[PATCH rtems] bsps/powerpc, bsps/shared: Move remaining legacy networking header files
Vijay Kumar Banerjee
vijay at rtems.org
Fri Jun 25 04:05:16 UTC 2021
On Wed, Jun 23, 2021 at 3:26 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jun 23, 2021, 2:31 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> On Wed, Jun 23, 2021 at 1:24 PM Joel Sherrill <joel at rtems.org> wrote:
>> > Assuming you built the bsps in question, I'm ok with this.
>> I tested the build and install for both the bsps involved.
> Then I'm cool with pushing it.
Pushed this along with the corresponding legacy stack commit.
>> > Any insight info the tftp code? Did it really need rtems_bsdnet.h?
>> It looks like, the tftp code uses the hostname and
>> rtems_bsdnet_bootp_server_address from the legacy stack. The
>> rtems_bsdnet.h has the extern declaration for it. I couldn't come up
>> with a clean solution to add the values to tftp code. Any suggestion?
>> Or we can make copies of this in each stack.
> Is there an equivalent method in the new stack? This may be a case for some level of compatibility between them for RTEMS specifics.
>> I'm planning to work on two different networking submodule
>> "net-services" and "net-drivers" for the common services and to expand
>> the driver support for each stack. This can shift to the services repo
>> later if we make copies of it as a temporary workaround.
> Also the old network demos are stack independent past initialization. They just need a bsp/lab specific configuration to be useful. The default configuration is loopback which isn't useful for testing or showing basic use of features.
> This part should be a separate thread. :)
Started the work on the submodule. That's in a different thread already. :D
Thanks,
Vijay
>> > On Wed, Jun 23, 2021, 2:21 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> >> bsps/headers.am | 3 -
>> >> bsps/include/grlib/greth.h | 165 --
>> >> bsps/include/grlib/network_interface_add.h | 47 -
>> >> bsps/powerpc/beatnik/headers.am | 3 -
>> >> bsps/powerpc/beatnik/include/bsp/if_em_pub.h | 22 -
>> >> bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h | 30 -
>> >> bsps/powerpc/beatnik/include/bsp/if_mve_pub.h | 426 -----
>> >> bsps/shared/grlib/net/greth.c | 1663 -----------------
>> >> spec/build/bsps/objgrlib.yml | 2 -
>> >> .../build/bsps/powerpc/beatnik/bspbeatnik.yml | 3 -
>> >> 10 files changed, 2364 deletions(-)
>> >> delete mode 100644 bsps/include/grlib/greth.h
>> >> delete mode 100644 bsps/include/grlib/network_interface_add.h
>> >> delete mode 100644 bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> >> delete mode 100644 bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> >> delete mode 100644 bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> >> delete mode 100644 bsps/shared/grlib/net/greth.c
>> >> diff --git a/bsps/headers.am b/bsps/headers.am
>> >> index b89e5c2b28..b5821564b1 100644
>> >> --- a/bsps/headers.am
>> >> +++ b/bsps/headers.am
>> >> @@ -82,7 +82,6 @@ include_grlib_HEADERS += ../../bsps/include/grlib/gradcdac.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/grascs.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/grcan.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/grctm.h
>> >> -include_grlib_HEADERS += ../../bsps/include/grlib/greth.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/grgpio.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/griommu.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/grlib.h
>> >> @@ -102,7 +101,6 @@ include_grlib_HEADERS += ../../bsps/include/grlib/l2c.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/l4stat.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/mctrl.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/memscrub.h
>> >> -include_grlib_HEADERS += ../../bsps/include/grlib/network_interface_add.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/occan.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/pcif.h
>> >> include_grlib_HEADERS += ../../bsps/include/grlib/satcan.h
>> >> @@ -118,7 +116,6 @@ include_libchip_HEADERS += ../../bsps/include/libchip/ata.h
>> >> include_libchip_HEADERS += ../../bsps/include/libchip/ata_internal.h
>> >> include_libchip_HEADERS += ../../bsps/include/libchip/disp_hcms29xx.h
>> >> include_libchip_HEADERS += ../../bsps/include/libchip/ds1375-rtc.h
>> >> -include_libchip_HEADERS += ../../bsps/include/libchip/greth.h
>> >> include_libchip_HEADERS += ../../bsps/include/libchip/i2c-2b-eeprom.h
>> >> include_libchip_HEADERS += ../../bsps/include/libchip/i2c-ds1621.h
>> >> include_libchip_HEADERS += ../../bsps/include/libchip/i2c-sc620.h
>> >> diff --git a/bsps/include/grlib/greth.h b/bsps/include/grlib/greth.h
>> >> deleted file mode 100644
>> >> index e7970a79f7..0000000000
>> >> --- a/bsps/include/grlib/greth.h
>> >> +++ /dev/null
>> >> @@ -1,165 +0,0 @@
>> >> - * Cobham Gaisler ethernet MAC driver
>> >> - * adapted from Opencores driver by Marko Isomaki
>> >> - * The license and distribution terms for this file may be
>> >> - * found in found in the file LICENSE in this distribution or at
>> >> - * http://www.rtems.org/license/LICENSE.
