[PATCH] aarch64: whitespace fixes in start.S
Thu Jun 24 16:05:06 UTC 2021
This patch layers on top of my other series of 7, but just applies
cosmetic whitespace changes to use spaces instead of tabs throughout
this start.S file. It was a mix of both previously. If no objections,
I'll apply it with the other series when that gets ACKed.
On Thu, Jun 24, 2021 at 10:03 AM Gedare Bloom <gedare at rtems.org> wrote:
>  bsps/aarch64/shared/start/start.S | 332 +++++++++++++++---------------
>  1 file changed, 166 insertions(+), 166 deletions(-)
> diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
> index 5b535463de..01fa1a8408 100644
> --- a/bsps/aarch64/shared/start/start.S
> +++ b/bsps/aarch64/shared/start/start.S
> @@ -39,64 +39,64 @@
>  #include <bspopts.h>
> -       /* Global symbols */
> -       .globl  _start
> -       .section        ".bsp_start_text", "ax"
> +  /* Global symbols */
> +  .globl _start
> +  .section ".bsp_start_text", "ax"
>  /* Start entry */
>  _start:
> -        * We do not save the context since we do not return to the boot
> -        * loader but preserve x1 and x2 to allow access to bootloader parameters
> +   * We do not save the context since we do not return to the boot
> +   * loader but preserve x1 and x2 to allow access to bootloader parameters
>  #ifndef BSP_START_NEEDS_REGISTER_INITIALIZATION
> -       mov     x5, x1          /* machine type number or ~0 for DT boot */
> -       mov     x6, x2          /* physical address of ATAGs or DTB */
> +  mov x5, x1    /* machine type number or ~0 for DT boot */
> +  mov x6, x2    /* physical address of ATAGs or DTB */
>  #else /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
> -       mov     x0, XZR
> -       mov     x1, XZR
> -       mov     x2, XZR
> -       mov     x3, XZR
> -       mov     x4, XZR
> -       mov     x5, XZR
> -       mov     x6, XZR
> -       mov     x7, XZR
> -       mov     x8, XZR
> -       mov     x9, XZR
> -       mov     x10, XZR
> -       mov     x11, XZR
> -       mov     x12, XZR
> -       mov     x13, XZR
> -       mov     x14, XZR
> -       mov     x15, XZR
> -       mov     x16, XZR
> -       mov     x17, XZR
> -       mov     x18, XZR
> -       mov     x19, XZR
> -       mov     x20, XZR
> -       mov     x21, XZR
> -       mov     x22, XZR
> -       mov     x23, XZR
> -       mov     x24, XZR
> -       mov     x25, XZR
> -       mov     x26, XZR
> -       mov     x27, XZR
> -       mov     x28, XZR
> -       mov     x29, XZR
> -       mov     x30, XZR
> +  mov x0, XZR
> +  mov x1, XZR
> +  mov x2, XZR
> +  mov x3, XZR
> +  mov x4, XZR
> +  mov x5, XZR
> +  mov x6, XZR
> +  mov x7, XZR
> +  mov x8, XZR
> +  mov x9, XZR
> +  mov x10, XZR
> +  mov x11, XZR
> +  mov x12, XZR
> +  mov x13, XZR
> +  mov x14, XZR
> +  mov x15, XZR
> +  mov x16, XZR
> +  mov x17, XZR
> +  mov x18, XZR
> +  mov x19, XZR
> +  mov x20, XZR
> +  mov x21, XZR
> +  mov x22, XZR
> +  mov x23, XZR
> +  mov x24, XZR
> +  mov x25, XZR
> +  mov x26, XZR
> +  mov x27, XZR
> +  mov x28, XZR
> +  mov x29, XZR
> +  mov x30, XZR
>  #ifdef AARCH64_MULTILIB_VFP
>  #endif
>  #endif
> -       /* Initialize SCTLR_EL1 */
> -       mov x0, XZR
> +  /* Initialize SCTLR_EL1 */
> +  mov x0, XZR
>  #if defined(RTEMS_DEBUG)
> -       /* Enable Stack alignment checking */
> -       orr x0, x0, #(1<<3)
> +  /* Enable Stack alignment checking */
> +  orr x0, x0, #(1<<3)
>  #endif
> -       msr SCTLR_EL1, x0
> +  msr SCTLR_EL1, x0
>    mrs x0, CurrentEL
>    cmp x0, #(1<<2)
> @@ -107,7 +107,7 @@ _start:
>    b.eq _el3_start
>  _el3_start:
> -       /* Drop from EL3 to EL2 */
> +  /* Drop from EL3 to EL2 */
>    /* Initialize HCR_EL2 and SCTLR_EL2 */
