddr;
>> - sc->phy_read_access = 0;
>> - sc->phy_write_access = 0;
>> - /* As I understand the PHY comes back to a good default state after
>> - * Power-down or Reset, so we do both just in case. Power-down bit should
>> - * be cleared.
>> - * Wait for old reset (if asserted by boot loader) to complete, otherwise
>> - * power-down instruction might not have any effect.
>> - while (read_mii(sc, phyaddr, 0) & 0x8000) {}
>> - write_mii(sc, phyaddr, 0, 0x0800); /* Power-down */
>> - write_mii(sc, phyaddr, 0, 0x0000); /* Power-Up */
>> - write_mii(sc, phyaddr, 0, 0x8000); /* Reset */
>> - /* We wait about 30ms */
>> - rtems_task_wake_after(rtems_clock_get_ticks_per_second()/32);
>> - /* Wait for reset to complete and get default values */
>> - while ((phyctrl = read_mii(sc, phyaddr, 0)) & 0x8000) {}
>> - /* Set up PHY advertising modes for auto-negotiation */
>> - advmodes = sc->advmodes;
>> - if (advmodes == 0)
>> - advmodes = GRETH_ADV_ALL;
>> - if (!sc->gbit_mac)
>> - advmodes &= ~(GRETH_ADV_1000_FD | GRETH_ADV_1000_HD);
>> - /* Enable/Disable GBit auto-neg advetisement so that the link partner
>> - * know that we have/haven't GBit capability. The MAC may not support
>> - * Gbit even though PHY does...
>> - phystatus = read_mii(sc, phyaddr, 1);
>> - if (phystatus & 0x0100) {
>> - tmp1 = read_mii(sc, phyaddr, 9);
>> - tmp1 &= ~0x300;
>> - if (advmodes & GRETH_ADV_1000_FD)
>> - tmp1 |= 0x200;
>> - if (advmodes & GRETH_ADV_1000_HD)
>> - tmp1 |= 0x100;
>> - write_mii(sc, phyaddr, 9, tmp1);
>> - /* Optionally limit the 10/100 modes as configured by user */
>> - tmp1 = read_mii(sc, phyaddr, 4);
>> - tmp1 &= ~0x1e0;
>> - if (advmodes & GRETH_ADV_100_FD)
>> - tmp1 |= 0x100;
>> - if (advmodes & GRETH_ADV_100_HD)
>> - tmp1 |= 0x080;
>> - if (advmodes & GRETH_ADV_10_FD)
>> - tmp1 |= 0x040;
>> - if (advmodes & GRETH_ADV_10_HD)
>> - tmp1 |= 0x020;
>> - write_mii(sc, phyaddr, 4, tmp1);
>> - /* If autonegotiation implemented we start it */
>> - if (phystatus & 0x0008) {
>> - write_mii(sc, phyaddr, 0, phyctrl | 0x1200);
>> - phyctrl = read_mii(sc, phyaddr, 0);
>> - /* Check if PHY is autoneg capable and then determine operating mode,
>> - otherwise force it to 10 Mbit halfduplex */
>> - sc->gb = 0;
>> - sc->fd = 0;
>> - sc->sp = 0;
>> - sc->auto_neg = 0;
>> - timespecclear(&sc->auto_neg_time);
>> - if ((phyctrl >> 12) & 1) {
>> - /*wait for auto negotiation to complete*/
>> - sc->auto_neg = 1;
>> - if (rtems_clock_get_uptime(&tstart) != RTEMS_SUCCESSFUL)
>> - printk("rtems_clock_get_uptime failed\n");
>> - while (!(((phystatus = read_mii(sc, phyaddr, 1)) >> 5) & 1)) {
>> - if (rtems_clock_get_uptime(&tnow) != RTEMS_SUCCESSFUL)
>> - timespecsub(&tnow, &tstart, &sc->auto_neg_time);
>> - if (timespeccmp(&sc->auto_neg_time, &greth_tan, >)) {
>> - sc->auto_neg = -1; /* Failed */
>> - tmp1 = read_mii(sc, phyaddr, 0);
>> - sc->gb = ((phyctrl >> 6) & 1) && !((phyctrl >> 13) & 1);
>> - sc->sp = !((phyctrl >> 6) & 1) && ((phyctrl >> 13) & 1);
>> - sc->fd = (phyctrl >> 8) & 1;
>> - goto auto_neg_done;
>> - /* Wait about 30ms, time is PHY dependent */
>> - sc->phydev.adv = read_mii(sc, phyaddr, 4);