>> >> -#ifndef __GRETH_H__
>> >> -#define __GRETH_H__
>> >> -#ifdef __cplusplus
>> >> -extern "C" {
>> >> -#endif
>> >> -/* Ethernet configuration registers */
>> >> -typedef struct _greth_regs {
>> >> - volatile uint32_t ctrl; /* Ctrl Register */
>> >> - volatile uint32_t status; /* Status Register */
>> >> - volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
>> >> - volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
>> >> - volatile uint32_t mdio_ctrl; /* MDIO control and status */
>> >> - volatile uint32_t txdesc; /* Transmit descriptor pointer */
>> >> - volatile uint32_t rxdesc; /* Receive descriptor pointer */
>> >> - volatile uint32_t edcl; /* EDCL IP register */
>> >> - volatile uint32_t ht_msb; /* Multicast MSB hash */
>> >> - volatile uint32_t ht_lsb; /* Multicast LSB hash */
>> >> -} greth_regs;
>> >> -#define GRETH_TOTAL_BD 128
>> >> -#define GRETH_MAXBUF_LEN 1520
>> >> -/* Tx BD */
>> >> -#define GRETH_TXD_ENABLE 0x0800 /* Tx BD Enable */
>> >> -#define GRETH_TXD_WRAP 0x1000 /* Tx BD Wrap (last BD) */
>> >> -#define GRETH_TXD_IRQ 0x2000 /* Tx BD IRQ Enable */
>> >> -#define GRETH_TXD_MORE 0x20000 /* Tx BD More (more descs for packet) */
>> >> -#define GRETH_TXD_IPCS 0x40000 /* Tx BD insert ip chksum */
>> >> -#define GRETH_TXD_TCPCS 0x80000 /* Tx BD insert tcp chksum */
>> >> -#define GRETH_TXD_UDPCS 0x100000 /* Tx BD insert udp chksum */
>> >> -#define GRETH_TXD_UNDERRUN 0x4000 /* Tx BD Underrun Status */
>> >> -#define GRETH_TXD_RETLIM 0x8000 /* Tx BD Retransmission Limit Status */
>> >> -#define GRETH_TXD_LATECOL 0x10000 /* Tx BD Late Collision */
>> >> -#define GRETH_TXD_STATS (GRETH_TXD_UNDERRUN | \
>> >> - GRETH_TXD_RETLIM | \
>> >> - GRETH_TXD_LATECOL)
>> >> -#define GRETH_TXD_CS (GRETH_TXD_IPCS | \
>> >> - GRETH_TXD_TCPCS | \
>> >> - GRETH_TXD_UDPCS)
>> >> -/* Rx BD */
>> >> -#define GRETH_RXD_ENABLE 0x0800 /* Rx BD Enable */
>> >> -#define GRETH_RXD_WRAP 0x1000 /* Rx BD Wrap (last BD) */
>> >> -#define GRETH_RXD_IRQ 0x2000 /* Rx BD IRQ Enable */
>> >> -#define GRETH_RXD_DRIBBLE 0x4000 /* Rx BD Dribble Nibble Status */
>> >> -#define GRETH_RXD_TOOLONG 0x8000 /* Rx BD Too Long Status */
>> >> -#define GRETH_RXD_CRCERR 0x10000 /* Rx BD CRC Error Status */
>> >> -#define GRETH_RXD_OVERRUN 0x20000 /* Rx BD Overrun Status */
>> >> -#define GRETH_RXD_LENERR 0x40000 /* Rx BD Length Error */
>> >> -#define GRETH_RXD_ID 0x40000 /* Rx BD IP Detected */
>> >> -#define GRETH_RXD_IR 0x40000 /* Rx BD IP Chksum Error */
>> >> -#define GRETH_RXD_UD 0x40000 /* Rx BD UDP Detected*/
>> >> -#define GRETH_RXD_UR 0x40000 /* Rx BD UDP Chksum Error */
>> >> -#define GRETH_RXD_TD 0x40000 /* Rx BD TCP Detected */
>> >> -#define GRETH_RXD_TR 0x40000 /* Rx BD TCP Chksum Error */
>> >> -#define GRETH_RXD_STATS (GRETH_RXD_OVERRUN | \
>> >> - GRETH_RXD_DRIBBLE | \
>> >> - GRETH_RXD_TOOLONG | \
>> >> - GRETH_RXD_CRCERR)
>> >> -/* CTRL Register */
>> >> -#define GRETH_CTRL_TXEN 0x00000001 /* Transmit Enable */
>> >> -#define GRETH_CTRL_RXEN 0x00000002 /* Receive Enable */
>> >> -#define GRETH_CTRL_TXIRQ 0x00000004 /* Transmit Enable */
>> >> -#define GRETH_CTRL_RXIRQ 0x00000008 /* Receive Enable */
>> >> -#define GRETH_CTRL_FULLD 0x00000010 /* Full Duplex */
>> >> -#define GRETH_CTRL_PRO 0x00000020 /* Promiscuous (receive all) */
>> >> -#define GRETH_CTRL_RST 0x00000040 /* Reset MAC */
>> >> -#define GRETH_CTRL_SP 0x00000080 /* 100MBit speed mode */
>> >> -#define GRETH_CTRL_GB 0x00000100 /* 1GBit speed mode */
>> >> -#define GRETH_CTRL_MCE 0x00000800 /* Multicast Enable */
>> >> -#define GRETH_CTRL_DD 0x00001000 /* Disable EDCL Duplex Detection */
>> >> -#define GRETH_CTRL_ED 0x00004000 /* EDCL Disable */
>> >> -#define GRETH_CTRL_MC 0x02000000 /* Multicast available */
>> >> -#define GRETH_CTRL_ME 0x04000000 /* MDIO interrupts enabled */
>> >> -#define GRETH_CTRL_GA 0x08000000 /* Gigabit MAC available */
>> >> -/* Status Register */
>> >> -#define GRETH_STATUS_RXERR 0x00000001 /* Receive Error */
>> >> -#define GRETH_STATUS_TXERR 0x00000002 /* Transmit Error IRQ */
>> >> -#define GRETH_STATUS_RXIRQ 0x00000004 /* Receive Frame IRQ */
>> >> -#define GRETH_STATUS_TXIRQ 0x00000008 /* Transmit Error IRQ */
>> >> -#define GRETH_STATUS_RXAHBERR 0x00000010 /* Receiver AHB Error */
>> >> -#define GRETH_STATUS_TXAHBERR 0x00000020 /* Transmitter AHB Error */
>> >> -#define GRETH_STATUS_NRD 0x0f000000 /* Number of descriptors */
>> >> -/* MDIO Control */
>> >> -#define GRETH_MDIO_WRITE 0x00000001 /* MDIO Write */
>> >> -#define GRETH_MDIO_READ 0x00000002 /* MDIO Read */
>> >> -#define GRETH_MDIO_LINKFAIL 0x00000004 /* MDIO Link failed */
>> >> -#define GRETH_MDIO_BUSY 0x00000008 /* MDIO Link Busy */
>> >> -#define GRETH_MDIO_REGADR 0x000007C0 /* Register Address */
>> >> -#define GRETH_MDIO_PHYADR 0x0000F800 /* PHY address */
>> >> -#define GRETH_MDIO_DATA 0xFFFF0000 /* MDIO DATA */
>> >> -/* MII registers */
>> >> -#define GRETH_MII_EXTADV_1000FD 0x00000200
>> >> -#define GRETH_MII_EXTADV_1000HD 0x00000100
>> >> -#define GRETH_MII_EXTPRT_1000FD 0x00000800
>> >> -#define GRETH_MII_EXTPRT_1000HD 0x00000400
>> >> -#define GRETH_MII_100T4 0x00000200
>> >> -#define GRETH_MII_100TXFD 0x00000100
>> >> -#define GRETH_MII_100TXHD 0x00000080