>    msr HCR_EL2, XZR
> @@ -141,170 +141,170 @@ _el3_start:
>    eret
>  _el2_start:
> -       /* Drop from EL2 to EL1 */
> -       /* Configure HCR_EL2 */
> -       mrs x0, HCR_EL2
> -       /* Set EL1 Execution state to AArch64 */
> -       orr x0, x0, #(1<<31)
> -       /* Disable ID traps */
> -       bic x0, x0, #(1<<15)
> -       bic x0, x0, #(1<<16)
> -       bic x0, x0, #(1<<17)
> -       bic x0, x0, #(1<<18)
> -       msr HCR_EL2, x0
> -       /* Set to EL1h mode for eret */
> -       mov x0, #0b00101
> -       msr SPSR_EL2, x0
> -       /* Set EL1 entry point */
> -       adr x0, _el1_start
> -       msr ELR_EL2, x0
> -       eret
> +  /* Drop from EL2 to EL1 */
> +  /* Configure HCR_EL2 */
> +  mrs x0, HCR_EL2
> +  /* Set EL1 Execution state to AArch64 */
> +  orr x0, x0, #(1<<31)
> +  /* Disable ID traps */
> +  bic x0, x0, #(1<<15)
> +  bic x0, x0, #(1<<16)
> +  bic x0, x0, #(1<<17)
> +  bic x0, x0, #(1<<18)
> +  msr HCR_EL2, x0
> +  /* Set to EL1h mode for eret */
> +  mov x0, #0b00101
> +  msr SPSR_EL2, x0
> +  /* Set EL1 entry point */
> +  adr x0, _el1_start
> +  msr ELR_EL2, x0
> +  eret
>  _el1_start:
>  #ifdef RTEMS_SMP
> -       /* Read MPIDR and get current processor index */
> -        mrs    x7, mpidr_el1
> -       and     x7, #0xff
> +  /* Read MPIDR and get current processor index */
> +  mrs x7, mpidr_el1
> +  and x7, #0xff
>  #endif
>  #ifdef RTEMS_SMP
> -         * Get current per-CPU control and store it in PL1 only Thread ID
> -         * Register (TPIDRPRW).
> +   * Get current per-CPU control and store it in PL1 only Thread ID
> +   * Register (TPIDRPRW).
>  #ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> -       ldr     w1, =_Per_CPU_Information
> +  ldr w1, =_Per_CPU_Information
>  #else
> -       ldr     x1, =_Per_CPU_Information
> +  ldr x1, =_Per_CPU_Information
>  #endif
> -       add     x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
> -       mcr     p15, 0, x1, c13, c0, 4
> +  add x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
> +  mcr p15, 0, x1, c13, c0, 4
>  #endif
> -       /* Calculate interrupt stack area end for current processor */
> +  /* Calculate interrupt stack area end for current processor */
> -       ldr     w1, =_ISR_Stack_size
> +  ldr w1, =_ISR_Stack_size
>  #else
> -       ldr     x1, =_ISR_Stack_size
> +  ldr x1, =_ISR_Stack_size
>  #endif
>  #ifdef RTEMS_SMP
> -       add     x3, x7, #1
> -       mul     x1, x1, x3
> +  add x3, x7, #1
> +  mul x1, x1, x3
>  #endif
> -       ldr     w2, =_ISR_Stack_area_begin
> +  ldr w2, =_ISR_Stack_area_begin
>  #else
> -       ldr     x2, =_ISR_Stack_area_begin
> +  ldr x2, =_ISR_Stack_area_begin
>  #endif
> -       add     x3, x1, x2
> +  add x3, x1, x2
> -       /* Save original DAIF value */
> -       mrs     x4, DAIF
> +  /* Save original DAIF value */
> +  mrs  x4, DAIF
>  #ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
> -       mov     x8, XZR
> -       mov     x9, XZR
> -       mov     x10, XZR
> -       mov     x11, XZR
> -       mov     x12, XZR
> -       mov     x13, XZR
> -       mov     x14, XZR
> -       mov     x15, XZR
> +  mov x8, XZR
> +  mov x9, XZR
> +  mov x10, XZR
> +  mov x11, XZR
> +  mov x12, XZR
> +  mov x13, XZR
> +  mov x14, XZR
> +  mov x15, XZR
>  #endif
> -        * SPx: the stack pointer corresponding to the current exception level
> -        * Normal operation for RTEMS on AArch64 uses SPx and runs on EL1
> -        * Exception operation (synchronous errors, IRQ, FIQ, System Errors) uses SP0
> +   * SPx: the stack pointer corresponding to the current exception level
> +   * Normal operation for RTEMS on AArch64 uses SPx and runs on EL1