>> - sc->phydev.part = read_mii(sc, phyaddr, 5);
>> - if ((phystatus >> 8) & 1) {
>> - sc->phydev.extadv = read_mii(sc, phyaddr, 9);
>> - sc->phydev.extpart = read_mii(sc, phyaddr, 10);
>> - if ( (sc->phydev.extadv & GRETH_MII_EXTADV_1000HD) &&
>> - (sc->phydev.extpart & GRETH_MII_EXTPRT_1000HD)) {
>> - sc->gb = 1;
>> - sc->fd = 0;
>> - if ( (sc->phydev.extadv & GRETH_MII_EXTADV_1000FD) &&
>> - (sc->phydev.extpart & GRETH_MII_EXTPRT_1000FD)) {
>> - sc->gb = 1;
>> - sc->fd = 1;
>> - if ((sc->gb == 0) || ((sc->gb == 1) && (sc->gbit_mac == 0))) {
>> - if ( (sc->phydev.adv & GRETH_MII_100TXFD) &&
>> - (sc->phydev.part & GRETH_MII_100TXFD)) {
>> - sc->sp = 1;
>> - sc->fd = 1;
>> - } else if ( (sc->phydev.adv & GRETH_MII_100TXHD) &&
>> - (sc->phydev.part & GRETH_MII_100TXHD)) {
>> - sc->sp = 1;
>> - sc->fd = 0;
>> - } else if ( (sc->phydev.adv & GRETH_MII_10FD) &&
>> - (sc->phydev.part & GRETH_MII_10FD)) {
>> - sc->fd = 1;
>> -auto_neg_done:
>> - sc->phydev.vendor = 0;
>> - sc->phydev.device = 0;
>> - sc->phydev.rev = 0;
>> - /* Read out PHY info if extended registers are available */
>> - if (phystatus & 1) {
>> - tmp1 = read_mii(sc, phyaddr, 2);
>> - tmp2 = read_mii(sc, phyaddr, 3);
>> - sc->phydev.vendor = (tmp1 << 6) | ((tmp2 >> 10) & 0x3F);
>> - sc->phydev.rev = tmp2 & 0xF;
>> - sc->phydev.device = (tmp2 >> 4) & 0x3F;
>> - /* Force to 10 mbit half duplex if the 10/100 MAC is used with a 1000 PHY */
>> - if (((sc->gb) && !(sc->gbit_mac)) || !((phyctrl >> 12) & 1)) {
>> - write_mii(sc, phyaddr, 0, sc->sp << 13);
>> - /* check if marvell 88EE1111 PHY. Needs special reset handling */
>> - if ((phystatus & 1) && (sc->phydev.vendor == 0x005043) &&
>> - (sc->phydev.device == 0x0C))
>> - sc->gb = 0;
>> - sc->sp = 0;
>> - sc->fd = 0;
>> - while ((read_mii(sc, phyaddr, 0)) & 0x8000) {}
>> - /* Reset ON */
>> - for (i = 0; i < 100 && (regs->ctrl & GRETH_CTRL_RST); i++)
>> - /* Reset OFF. Set mode matching PHY settings. */
>> - speed = (sc->gb << 8) | (sc->sp << 7) | (sc->fd << 4);
>> - regs->ctrl = GRETH_CTRL_DD | sc->edcl_dis | speed;
>> - /* Initialize rx/tx descriptor table pointers. Due to alignment we
>> - * always allocate maximum table size.
>> - tabsize = sc->num_descs * 8;
>> - sc->txdesc = (greth_rxtxdesc *) almalloc(tabsize * 2, tabsize);
>> - sc->rxdesc = (greth_rxtxdesc *) (tabsize + (void *)sc->txdesc);
>> - sc->tx_ptr = 0;
>> - sc->tx_dptr = 0;
>> - sc->tx_cnt = 0;
>> - sc->rx_ptr = 0;
>> - /* Translate the Descriptor DMA table base address into an address that
>> - * the GRETH core can understand
>> - drvmgr_translate_check(
>> - sc->dev,
>> - CPUMEM_TO_DMA,
>> - (void *)sc->txdesc,
>> - (void **)&sc->txdesc_remote,
>> - tabsize * 2);
>> - sc->rxdesc_remote = sc->txdesc_remote + tabsize;
>> - regs->txdesc = (int) sc->txdesc_remote;
>> - regs->rxdesc = (int) sc->rxdesc_remote;
>> - sc->rxmbuf = grlib_calloc(sc->rxbufs, sizeof(*sc->rxmbuf));
>> - sc->txmbuf = grlib_calloc(sc->txbufs, sizeof(*sc->txmbuf));
>> - for (i = 0; i < sc->txbufs; i++)
>> - sc->txdesc[i].ctrl = 0;
>> - if (!(sc->gbit_mac)) {
>> - sc->dev,
>> - CPUMEM_TO_DMA,
>> - (void *)grlib_malloc(GRETH_MAXBUF_LEN),
>> - (void **)&sc->txdesc[i].addr,