>> >> -#define GRETH_MII_10FD 0x00000040
>> >> -#define GRETH_MII_10HD 0x00000020
>> >> -/* Attach routine */
>> >> -void greth_register_drv(void);
>> >> -/* PHY data */
>> >> -struct phy_device_info
>> >> - int vendor;
>> >> - int device;
>> >> - int rev;
>> >> - int adv;
>> >> - int part;
>> >> - int extadv;
>> >> - int extpart;
>> >> -/* Limit speed modes advertised during auto-negotiation */
>> >> -#define GRETH_ADV_10_HD 0x0001
>> >> -#define GRETH_ADV_10_FD 0x0002
>> >> -#define GRETH_ADV_100_HD 0x0004
>> >> -#define GRETH_ADV_100_FD 0x0008
>> >> -#define GRETH_ADV_1000_HD 0x0010
>> >> -#define GRETH_ADV_1000_FD 0x0020
>> >> -#define GRETH_ADV_ALL 0x003f
>> >> -#ifdef CPU_U32_FIX
>> >> -void ipalign(struct mbuf *m);
>> >> -#endif
>> >> -#ifdef __cplusplus
>> >> -#endif
>> >> -#endif
>> >> diff --git a/bsps/include/grlib/network_interface_add.h b/bsps/include/grlib/network_interface_add.h
>> >> index b04a96f003..0000000000
>> >> --- a/bsps/include/grlib/network_interface_add.h
>> >> +++ /dev/null
>> >> @@ -1,47 +0,0 @@
>> >> -/* Network interface register help function
>> >> - * COPYRIGHT (c) 2008.
>> >> - * Cobham Gaisler AB.
>> >> - * This function adds a network interface to the
>> >> - * rtems_bsdnet_config.ifconfig linked list of interfaces.
>> >> - * The interface configuration is taken from the user defined
>> >> - * array interface_configs. This function is useful for PnP
>> >> - * systems when an unknown number of interfaces are available.
>> >> -#ifndef __NETWORK_INTERFACE_ADD_H__
>> >> -#define __NETWORK_INTERFACE_ADD_H__
>> >> -#include <rtems/rtems_bsdnet.h>
>> >> -#ifdef __cplusplus
>> >> -extern "C" {
>> >> -#endif
>> >> -/* Interface configuration description */
>> >> -struct ethernet_config {
>> >> - char *ip_addr; /* IP address */
>> >> - char *ip_netmask; /* IP Netmask */
>> >> - char eth_adr[6]; /* Ethernet hardware MAC address */
>> >> -/* Array with configurations for all interfaces in the system
>> >> - * Must be defined by the user.
>> >> -extern struct ethernet_config interface_configs[];
>> >> -/* Routine adding interface to rtems_bsdnet_config.ifconfig linked
>> >> - * list of interfaces.
>> >> -int network_interface_add(struct rtems_bsdnet_ifconfig *interface);
>> >> -#ifdef __cplusplus
>> >> -#endif
>> >> -#endif /* _RTEMS_NETWORKCONFIG_H_ */
>> >> diff --git a/bsps/powerpc/beatnik/headers.am b/bsps/powerpc/beatnik/headers.am
>> >> index 36df3cd759..364ea222a8 100644
>> >> --- a/bsps/powerpc/beatnik/headers.am
>> >> +++ b/bsps/powerpc/beatnik/headers.am
>> >> @@ -16,7 +16,4 @@ include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gti2cr
>> >> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gtintrreg.h
>> >> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gtpcireg.h
>> >> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/gtreg.h
>> >> -include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> >> -include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> >> -include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> >> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/irq.h
>> >> diff --git a/bsps/powerpc/beatnik/include/bsp/if_em_pub.h b/bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> >> index eb970e465b..0000000000
>> >> --- a/bsps/powerpc/beatnik/include/bsp/if_em_pub.h
>> >> +++ /dev/null
>> >> @@ -1,22 +0,0 @@
>> >> -#ifndef RTEMS_BSDNET_IF_EM_PUBLIC_SYMBOLS_H
>> >> -#define RTEMS_BSDNET_IF_EM_PUBLIC_SYMBOLS_H
>> >> -#include <rtems.h>
>> >> -#include <bsp/early_enet_link_status.h>
>> >> -#ifdef __cplusplus
>> >> - extern "C" {
>> >> -#endif
>> >> -extern int rtems_em_attach(struct rtems_bsdnet_ifconfig *, int);
>> >> -extern int rtems_em_pci_setup(int);
>> >> -extern rtems_bsdnet_early_link_check_ops rtems_em_early_link_check_ops;
>> >> -#ifdef __cplusplus
>> >> -#endif
>> >> -#endif
>> >> diff --git a/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h b/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> >> index 8ea849efb1..0000000000
>> >> --- a/bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
>> >> +++ /dev/null
>> >> @@ -1,30 +0,0 @@
>> >> -#ifndef RTEMS_BSDNET_IF_GFE_PUBLIC_SYMBOLS_H
>> >> -#define RTEMS_BSDNET_IF_GFE_PUBLIC_SYMBOLS_H
>> >> -#include <rtems.h>
>> >> -#include <net/ethernet.h>
>> >> -#ifdef __cplusplus
>> >> - extern "C" {
>> >> -#endif
>> >> -extern int
>> >> -rtems_gfe_attach(struct rtems_bsdnet_ifconfig *, int);
>> >> -/* enet_addr must be 6 bytes long */
>> >> -int
>> >> -rtems_gfe_setup(int unit, char *enet_addr, uint32_t base_addr);
>> >> -rtems_gfe_early_link_check_ops;
>> >> -#ifdef __cplusplus
>> >> -#endif
>> >> -#endif
>> >> diff --git a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h b/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> >> index 46cc4ccd23..0000000000
>> >> --- a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
>> >> +++ /dev/null
>> >> @@ -1,426 +0,0 @@
>> >> -#ifndef RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
>> >> -#define RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
>> >> - * Authorship
>> >> - * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
>> >> - * created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
>> >> - * Stanford Linear Accelerator Center, Stanford University.