> +   * Exception operation (synchronous errors, IRQ, FIQ, System Errors) uses SP0
> -       ldr     w1, =bsp_stack_exception_size
> +  ldr w1, =bsp_stack_exception_size
>  #else
> -       ldr     x1, =bsp_stack_exception_size
> +  ldr x1, =bsp_stack_exception_size
>  #endif
> -       /* Switch to SP0 and set exception stack */
> -       msr     spsel, #0
> -       mov     sp, x3
> -       /* Switch back to SPx for normal operation */
> -       msr     spsel, #1
> -       sub     x3, x3, x1
> +  /* Switch to SP0 and set exception stack */
> +  msr spsel, #0
> +  mov sp, x3
> +  /* Switch back to SPx for normal operation */
> +  msr spsel, #1
> +  sub x3, x3, x1
> -       /* Set SP1 stack used for normal operation */
> -       mov     sp, x3
> +  /* Set SP1 stack used for normal operation */
> +  mov sp, x3
> -       /* Stay in EL1 mode */
> +  /* Stay in EL1 mode */
>  #ifdef AARCH64_MULTILIB_HAS_CPACR
> -       /* Read CPACR */
> -       mrs x0, CPACR_EL1
> +  /* Read CPACR */
> +  mrs x0, CPACR_EL1
> -       /* Enable EL1 access permissions for CP10 */
> -       orr x0, x0, #(1 << 20)
> +  /* Enable EL1 access permissions for CP10 */
> +  orr x0, x0, #(1 << 20)
> -       /* Write CPACR */
> -       msr CPACR_EL1, x0
> -       isb
> +  /* Write CPACR */
> +  msr CPACR_EL1, x0
> +  isb
>  #endif
> -       /* FPU does not need to be enabled on AArch64 */
> +  /* FPU does not need to be enabled on AArch64 */
> -       mov     x0, #0
> -       mov     CPTR_EL3, XZR
> -       mov     CPTR_EL2, XZR
> -       mov     d0, XZR
> -       mov     d1, XZR
> -       mov     d2, XZR
> -       mov     d3, XZR
> -       mov     d4, XZR
> -       mov     d5, XZR
> -       mov     d6, XZR
> -       mov     d7, XZR
> -       mov     d8, XZR
> -       mov     d9, XZR
> -       mov     d10, XZR
> -       mov     d11, XZR
> -       mov     d12, XZR
> -       mov     d13, XZR
> -       mov     d14, XZR
> -       mov     d15, XZR
> -       mov     d16, XZR
> -       mov     d17, XZR
> -       mov     d18, XZR
> -       mov     d19, XZR
> -       mov     d20, XZR
> -       mov     d21, XZR
> -       mov     d22, XZR
> -       mov     d23, XZR
> -       mov     d24, XZR
> -       mov     d25, XZR
> -       mov     d26, XZR
> -       mov     d27, XZR
> -       mov     d28, XZR
> -       mov     d29, XZR
> -       mov     d30, XZR
> -       mov     d31, XZR
> +  mov x0, #0
> +  mov CPTR_EL3, XZR
> +  mov CPTR_EL2, XZR
> +  mov d0, XZR
> +  mov d1, XZR
> +  mov d2, XZR
> +  mov d3, XZR
> +  mov d4, XZR
> +  mov d5, XZR
> +  mov d6, XZR
> +  mov d7, XZR
> +  mov d8, XZR
> +  mov d9, XZR
> +  mov d10, XZR
> +  mov d11, XZR
> +  mov d12, XZR
> +  mov d13, XZR
> +  mov d14, XZR
> +  mov d15, XZR
> +  mov d16, XZR
> +  mov d17, XZR
> +  mov d18, XZR
> +  mov d19, XZR
> +  mov d20, XZR
> +  mov d21, XZR
> +  mov d22, XZR
> +  mov d23, XZR
> +  mov d24, XZR
> +  mov d25, XZR
> +  mov d26, XZR
> +  mov d27, XZR
> +  mov d28, XZR
> +  mov d29, XZR
> +  mov d30, XZR
> +  mov d31, XZR
>  #endif /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
>  #endif /* AARCH64_MULTILIB_VFP */
> -        * Invoke the start hook 0.
> +   * Invoke the start hook 0.
> -       mov     x1, x5          /* machine type number or ~0 for DT boot */
> -       bl      bsp_start_hook_0
> +  mov x1, x5    /* machine type number or ~0 for DT boot */
> +  bl bsp_start_hook_0
> -       /* Branch to start hook 1 */
> -       bl      bsp_start_hook_1
> +  /* Branch to start hook 1 */
> +  bl bsp_start_hook_1
> -       /* Branch to boot card */
> -       mov     x0, #0
> -       bl      boot_card
> +  /* Branch to boot card */
> +  mov x0, #0
> +  bl boot_card
> 2.25.1