>> - GRETH_MAXBUF_LEN);
>> -#ifdef GRETH_DEBUG
>> - /* printf("TXBUF: %08x\n", (int) sc->txdesc[i].addr); */
>> -#endif
>> - for (i = 0; i < sc->rxbufs; i++)
>> - MGETHDR (m, M_WAIT, MT_DATA);
>> - MCLGET (m, M_WAIT);
>> - if (sc->gbit_mac)
>> - m->m_data += 2;
>> - m->m_pkthdr.rcvif = &sc->arpcom.ac_if;
>> - sc->rxmbuf[i] = m;
>> - sc->dev,
>> - CPUMEM_TO_DMA,
>> - (void *)mtod(m, uint32_t *),
>> - (void **)&sc->rxdesc[i].addr,
>> - sc->rxdesc[i].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ;
>> -#ifdef GRETH_DEBUG
>> -/* printf("RXBUF: %08x\n", (int) sc->rxdesc[i].addr); */
>> -#endif
>> - sc->rxdesc[sc->rxbufs - 1].ctrl |= GRETH_RXD_WRAP;
>> - /* set ethernet address. */
>> - regs->mac_addr_msb =
>> - sc->arpcom.ac_enaddr[0] << 8 | sc->arpcom.ac_enaddr[1];
>> - regs->mac_addr_lsb =
>> - sc->arpcom.ac_enaddr[2] << 24 | sc->arpcom.ac_enaddr[3] << 16 |
>> - sc->arpcom.ac_enaddr[4] << 8 | sc->arpcom.ac_enaddr[5];
>> - if ( sc->rxbufs < 10 ) {
>> - sc->tx_int_gen = sc->tx_int_gen_cur = 1;
>> - }else{
>> - sc->tx_int_gen = sc->tx_int_gen_cur = sc->txbufs/2;
>> - sc->next_tx_mbuf = NULL;
>> - if ( !sc->gbit_mac )
>> - sc->max_fragsize = 1;
>> - /* clear all pending interrupts */
>> - regs->status = 0xffffffff;
>> - /* install interrupt handler */
>> - drvmgr_interrupt_register(sc->dev, 0, "greth", greth_interrupt, sc);
>> - regs->ctrl |= GRETH_CTRL_RXEN | GRETH_CTRL_RXIRQ;
>> - print_init_info(sc);
>> -#ifdef CPU_U32_FIX
>> - * Routine to align the received packet so that the ip header
>> - * is on a 32-bit boundary. Necessary for cpu's that do not
>> - * allow unaligned loads and stores and when the 32-bit DMA
>> - * mode is used.
>> - * Transfers are done on word basis to avoid possibly slow byte
>> - * and half-word writes.
>> - unsigned int *first, *last, data;
>> - unsigned int tmp = 0;
>> - if ((((int) m->m_data) & 2) && (m->m_len)) {
>> -#if CPU_LITTLE_ENDIAN == TRUE
>> - memmove((caddr_t)(((int) m->m_data) + 2), m->m_data, m->m_len);
>> -#else
>> - last = (unsigned int *) ((((int) m->m_data) + m->m_len + 8) & ~3);
>> - first = (unsigned int *) (((int) m->m_data) & ~3);
>> - /* tmp = *first << 16; */
>> - tmp = GRETH_MEM_LOAD(first);
>> - tmp = tmp << 16;
>> - first++;
>> - do {
>> - /* When snooping is not available the LDA instruction must be used
>> - * to avoid the cache to return an illegal value.
>> - ** Load with forced cache miss
>> - * data = *first;
>> - data = GRETH_MEM_LOAD(first);
>> - *first = tmp | (data >> 16);
>> - tmp = data << 16;
>> - first++;
>> - } while (first <= last);
>> -#endif
>> - m->m_data = (caddr_t)(((int) m->m_data) + 2);
>> -#endif
>> -static void
>> -greth_Daemon (void *arg)
>> - struct ether_header *eh;
>> - struct greth_softc *dp = (struct greth_softc *) arg;
>> - struct ifnet *ifp = &dp->arpcom.ac_if;
>> - struct mbuf *m;
>> - unsigned int len, len_status, bad;
>> - rtems_event_set events;
>> - int first;
>> - int tmp;
>> - for (;;)
>> - rtems_bsdnet_event_receive (INTERRUPT_EVENT | GRETH_TX_WAIT_EVENT,
>> - RTEMS_WAIT | RTEMS_EVENT_ANY,
>> - RTEMS_NO_TIMEOUT, &events);
>> - if ( events & GRETH_TX_WAIT_EVENT ){
>> - /* TX interrupt.