>> >> - * Acknowledgement of sponsorship
>> >> - * The 'beatnik' BSP was produced by
>> >> - * the Stanford Linear Accelerator Center, Stanford University,
>> >> - * under Contract DE-AC03-76SFO0515 with the Department of Energy.
>> >> - * Government disclaimer of liability
>> >> - * Neither the United States nor the United States Department of Energy,
>> >> - * nor any of their employees, makes any warranty, express or implied, or
>> >> - * assumes any legal liability or responsibility for the accuracy,
>> >> - * completeness, or usefulness of any data, apparatus, product, or process
>> >> - * disclosed, or represents that its use would not infringe privately owned
>> >> - * rights.
>> >> - * Stanford disclaimer of liability
>> >> - * Stanford University makes no representations or warranties, express or
>> >> - * implied, nor assumes any liability for the use of this software.
>> >> - * Stanford disclaimer of copyright
>> >> - * Stanford University, owner of the copyright, hereby disclaims its
>> >> - * copyright and all other rights in this software. Hence, anyone may
>> >> - * freely use it for any purpose without restriction.
>> >> - * Maintenance of notices
>> >> - * In the interest of clarity regarding the origin and status of this
>> >> - * SLAC software, this and all the preceding Stanford University notices
>> >> - * are to remain affixed to any copy or derivative of this software made
>> >> - * or distributed by the recipient and are to be affixed to any copy of
>> >> - * software made or distributed by the recipient that contains a copy or
>> >> - * derivative of this software.
>> >> - * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
>> >> -#include <rtems.h>
>> >> -#include <stdint.h>
>> >> -#ifdef __cplusplus
>> >> - extern "C" {
>> >> -#endif
>> >> -extern int rtems_mve_attach(struct rtems_bsdnet_ifconfig *, int);
>> >> -extern rtems_bsdnet_early_link_check_ops rtems_mve_early_link_check_ops;
>> >> -/* Low-level Driver API.
>> >> - * This provides driver access to applications that want to use e.g., the second
>> >> - * ethernet interface w/o running the BSD TCP/IP stack.
>> >> -/* Opaque handle */
>> >> -struct mveth_private;
>> >> -/* Direct assignment of MVE flags to user API relies on irqs and x-irqs not overlapping */
>> >> -#define BSP_MVE_IRQ_RX (1<<2)
>> >> -#define BSP_MVE_IRQ_TX (1<<0)
>> >> -#define BSP_MVE_IRQ_LINK (1<<16)
>> >> -/* Setup an interface.
>> >> - * Allocates resources for descriptor rings and sets up the driver software structure.
>> >> - * Arguments:
>> >> - * unit:
>> >> - * interface # (1..2). The interface must not be attached to BSD.
>> >> - * driver_tid:
>> >> - * ISR posts RTEMS event # ('unit' - 1) to task with ID 'driver_tid' and disables interrupts
>> >> - * from this interface.
>> >> - * void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred):
>> >> - * Pointer to user-supplied callback to release a buffer that had been sent
>> >> - * by BSP_mve_send_buf() earlier. The callback is passed 'cleanup_txbuf_arg'
>> >> - * and a flag indicating whether the send had been successful.
>> >> - * The driver no longer accesses 'user_buf' after invoking this callback.
>> >> - * CONTEXT: This callback is executed either by BSP_mve_swipe_tx() or
>> >> - * BSP_mve_send_buf(), BSP_mve_init_hw(), BSP_mve_stop_hw() (the latter
>> >> - * ones calling BSP_mve_swipe_tx()).
>> >> - * void *cleanup_txbuf_arg:
>> >> - * Closure argument that is passed on to 'cleanup_txbuf()' callback;
>> >> - * void *(*alloc_rxbuf)(int *p_size, unsigned long *p_data_addr),
>> >> - * Pointer to user-supplied callback to allocate a buffer for subsequent
>> >> - * insertion into the RX ring by the driver.
>> >> - * RETURNS: opaque handle to the buffer (which may be a more complex object
>> >> - * such as an 'mbuf'). The handle is not used by the driver directly
>> >> - * but passed back to the 'consume_rxbuf()' callback.
>> >> - * Size of the available data area and pointer to buffer's data area
>> >> - * in '*psize' and '*p_data_area', respectively.
>> >> - * If no buffer is available, this routine should return NULL in which
>> >> - * case the driver drops the last packet and re-uses the last buffer
>> >> - * instead of handing it out to 'consume_rxbuf()'.
>> >> - * CONTEXT: Called when initializing the RX ring (BSP_mve_init_hw()) or when
>> >> - * swiping it (BSP_mve_swipe_rx()).
>> >> - * void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len);
>> >> - * Pointer to user-supplied callback to pass a received buffer back to
>> >> - * the user. The driver no longer accesses the buffer after invoking this
>> >> - * callback (with 'len'>0, see below). 'user_buf' is the buffer handle
>> >> - * previously generated by 'alloc_rxbuf()'.
>> >> - * The callback is passed 'cleanup_rxbuf_arg' and a 'len'
>> >> - * argument giving the number of bytes that were received.
>> >> - * 'len' may be <=0 in which case the 'user_buf' argument is NULL.
>> >> - * 'len' == 0 means that the last 'alloc_rxbuf()' had failed,
>> >> - * 'len' < 0 indicates a receiver error. In both cases, the last packet
>> >> - * was dropped/missed and the last buffer will be re-used by the driver.
>> >> - * NOTE: the data are 'prefixed' with two bytes, i.e., the ethernet packet header
>> >> - * is stored at offset 2 in the buffer's data area. Also, the FCS (4 bytes)
>> >> - * is appended. 'len' accounts for both.
>> >> - * CONTEXT: Called from BSP_mve_swipe_rx().
>> >> - * void *cleanup_rxbuf_arg:
>> >> - * Closure argument that is passed on to 'consume_rxbuf()' callback;
>> >> - * rx_ring_size, tx_ring_size:
>> >> - * How many big to make the RX and TX descriptor rings. Note that the sizes
>> >> - * may be 0 in which case a reasonable default will be used.
>> >> - * If either ring size is < 0 then the RX or TX will be disabled.
>> >> - * Note that it is illegal in this case to use BSP_mve_swipe_rx() or
>> >> - * BSP_mve_swipe_tx(), respectively.
>> >> - * irq_mask:
>> >> - * Interrupts to enable. OR of flags from above.
>> >> -struct mveth_private *
>> >> -BSP_mve_setup(
>> >> - int unit,
>> >> - rtems_id driver_tid,
>> >> - void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
>> >> - void *cleanup_txbuf_arg,
>> >> - void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
>> >> - void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len),
>> >> - void *consume_rxbuf_arg,
>> >> - int rx_ring_size,
>> >> - int tx_ring_size,
>> >> - int irq_mask
>> >> - * Alternate 'setup' routine allowing the user to install an ISR rather
>> >> - * than a task ID.
>> >> - * All parameters (other than 'isr' / 'isr_arg') and the return value
>> >> - * are identical to the BSP_mve_setup() entry point.
>> >> -BSP_mve_setup_1(
>> >> - int unit,
>> >> - void (*isr)(void *isr_arg),
>> >> - void *isr_arg,
>> >> - int rx_ring_size,
>> >> - int tx_ring_size,
>> >> - int irq_mask
>> >> - * Initialize interface hardware
>> >> - * 'mp' handle obtained by from BSP_mve_setup().
>> >> - * 'promisc' whether to set promiscuous flag.
>> >> - * 'enaddr' pointer to six bytes with MAC address. Read
>> >> - * from the device if NULL.
>> >> - * Note: Multicast filters are cleared by this routine.
>> >> - * However, in promiscuous mode the mcast filters
>> >> - * are programmed to accept all multicast frames.
>> >> -void
>> >> -BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
>> >> - * Clear multicast hash filter. No multicast frames are accepted
>> >> - * after executing this routine (unless the hardware was initialized
>> >> - * in 'promiscuous' mode).
>> >> -void
>> >> -BSP_mve_mcast_filter_clear(struct mveth_private *mp);
>> >> - * Program multicast filter to accept all multicast frames
>> >> -void
>> >> -BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
>> >> - * Add a MAC address to the multicast filter.
>> >> - * Existing entries are not changed but note that
>> >> - * the filter is imperfect, i.e., multiple MAC addresses
>> >> - * may alias to a single filter entry. Hence software
>> >> - * filtering must still be performed.
>> >> - * If a higher-level driver implements IP multicasting
>> >> - * then multiple IP addresses may alias to the same MAC
>> >> - * address. This driver maintains a 'reference-count'
>> >> - * which is incremented every time the same MAC-address
>> >> - * is passed to this routine; the address is only removed
>> >> - * from the filter if BSP_mve_mcast_filter_accept_del()
>> >> - * is called the same number of times (or by BSP_mve_mcast_filter_clear).
>> >> -void
>> >> -BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
>> >> - * Remove a MAC address from the multicast filter.
>> >> - * This routine decrements the reference count of the given
>> >> - * MAC-address and removes it from the filter once the
>> >> - * count reaches zero.
>> >> -void
>> >> -BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
>> >> - * Shutdown hardware and clean out the rings
>> >> -void
>> >> -BSP_mve_stop_hw(struct mveth_private *mp);
>> >> -/* calls BSP_mve_stop_hw(), releases all resources and marks the interface
>> >> - * as unused.
>> >> - * RETURNS 0 on success, nonzero on failure.
>> >> - * NOTE: the handle MUST NOT be used after successful execution of this
>> >> - * routine.
>> >> -int
>> >> -BSP_mve_detach(struct mveth_private *mp);
>> >> -int
>> >> -BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len,
>> >> - void *data_p, int d_len);
>> >> - * Enqueue a mbuf chain or a raw data buffer for transmission;
>> >> - * RETURN: #bytes sent or -1 if there are not enough free descriptors
>> >> - * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
>> >> - * OTOH, a raw data packet (or a different type of buffer)
>> >> - * may be send (non-BSD driver) by pointing data_p to the start of
>> >> - * the data and passing 'len' > 0.
>> >> - * 'm_head' is passed back to the 'cleanup_txbuf()' callback.
>> >> - * Comments: software cache-flushing incurs a penalty if the
>> >> - * packet cannot be queued since it is flushed anyways.
>> >> - * The algorithm is slightly more efficient in the normal
>> >> - * case, though.
>> >> - * RETURNS: # bytes enqueued to device for transmission or -1 if no
>> >> - * space in the TX ring was available.
>> >> -int
>> >> -BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len);
>> >> -/* Descriptor scavenger; cleanup the TX ring, passing all buffers
>> >> - * that have been sent to the cleanup_tx() callback.
>> >> - * This routine is called from BSP_mve_send_buf(), BSP_mve_init_hw(),
>> >> - * BSP_mve_stop_hw().
>> >> - * RETURNS: number of buffers processed.
>> >> -int
>> >> -BSP_mve_swipe_tx(struct mveth_private *mp);
>> >> -/* Retrieve all received buffers from the RX ring, replacing them
>> >> - * by fresh ones (obtained from the alloc_rxbuf() callback). The
>> >> - * received buffers are passed to consume_rxbuf().
>> >> -int
>> >> -BSP_mve_swipe_rx(struct mveth_private *mp);
>> >> -/* read ethernet address from hw to buffer */
>> >> -void
>> >> -BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *eaddr);
>> >> -/* read/write media word.