>> - * We only end up here when all TX descriptors has been used,
>> - * and
>> - if ( dp->gbit_mac )
>> - greth_process_tx_gbit(dp);
>> - else
>> - greth_process_tx(dp);
>> - /* If we didn't get a RX interrupt we don't process it */
>> - if ( (events & INTERRUPT_EVENT) == 0 )
>> - continue;
>> -#ifdef GRETH_ETH_DEBUG
>> - printf ("r\n");
>> -#endif
>> - first=1;
>> - /* Scan for Received packets */
>> -again:
>> - while (!((len_status =
>> - GRETH_MEM_LOAD(&dp->rxdesc[dp->rx_ptr].ctrl)) & GRETH_RXD_ENABLE))
>> - bad = 0;
>> - if (len_status & GRETH_RXD_TOOLONG)
>> - dp->rxLengthError++;
>> - bad = 1;
>> - if (len_status & GRETH_RXD_DRIBBLE)
>> - dp->rxNonOctet++;
>> - bad = 1;
>> - if (len_status & GRETH_RXD_CRCERR)
>> - dp->rxBadCRC++;
>> - bad = 1;
>> - if (len_status & GRETH_RXD_OVERRUN)
>> - dp->rxOverrun++;
>> - bad = 1;
>> - if (len_status & GRETH_RXD_LENERR)
>> - bad = 1;
>> - if (!bad)
>> - /* pass on the packet in the receive buffer */
>> - len = len_status & 0x7FF;
>> - m = dp->rxmbuf[dp->rx_ptr];
>> -#ifdef GRETH_DEBUG
>> - int i;
>> - printf("RX: 0x%08x, Len: %d : ", (int) m->m_data, len);
>> - for (i=0; i<len; i++)
>> - printf("%x%x", (m->m_data[i] >> 4) & 0x0ff, m->m_data[i] & 0x0ff);
>> - printf("\n");
>> -#endif
>> - m->m_len = m->m_pkthdr.len =
>> - len - sizeof (struct ether_header);
>> - eh = mtod (m, struct ether_header *);
>> - m->m_data += sizeof (struct ether_header);
>> -#ifdef CPU_U32_FIX
>> - if(!dp->gbit_mac) {
>> - /* OVERRIDE CACHED ETHERNET HEADER FOR NON-SNOOPING SYSTEMS */
>> - tmp = GRETH_MEM_LOAD((uintptr_t)eh);
>> - tmp = GRETH_MEM_LOAD(4+(uintptr_t)eh);
>> - tmp = GRETH_MEM_LOAD(8+(uintptr_t)eh);
>> - tmp = GRETH_MEM_LOAD(12+(uintptr_t)eh);
>> - (void)tmp;
>> - ipalign(m); /* Align packet on 32-bit boundary */
>> -#endif
>> - if(!(dp->gbit_mac) && !CPU_SPARC_HAS_SNOOPING) {
>> - rtems_cache_invalidate_entire_data();
>> - ether_input (ifp, eh, m);
>> - if (dp->gbit_mac)
>> - m->m_data += 2;
>> - dp->rxmbuf[dp->rx_ptr] = m;
>> - m->m_pkthdr.rcvif = ifp;
>> - dp->dev,
>> - CPUMEM_TO_DMA,
>> - (void *)mtod (m, uint32_t *),
>> - (void **)&dp->rxdesc[dp->rx_ptr].addr,
>> - dp->rxPackets++;
>> - if (dp->rx_ptr == dp->rxbufs - 1) {
>> - dp->rxdesc[dp->rx_ptr].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ | GRETH_RXD_WRAP;
>> - } else {
>> - dp->rxdesc[dp->rx_ptr].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ;
>> - SPIN_LOCK_IRQ(&dp->devlock, flags);
>> - dp->regs->ctrl |= GRETH_CTRL_RXEN;
>> - SPIN_UNLOCK_IRQ(&dp->devlock, flags);
>> - dp->rx_ptr = (dp->rx_ptr + 1) % dp->rxbufs;
>> - /* Always scan twice to avoid deadlock */
>> - if ( first ){
>> - first=0;
>> - dp->regs->ctrl |= GRETH_CTRL_RXIRQ;
>> - goto again;
>> -static int
>> -sendpacket (struct ifnet *ifp, struct mbuf *m)
>> - struct greth_softc *dp = ifp->if_softc;
>> - unsigned char *temp;
>> - struct mbuf *n;
>> - unsigned int len;
>> - * Is there a free descriptor available?
>> - if (GRETH_MEM_LOAD(&dp->txdesc[dp->tx_ptr].ctrl) & GRETH_TXD_ENABLE){
>> - /* No. */
>> - return 1;
>> - /* Remember head of chain */
>> - n = m;
>> - len = 0;
>> - temp = (unsigned char *) GRETH_MEM_LOAD(&dp->txdesc[dp->tx_ptr].addr);
>> - drvmgr_translate(dp->dev, CPUMEM_FROM_DMA, (void *)temp, (void **)&temp);
>> -#ifdef GRETH_DEBUG
>> - printf("TXD: 0x%08x : BUF: 0x%08x\n", (int) m->m_data, (int) temp);
>> -#endif
>> - for (;;)
>> -#ifdef GRETH_DEBUG
>> - int i;
>> - printf("MBUF: 0x%08x : ", (int) m->m_data);
>> - for (i=0;i<m->m_len;i++)
>> - printf("\n");
>> -#endif
>> - len += m->m_len;
>> - if (len <= RBUF_SIZE)
>> - memcpy ((void *) temp, (char *) m->m_data, m->m_len);
>> - temp += m->m_len;
>> - if ((m = m->m_next) == NULL)
>> - break;
>> - m_freem (n);
>> - /* don't send long packets */
>> - if (len <= GRETH_MAXBUF_LEN) {
>> - if (dp->tx_ptr < dp->txbufs-1) {
>> - dp->txdesc[dp->tx_ptr].ctrl = GRETH_TXD_IRQ |
>> - GRETH_TXD_ENABLE | len;
>> - } else {
>> - GRETH_TXD_WRAP | GRETH_TXD_ENABLE | len;
>> - dp->tx_ptr = (dp->tx_ptr + 1) % dp->txbufs;
>> - dp->regs->ctrl = dp->regs->ctrl | GRETH_CTRL_TXEN;
>> - return 0;
>> -static int
>> -sendpacket_gbit (struct ifnet *ifp, struct mbuf *m)
>> - unsigned int len;
>> - unsigned int ctrl;
>> - int frags;
>> - struct mbuf *mtmp;
>> - int int_en;
>> - len = 0;
>> -#ifdef GRETH_DEBUG
>> - printf("TXD: 0x%08x\n", (int) m->m_data);
>> -#endif
>> - /* Get number of fragments too see if we have enough
>> - * resources.
>> - frags=1;
>> - mtmp=m;
>> - while(mtmp->m_next){
>> - frags++;
>> - mtmp = mtmp->m_next;
>> - if ( frags > dp->max_fragsize )
>> - dp->max_fragsize = frags;
>> - if ( frags > dp->txbufs ){
>> - printf("GRETH: MBUF-chain cannot be sent. Increase descriptor count.\n");
>> - return -1;
>> - if ( frags > (dp->txbufs-dp->tx_cnt) ){
>> - /* Return number of fragments */
>> - return frags;
>> - /* Enable interrupt from descriptor every tx_int_gen
>> - * descriptor. Typically every 16 descriptor. This
>> - * is only to reduce the number of interrupts during
>> - * heavy load.
>> - dp->tx_int_gen_cur-=frags;
>> - if ( dp->tx_int_gen_cur <= 0 ){
>> - dp->tx_int_gen_cur = dp->tx_int_gen;
>> - int_en = GRETH_TXD_IRQ;
>> - }else{
>> - int_en = 0;
>> - /* At this stage we know that enough descriptors are available */
>> - for (;;)
>> -#ifdef GRETH_DEBUG
>> - int i;
>> - printf("MBUF: 0x%08x, Len: %d : ", (int) m->m_data, m->m_len);
>> - for (i=0; i<m->m_len; i++)
>> - printf("\n");
>> -#endif
>> - len += m->m_len;
>> - dp->dev,
>> - CPUMEM_TO_DMA,
>> - (void *)(uint32_t *)m->m_data,
>> - (void **)&dp->txdesc[dp->tx_ptr].addr,
>> - m->m_len);
>> - /* Wrap around? */
>> - ctrl = GRETH_TXD_ENABLE;
>> - }else{
>> - ctrl = GRETH_TXD_ENABLE | GRETH_TXD_WRAP;
>> - /* Enable Descriptor */
>> - if ((m->m_next) == NULL) {
>> - dp->txdesc[dp->tx_ptr].ctrl = ctrl | int_en | m->m_len;
>> - break;
>> - }else{
>> - dp->txdesc[dp->tx_ptr].ctrl = GRETH_TXD_MORE | ctrl | int_en | m->m_len;
>> - /* Next */
>> - dp->txmbuf[dp->tx_ptr] = m;
>> - dp->tx_cnt++;
>> - m = m->m_next;
>> - dp->tx_cnt++;
>> - /* Tell Hardware about newly enabled descriptor */
>> - return 0;
>> - struct mbuf *m;
>> - int first=1;
>> - * Send packets till queue is empty
>> - for (;;){
>> - /* Reap Sent packets */
>> - while((sc->tx_cnt > 0) && !(GRETH_MEM_LOAD(&sc->txdesc[sc->tx_dptr].ctrl) & GRETH_TXD_ENABLE)) {
>> - m_free(sc->txmbuf[sc->tx_dptr]);
>> - sc->tx_dptr = (sc->tx_dptr + 1) % sc->txbufs;
>> - sc->tx_cnt--;
>> - if ( sc->next_tx_mbuf ){
>> - /* Get packet we tried but faild to transmit last time */
>> - m = sc->next_tx_mbuf;
>> - sc->next_tx_mbuf = NULL; /* Mark packet taken */
>> - }else{
>> - * Get the next mbuf chain to transmit from Stack.
>> - IF_DEQUEUE (&ifp->if_snd, m);
>> - if (!m){
>> - /* Hardware has sent all schedule packets, this
>> - * makes the stack enter at greth_start next time
>> - * a packet is to be sent.
>> - ifp->if_flags &= ~IFF_OACTIVE;
>> - break;
>> - /* Are there free descriptors available? */
>> - /* Try to send packet, if it a negative number is returned. */
>> - if ( (sc->tx_cnt >= sc->txbufs) || sendpacket_gbit(ifp, m) ){
>> - /* Not enough resources */
>> - /* Since we have taken the mbuf out of the "send chain"
>> - * we must remember to use that next time we come back.
>> - * or else we have dropped a packet.
>> - sc->next_tx_mbuf = m;
>> - /* Not enough resources, enable interrupt for transmissions
>> - * this way we will be informed when more TX-descriptors are
>> - * available.
>> - if ( first ){
>> - first = 0;
>> - ifp->if_flags |= IFF_OACTIVE;
>> - sc->regs->ctrl |= GRETH_CTRL_TXIRQ;
>> - /* We must check again to be sure that we didn't
>> - * miss an interrupt (if a packet was sent just before
>> - * enabling interrupts)
>> - continue;
>> - return -1;
>> - }else{
>> - /* Sent Ok, proceed to process more packets if available */
>> - return 0;
>> - struct mbuf *m;
>> - int first=1;
>> - for (;;){
>> - /* Get packet we tried but failed to transmit last time */
>> - }else{
>> - if (!m){
>> - break;
>> - /* Try to send packet, failed if it a non-zero number is returned. */
>> - if ( sendpacket(ifp, m) ){
>> - * available.