>> >> - * 'cmd': can be SIOCGIFMEDIA, SIOCSIFMEDIA, 0 or 1. The latter
>> >> - * are aliased to the former for convenience.
>> >> - * 'parg': pointer to media word.
>> >> - * RETURNS: 0 on success, nonzero on error
>> >> - * NOTE: This routine is thread-safe.
>> >> -int
>> >> -BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg);
>> >> -/* Interrupt related routines */
>> >> -/* Note: the BSP_mve_enable/disable/ack_irqs() entry points
>> >> - * are deprecated.
>> >> - * The newer API where the user passes a mask allows
>> >> - * for more selective control.
>> >> -/* Enable all supported interrupts at device */
>> >> -void
>> >> -BSP_mve_enable_irqs(struct mveth_private *mp);
>> >> -/* Disable all supported interrupts at device */
>> >> -void
>> >> -BSP_mve_disable_irqs(struct mveth_private *mp);
>> >> -/* Acknowledge (and clear) all supported interrupts.
>> >> - * RETURNS: interrupts that were raised.
>> >> -uint32_t
>> >> -BSP_mve_ack_irqs(struct mveth_private *mp);
>> >> -/* Enable interrupts included in 'mask' (leaving
>> >> - * already enabled interrupts on). If the mask
>> >> - * includes bits that were not passed to the 'setup'
>> >> - * routine then the behavior is undefined.
>> >> -void
>> >> -BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
>> >> -/* Disable interrupts included in 'mask' (leaving
>> >> - * other ones that are currently enabled on). If the
>> >> - * mask includes bits that were not passed to the 'setup'
>> >> - * RETURNS: Bitmask of interrupts that were enabled upon entry
>> >> - * into this routine. This can be used to restore the
>> >> - * previous state.
>> >> -uint32_t
>> >> -BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
>> >> -/* Acknowledge and clear selected interrupts.
>> >> - * RETURNS: All pending interrupts.
>> >> - * NOTE: Only pending interrupts contained in 'mask'
>> >> - * are cleared. Others are left pending.
>> >> - * This routine can be used to check for pending
>> >> - * interrupts (pass mask == 0) or to clear all
>> >> - * interrupts (pass mask == -1).
>> >> -uint32_t
>> >> -BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
>> >> -/* If the PHY link status changes then some
>> >> - * internal settings in the ethernet controller's
>> >> - * serial port need to be updated to match the
>> >> - * PHY settings. Use this routine to perform the
>> >> - * necessary steps after a link change has been
>> >> - * detected.
>> >> - * RETURNS: 0 on success, -1 if the PHY state
>> >> - * could not be determined.
>> >> - * The current state of the media as read
>> >> - * by BSP_mve_media_ioctl() is returned in
>> >> - * *pmedia.
>> >> - * NOTE: This routine calls BSP_mve_media_ioctl().
>> >> -int
>> >> -BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia);
>> >> -/* Retrieve the driver daemon TID that was passed to
>> >> - * BSP_mve_setup().
>> >> -rtems_id
>> >> -BSP_mve_get_tid(struct mveth_private *mp);
>> >> -/* Dump statistics to file (stdout if NULL)
>> >> - * NOTE: this routine is not thread safe
>> >> -void
>> >> -BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
>> >> - * Example driver task loop (note: no synchronization of
>> >> - * buffer access shown!).
>> >> - * RTEMS_EVENTx = 0,1 or 2 depending on IF unit.
>> >> - * / * setup (obtain handle) and initialize hw here * /
>> >> - * do {
>> >> - * / * ISR disables IRQs and posts event * /
>> >> - * rtems_event_receive( RTEMS_EVENTx, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
>> >> - * irqs = BSP_mve_ack_irqs(handle);
>> >> - * if ( irqs & BSP_MVE_IRQ_TX ) {
>> >> - * BSP_mve_swipe_tx(handle); / * cleanup_txbuf() callback executed * /
>> >> - * if ( irqs & BSP_MVE_IRQ_RX ) {
>> >> - * BSP_mve_swipe_rx(handle); / * alloc_rxbuf() and consume_rxbuf() executed * /
>> >> - * if ( irqs & BSP_MVE_IRQ_LINK ) {
>> >> - * / * update serial port settings from current link status * /
>> >> - * BSP_mve_ack_link_chg(handle, 0);
>> >> - * BSP_mve_enable_irqs(handle);
>> >> - * } while (1);
>> >> -#ifdef __cplusplus
>> >> -#endif
>> >> -#endif
>> >> diff --git a/bsps/shared/grlib/net/greth.c b/bsps/shared/grlib/net/greth.c
>> >> index 84efcd74ab..0000000000
>> >> --- a/bsps/shared/grlib/net/greth.c
>> >> +++ /dev/null
>> >> @@ -1,1663 +0,0 @@
>> >> - * Gaisler Research ethernet MAC driver
>> >> - * 2008-12-10, Converted to driver manager and added support for
>> >> - * multiple GRETH cores. <daniel at gaisler.com>
>> >> - * 2007-09-07, Ported GBIT support from 4.6.5
>> >> -#include <machine/rtems-bsd-kernel-space.h>
>> >> -#include <rtems.h>
>> >> -#define CPU_U32_FIX
>> >> -#include <bsp.h>
>> >> -#ifdef GRETH_SUPPORTED
>> >> -#include <inttypes.h>
>> >> -#include <errno.h>
>> >> -#include <rtems/bspIo.h>
>> >> -#include <stdlib.h>
>> >> -#include <stdio.h>
>> >> -#include <string.h>
>> >> -#include <stdarg.h>
>> >> -#include <rtems/error.h>
>> >> -#include <grlib/greth.h>
>> >> -#include <drvmgr/drvmgr.h>
>> >> -#include <grlib/ambapp_bus.h>
>> >> -#include <grlib/ambapp.h>
>> >> -#include <sys/param.h>
>> >> -#include <sys/mbuf.h>
>> >> -#include <sys/socket.h>
>> >> -#include <sys/sockio.h>
>> >> -#include <net/if.h>
>> >> -#include <netinet/in.h>
>> >> -#include <netinet/if_ether.h>
>> >> -#ifdef malloc
>> >> -#undef malloc
>> >> -#endif
>> >> -#ifdef free
>> >> -#undef free
>> >> -#endif
>> >> -#include <grlib/grlib_impl.h>
>> >> -#if defined(__m68k__)
>> >> -extern m68k_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
>> >> -#else
>> >> -extern rtems_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
>> >> -#endif
>> >> -/* #define GRETH_DEBUG */
>> >> -#ifdef GRETH_DEBUG
>> >> -#define DBG(args...) printk(args)
>> >> -#else
>> >> -#endif
>> >> -/* #define GRETH_DEBUG_MII */
>> >> -#ifdef GRETH_DEBUG_MII
>> >> -#define MIIDBG(args...) printk(args)
>> >> -#else
>> >> -#endif
>> >> -#ifdef CPU_U32_FIX
>> >> -extern void ipalign(struct mbuf *m);
>> >> -#endif
>> >> -/* Used when reading from memory written by GRETH DMA unit */
>> >> -#ifndef GRETH_MEM_LOAD
>> >> -#define GRETH_MEM_LOAD(addr) (*(volatile unsigned int *)(addr))
>> >> -#endif
>> >> - * Number of OCs supported by this driver
>> >> -#define NOCDRIVER 1
>> >> - * Receive buffer size -- Allow for a full ethernet packet including CRC
>> >> -#define RBUF_SIZE 1518
>> >> -#define ET_MINLEN 64 /* minimum message length */
>> >> - * RTEMS event used by interrupt handler to signal driver tasks.