>> - if ( first ){
>> - first = 0;
>> - continue;
>> - return -1;
>> - }else{
>> - return 0;
>> -static void
>> -greth_start (struct ifnet *ifp)
>> - struct greth_softc *sc = ifp->if_softc;
>> - if ( ifp->if_flags & IFF_OACTIVE )
>> - return;
>> - if ( sc->gbit_mac ){
>> - /* No use trying to handle this if we are waiting on GRETH
>> - * to send the previously scheduled packets.
>> - greth_process_tx_gbit(sc);
>> - }else{
>> - greth_process_tx(sc);
>> - * Initialize and start the device
>> -static void
>> -greth_init (void *arg)
>> - struct greth_softc *sc = arg;
>> - char name[4] = {'E', 'T', 'H', '0'};
>> - if (sc->daemonTid == 0)
>> - * Start driver tasks
>> - name[3] += sc->minor;
>> - sc->daemonTid = rtems_bsdnet_newproc (name, 4096,
>> - greth_Daemon, sc);
>> - * Set up GRETH hardware
>> - greth_initialize_hardware (sc);
>> - * Setup promiscous/multi-cast MAC address filters if user enabled it
>> - greth_mac_filter_set(sc);
>> - * Tell the world that we're running.
>> - ifp->if_flags |= IFF_RUNNING;
>> - * Stop the device
>> -static void
>> -greth_stop (struct greth_softc *sc)
>> - unsigned int speed;
>> - ifp->if_flags &= ~IFF_RUNNING;
>> - speed = sc->regs->ctrl & (GRETH_CTRL_GB | GRETH_CTRL_SP | GRETH_CTRL_FULLD);
>> - /* RX/TX OFF */
>> - sc->regs->ctrl = GRETH_CTRL_DD | GRETH_CTRL_ED | speed;
>> - /* Reset ON */
>> - sc->regs->ctrl = GRETH_CTRL_RST | GRETH_CTRL_DD | GRETH_CTRL_ED | speed;
>> - /* Reset OFF and restore link settings previously detected if any */
>> - sc->regs->ctrl = GRETH_CTRL_DD | sc->edcl_dis | speed;
>> - * Show interface statistics
>> -static void
>> -greth_stats (struct greth_softc *sc)
>> - printf (" Rx Interrupts:%-8lu", sc->rxInterrupts);
>> - printf (" Rx Packets:%-8lu", sc->rxPackets);
>> - printf (" Length:%-8lu", sc->rxLengthError);
>> - printf (" Non-octet:%-8lu\n", sc->rxNonOctet);
>> - printf (" Bad CRC:%-8lu", sc->rxBadCRC);
>> - printf (" Overrun:%-8lu", sc->rxOverrun);
>> - printf (" Tx Interrupts:%-8lu", sc->txInterrupts);
>> - printf (" Maximal Frags:%-8d", sc->max_fragsize);
>> - printf (" GBIT MAC:%-8d", sc->gbit_mac);
>> - * Driver ioctl handler
>> -static int
>> -greth_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
>> - int error = 0;
>> - struct ifreq *ifr;
>> - switch (command)
>> - case SIOCGIFADDR:
>> - case SIOCSIFADDR:
>> - ether_ioctl (ifp, command, data);
>> - break;
>> - case SIOCSIFFLAGS:
>> - switch (ifp->if_flags & (IFF_UP | IFF_RUNNING))
>> - case IFF_RUNNING:
>> - greth_stop (sc);
>> - break;
>> - case IFF_UP:
>> - greth_init (sc);
>> - break;
>> - case IFF_UP | IFF_RUNNING:
>> - greth_stop (sc);
>> - greth_init (sc);
>> - break;
>> - default:
>> - break;
>> - break;
>> - case SIO_RTEMS_SHOW_STATS:
>> - greth_stats (sc);
>> - break;
>> - * Multicast commands: Enabling/disabling filtering of MAC addresses
>> - case SIOCADDMULTI:
>> - case SIOCDELMULTI:
>> - ifr = (struct ifreq *)data;
>> - if (command == SIOCADDMULTI) {
>> - error = ether_addmulti(ifr, &sc->arpcom);
>> - } else {
>> - error = ether_delmulti(ifr, &sc->arpcom);
>> - if (error == ENETRESET) {
>> - error = greth_mac_filter_set(sc);
>> - break;
>> - default:
>> - error = EINVAL;
>> - break;
>> - return error;
>> - * Attach an GRETH driver to the system
>> -static int
>> -greth_interface_driver_attach (
>> - struct rtems_bsdnet_ifconfig *config,
>> - int attach
>> - struct greth_softc *sc;
>> - struct ifnet *ifp;
>> - int mtu;
>> - int unitNumber;
>> - char *unitName;
>> - /* parse driver name */
>> - if ((unitNumber = rtems_bsdnet_parse_driver_name (config, &unitName)) < 0)
>> - return 0;
>> - sc = config->drv_ctrl;
>> - ifp = &sc->arpcom.ac_if;
>> -#ifdef GRETH_DEBUG
>> - printf("GRETH[%d]: %s, sc %p, dev %p on %s\n", unitNumber, config->ip_address, sc, sc->dev, sc->dev->parent->dev->name);
>> -#endif
>> - if (config->hardware_address)
>> - memcpy (sc->arpcom.ac_enaddr, config->hardware_address,
>> - ETHER_ADDR_LEN);
>> - else
>> - memset (sc->arpcom.ac_enaddr, 0x08, ETHER_ADDR_LEN);
>> - if (config->mtu)
>> - mtu = config->mtu;
>> - else
>> - mtu = ETHERMTU;
>> - sc->acceptBroadcast = !config->ignore_broadcast;
>> - * Set up network interface values
>> - ifp->if_softc = sc;
>> - ifp->if_unit = unitNumber;
>> - ifp->if_name = unitName;
>> - ifp->if_mtu = mtu;
>> - ifp->if_init = greth_init;
>> - ifp->if_ioctl = greth_ioctl;
>> - ifp->if_start = greth_start;
>> - ifp->if_output = ether_output;
>> - ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX;
>> - if (sc->mc_available)
>> - ifp->if_flags |= IFF_MULTICAST;
>> - if (ifp->if_snd.ifq_maxlen == 0)
>> - ifp->if_snd.ifq_maxlen = ifqmaxlen;
>> - * Attach the interface
>> - if_attach (ifp);
>> - ether_ifattach (ifp);
>> -#ifdef GRETH_DEBUG
>> - printf ("GRETH : driver has been attached\n");
>> -#endif
>> - return 1;
>> -/******************* Driver manager interface ***********************/
>> -/* Driver prototypes */
>> -int greth_register_io(rtems_device_major_number *m);
>> -int greth_device_init(struct greth_softc *sc);
>> -#ifdef GRETH_INFO_AVAIL
>> -static int greth_info(
>> - struct drvmgr_dev *dev,
>> - void (*print_line)(void *p, char *str),
>> - void *p, int argc, char *argv[]);
>> -#define GRETH_INFO_FUNC greth_info
>> -#else
>> -#define GRETH_INFO_FUNC NULL
>> -#endif
>> -int greth_init2(struct drvmgr_dev *dev);
>> -int greth_init3(struct drvmgr_dev *dev);
>> -struct drvmgr_drv_ops greth_ops =
>> - .init =
>> - NULL,
>> - greth_init2,
>> - greth_init3,
>> - NULL
>> - .remove = NULL,
>> - .info = GRETH_INFO_FUNC,
>> -struct amba_dev_id greth_ids[] =
>> - {VENDOR_GAISLER, GAISLER_ETHMAC},
>> - {0, 0} /* Mark end of table */
>> -struct amba_drv_info greth_drv_info =
>> - DRVMGR_OBJ_DRV, /* Driver */
>> - NULL, /* Next driver */
>> - NULL, /* Device list */
>> - DRIVER_AMBAPP_GAISLER_GRETH_ID, /* Driver ID */
>> - "GRETH_DRV", /* Driver Name */
>> - DRVMGR_BUS_TYPE_AMBAPP, /* Bus Type */
>> - &greth_ops,
>> - NULL, /* Funcs */
>> - 0, /* No devices yet */
>> - 0,
>> - &greth_ids[0]
>> -void greth_register_drv (void)
>> - DBG("Registering GRETH driver\n");
>> - drvmgr_drv_register(&greth_drv_info.general);
>> - struct greth_softc *priv;
>> - DBG("GRETH[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
>> - priv = dev->priv = grlib_calloc(1, sizeof(*priv));
>> - if ( !priv )
>> - return DRVMGR_NOMEM;
>> - priv->dev = dev;
>> - /* This core will not find other cores, so we wait for init3() */
>> - return DRVMGR_OK;
>> - struct rtems_bsdnet_ifconfig *ifp;
>> - rtems_status_code status;
>> - sc = dev->priv;
>> - sprintf(sc->devName, "gr_eth%d", (dev->minor_drv+1));
>> - /* Init GRETH device */
>> - if ( greth_device_init(sc) ) {
>> - printk("GRETH: Failed to init device\n");
>> - return DRVMGR_FAIL;
>> - /* Initialize Spin-lock for GRSPW Device. This is to protect
>> - * CTRL and DMACTRL registers from ISR.