>> >> - * This must not be any of the events used by the network task synchronization.
>> >> -#define INTERRUPT_EVENT RTEMS_EVENT_1
>> >> - * RTEMS event used to start transmit daemon.
>> >> - * This must not be the same as INTERRUPT_EVENT.
>> >> -#define START_TRANSMIT_EVENT RTEMS_EVENT_2
>> >> - /* event to send when tx buffers become available */
>> >> -#define GRETH_TX_WAIT_EVENT RTEMS_EVENT_3
>> >> -#if (MCLBYTES < RBUF_SIZE)
>> >> -# error "Driver must have MCLBYTES > RBUF_SIZE"
>> >> -#endif
>> >> -/* 4s Autonegotiation Timeout */
>> >> -#ifndef GRETH_AUTONEGO_TIMEOUT_MS
>> >> -#define GRETH_AUTONEGO_TIMEOUT_MS 4000
>> >> -#endif
>> >> -const struct timespec greth_tan = {
>> >> - GRETH_AUTONEGO_TIMEOUT_MS/1000,
>> >> - (GRETH_AUTONEGO_TIMEOUT_MS % 1000) * 1000000
>> >> -/* For optimizing the autonegotiation time */
>> >> -#define GRETH_AUTONEGO_PRINT_TIME
>> >> -/* Ethernet buffer descriptor */
>> >> -typedef struct _greth_rxtxdesc {
>> >> - volatile uint32_t ctrl; /* Length and status */
>> >> - uint32_t *addr; /* Buffer pointer */
>> >> -} greth_rxtxdesc;
>> >> - * Per-device data
>> >> -struct greth_softc
>> >> - struct arpcom arpcom;
>> >> - struct drvmgr_dev *dev; /* Driver manager device */
>> >> - char devName[32];
>> >> - greth_regs *regs;
>> >> - int minor;
>> >> - int phyaddr; /* PHY Address configured by user (or -1 to autodetect) */
>> >> - unsigned int edcl_dis;
>> >> - int greth_rst;
>> >> - int acceptBroadcast;
>> >> - rtems_id daemonTid;
>> >> - unsigned int tx_ptr;
>> >> - unsigned int tx_dptr;
>> >> - unsigned int tx_cnt;
>> >> - unsigned int rx_ptr;
>> >> - unsigned int txbufs;
>> >> - unsigned int rxbufs;
>> >> - greth_rxtxdesc *txdesc;
>> >> - greth_rxtxdesc *rxdesc;
>> >> - unsigned int txdesc_remote;
>> >> - unsigned int rxdesc_remote;
>> >> - struct mbuf **rxmbuf;
>> >> - struct mbuf **txmbuf;
>> >> - rtems_vector_number vector;
>> >> - /* TX descriptor interrupt generation */
>> >> - int tx_int_gen;
>> >> - int tx_int_gen_cur;
>> >> - struct mbuf *next_tx_mbuf;
>> >> - int max_fragsize;
>> >> - /*Status*/
>> >> - struct phy_device_info phydev;
>> >> - int phy_read_access;
>> >> - int phy_write_access;
>> >> - int fd;
>> >> - int sp;
>> >> - int gb;
>> >> - int gbit_mac;
>> >> - int auto_neg;
>> >> - unsigned int advmodes; /* advertise ethernet speed modes. 0 = all modes. */
>> >> - struct timespec auto_neg_time;
>> >> - int mc_available;
>> >> - int num_descs;
>> >> - * Statistics
>> >> - unsigned long rxInterrupts;
>> >> - unsigned long rxPackets;
>> >> - unsigned long rxLengthError;
>> >> - unsigned long rxNonOctet;
>> >> - unsigned long rxBadCRC;
>> >> - unsigned long rxOverrun;
>> >> - unsigned long txInterrupts;
>> >> - unsigned long txDeferred;
>> >> - unsigned long txHeartbeat;
>> >> - unsigned long txLateCollision;
>> >> - unsigned long txRetryLimit;
>> >> - unsigned long txUnderrun;
>> >> - /* Spin-lock ISR protection */
>> >> - SPIN_DECLARE(devlock);
>> >> -int greth_process_tx_gbit(struct greth_softc *sc);
>> >> -int greth_process_tx(struct greth_softc *sc);
>> >> -static char *almalloc(int sz, int alignment)
>> >> - char *tmp;
>> >> - tmp = grlib_calloc(1, sz + (alignment-1));
>> >> - tmp = (char *) (((int)tmp+alignment) & ~(alignment -1));
>> >> - return(tmp);
>> >> -/* GRETH interrupt handler */
>> >> -static void greth_interrupt (void *arg)
>> >> - uint32_t status;
>> >> - uint32_t ctrl;
>> >> - rtems_event_set events = 0;
>> >> - struct greth_softc *greth = arg;
>> >> - SPIN_ISR_IRQFLAGS(flags);
>> >> - /* read and clear interrupt cause */
>> >> - status = greth->regs->status;
>> >> - greth->regs->status = status;
>> >> - SPIN_LOCK(&greth->devlock, flags);
>> >> - ctrl = greth->regs->ctrl;
>> >> - /* Frame received? */
>> >> - if ((ctrl & GRETH_CTRL_RXIRQ) && (status & (GRETH_STATUS_RXERR | GRETH_STATUS_RXIRQ)))