>> - SPIN_INIT(&sc->devlock, sc->devName);
>> - /* Register GRETH device as an Network interface */
>> - ifp = grlib_calloc(1, sizeof(*ifp));
>> - ifp->name = sc->devName;
>> - ifp->drv_ctrl = sc;
>> - ifp->attach = greth_interface_driver_attach;
>> - status = network_interface_add(ifp);
>> - if (status != 0) {
>> - return DRVMGR_OK;
>> - struct amba_dev_info *ambadev;
>> - struct ambapp_core *pnpinfo;
>> - union drvmgr_key_value *value;
>> - int i, nrd;
>> - /* Get device information from AMBA PnP information */
>> - ambadev = (struct amba_dev_info *)sc->dev->businfo;
>> - if ( ambadev == NULL ) {
>> - return -1;
>> - pnpinfo = &ambadev->info;
>> - sc->regs = (greth_regs *)pnpinfo->apb_slv->start;
>> - sc->minor = sc->dev->minor_drv;
>> - sc->greth_rst = 1;
>> - /* Remember EDCL enabled/disable state before reset */
>> - sc->edcl_dis = sc->regs->ctrl & GRETH_CTRL_ED;
>> - /* Default is to inherit EDCL Disable bit from HW. User can force En/Dis */
>> - value = drvmgr_dev_key_get(sc->dev, "edclDis", DRVMGR_KT_INT);
>> - if ( value ) {
>> - /* Force EDCL mode. Has an effect later when GRETH+PHY is initialized */
>> - if (value->i > 0) {
>> - sc->edcl_dis = GRETH_CTRL_ED;
>> - } else {
>> - /* Default to avoid soft-reset the GRETH when EDCL is forced */
>> - sc->edcl_dis = 0;
>> - sc->greth_rst = 0;
>> - /* let user control soft-reset of GRETH (for debug) */
>> - value = drvmgr_dev_key_get(sc->dev, "soft-reset", DRVMGR_KT_INT);
>> - if ( value) {
>> - sc->greth_rst = value->i ? 1 : 0;
>> - /* clear control register and reset NIC and keep current speed modes.
>> - * This should be done as quick as possible during startup, this is to
>> - * stop DMA transfers after a reboot.
>> - * When EDCL is forced enabled reset is skipped, disabling RX/TX DMA is
>> - * is enough during debug.
>> - /* Configure driver by overriding default config with the bus resources
>> - * configured by the user
>> - sc->txbufs = 32;
>> - sc->rxbufs = 32;
>> - sc->phyaddr = -1;
>> - /* Probe the number of descriptors available the */
>> - nrd = (sc->regs->status & GRETH_STATUS_NRD) >> 24;
>> - for (sc->num_descs = 128, i = 0; i < nrd; i++)
>> - sc->num_descs = sc->num_descs * 2;
>> - value = drvmgr_dev_key_get(sc->dev, "txDescs", DRVMGR_KT_INT);
>> - if ( value && (value->i <= sc->num_descs) )
>> - sc->txbufs = value->i;
>> - value = drvmgr_dev_key_get(sc->dev, "rxDescs", DRVMGR_KT_INT);
>> - sc->rxbufs = value->i;
>> - value = drvmgr_dev_key_get(sc->dev, "phyAdr", DRVMGR_KT_INT);
>> - if ( value && (value->i < 32) )
>> - sc->phyaddr = value->i;
>> - value = drvmgr_dev_key_get(sc->dev, "advModes", DRVMGR_KT_INT);
>> - if ( value )
>> - sc->advmodes = value->i;
>> - /* Check if multicast support is available */
>> - sc->mc_available = sc->regs->ctrl & GRETH_CTRL_MC;
>> - return 0;
>> - char buf[64];
>> - if (dev->priv == NULL)
>> - return -DRVMGR_EINVAL;
>> - sc = dev->priv;
>> - sprintf(buf, "IFACE NAME: %s", sc->devName);
>> - print_line(p, buf);
>> - sprintf(buf, "GBIT MAC: %s", sc->gbit_mac ? "YES" : "NO");
>> - return DRVMGR_OK;
>> -#endif
>> -#endif
>> diff --git a/spec/build/bsps/objgrlib.yml b/spec/build/bsps/objgrlib.yml
>> index 4935c7b599..3d12f6d122 100644
>> --- a/spec/build/bsps/objgrlib.yml
>> +++ b/spec/build/bsps/objgrlib.yml
>> @@ -44,7 +44,6 @@ install:
>> - bsps/include/grlib/grascs.h
>> - bsps/include/grlib/grcan.h
>> - bsps/include/grlib/grctm.h
>> - - bsps/include/grlib/greth.h
>> - bsps/include/grlib/grgpio.h
>> - bsps/include/grlib/griommu.h
>> - bsps/include/grlib/grlib.h
>> @@ -64,7 +63,6 @@ install:
>> - bsps/include/grlib/l4stat.h
>> - bsps/include/grlib/mctrl.h
>> - bsps/include/grlib/memscrub.h
>> - - bsps/include/grlib/network_interface_add.h
>> - bsps/include/grlib/occan.h
>> - bsps/include/grlib/pcif.h
>> - bsps/include/grlib/satcan.h
>> diff --git a/spec/build/bsps/powerpc/beatnik/bspbeatnik.yml b/spec/build/bsps/powerpc/beatnik/bspbeatnik.yml
>> index 417d972f1c..df58b6d5da 100644
>> --- a/spec/build/bsps/powerpc/beatnik/bspbeatnik.yml
>> +++ b/spec/build/bsps/powerpc/beatnik/bspbeatnik.yml
>> @@ -25,9 +25,6 @@ install:
>> - bsps/powerpc/beatnik/include/bsp/gtintrreg.h
>> - bsps/powerpc/beatnik/include/bsp/gtpcireg.h
>> - bsps/powerpc/beatnik/include/bsp/gtreg.h
>> - - bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> - - bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> - - bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> - bsps/powerpc/beatnik/include/bsp/irq.h
>> - destination: ${BSP_LIBDIR}
>> source:
>> 2.26.2