>> >> - greth->rxInterrupts++;
>> >> - /* Stop RX-Error and RX-Packet interrupts */
>> >> - ctrl &= ~GRETH_CTRL_RXIRQ;
>> >> - events |= INTERRUPT_EVENT;
>> >> - if ( (ctrl & GRETH_CTRL_TXIRQ) && (status & (GRETH_STATUS_TXERR | GRETH_STATUS_TXIRQ)) )
>> >> - greth->txInterrupts++;
>> >> - ctrl &= ~GRETH_CTRL_TXIRQ;
>> >> - events |= GRETH_TX_WAIT_EVENT;
>> >> - /* Clear interrupt sources */
>> >> - greth->regs->ctrl = ctrl;
>> >> - SPIN_UNLOCK(&greth->devlock, flags);
>> >> - /* Send the event(s) */
>> >> - if ( events )
>> >> - rtems_bsdnet_event_send(greth->daemonTid, events);
>> >> -static uint32_t read_mii(struct greth_softc *sc, uint32_t phy_addr, uint32_t reg_addr)
>> >> - sc->phy_read_access++;
>> >> - while (sc->regs->mdio_ctrl & GRETH_MDIO_BUSY) {}
>> >> - sc->regs->mdio_ctrl = (phy_addr << 11) | (reg_addr << 6) | GRETH_MDIO_READ;
>> >> - if (!(sc->regs->mdio_ctrl & GRETH_MDIO_LINKFAIL)) {
>> >> - MIIDBG("greth%d: mii read[%d] OK to %" PRIx32 ".%" PRIx32
>> >> - " (0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
>> >> - sc->minor, sc->phy_read_access, phy_addr, reg_addr,
>> >> - sc->regs->ctrl, sc->regs->mdio_ctrl);
>> >> - return((sc->regs->mdio_ctrl >> 16) & 0xFFFF);
>> >> - } else {
>> >> - printf("greth%d: mii read[%d] failed to %" PRIx32 ".%" PRIx32
>> >> - return (0xffff);
>> >> -static void write_mii(struct greth_softc *sc, uint32_t phy_addr, uint32_t reg_addr, uint32_t data)
>> >> - sc->phy_write_access++;
>> >> - ((data & 0xFFFF) << 16) | (phy_addr << 11) | (reg_addr << 6) | GRETH_MDIO_WRITE;
>> >> - MIIDBG("greth%d: mii write[%d] OK to to %" PRIx32 ".%" PRIx32
>> >> - "(0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
>> >> - sc->minor, sc->phy_write_access, phy_addr, reg_addr,
>> >> - } else {
>> >> - printf("greth%d: mii write[%d] failed to to %" PRIx32 ".%" PRIx32
>> >> -static void print_init_info(struct greth_softc *sc)
>> >> - printf("greth: driver attached\n");
>> >> - if ( sc->auto_neg == -1 ){
>> >> - printf("Auto negotiation timed out. Selecting default config\n");
>> >> - printf("**** PHY ****\n");
>> >> - printf("Vendor: %x Device: %x Revision: %d\n",sc->phydev.vendor, sc->phydev.device, sc->phydev.rev);
>> >> - printf("Current Operating Mode: ");
>> >> - if (sc->gb) {
>> >> - printf("1000 Mbit ");
>> >> - } else if (sc->sp) {
>> >> - printf("100 Mbit ");
>> >> - } else {
>> >> - printf("10 Mbit ");
>> >> - if (sc->fd) {
>> >> - printf("Full Duplex\n");
>> >> - } else {
>> >> - printf("Half Duplex\n");
>> >> -#ifdef GRETH_AUTONEGO_PRINT_TIME
>> >> - if ( sc->auto_neg ) {
>> >> - printf("Autonegotiation Time: %" PRIdMAX "ms\n",
>> >> - (intmax_t)sc->auto_neg_time.tv_sec * 1000 +
>> >> - sc->auto_neg_time.tv_nsec / 1000000);
>> >> -#endif
>> >> - * Generates the hash words based on CRCs of the enabled MAC addresses that are
>> >> - * allowed to be received. The allowed MAC addresses are maintained in a linked
>> >> - * "multi-cast" list available in the arpcom structure.
>> >> - * Returns the number of MAC addresses that were processed (in the list)
>> >> -static int
>> >> -greth_mac_filter_calc(struct arpcom *ac, uint32_t *msb, uint32_t *lsb)
>> >> - struct ether_multistep step;
>> >> - struct ether_multi *enm;
>> >> - int cnt = 0;
>> >> - uint32_t crc, htindex, ht[2] = {0, 0};
>> >> - /* Go through the Ethernet Multicast addresses one by one and add their
>> >> - * CRC contribution to the MAC filter.
>> >> - ETHER_FIRST_MULTI(step, ac, enm);
>> >> - while (enm) {
>> >> - crc = ether_crc32_be((uint8_t *)enm->enm_addrlo, 6);
>> >> - htindex = crc & 0x3f;
>> >> - ht[htindex >> 5] |= (1 << (htindex & 0x1F));
>> >> - cnt++;
>> >> - ETHER_NEXT_MULTI(step, enm);
>> >> - if (cnt > 0) {
>> >> - *msb = ht[1];
>> >> - *lsb = ht[0];
>> >> - return cnt;
>> >> - * Initialize the ethernet hardware
>> >> -static int greth_mac_filter_set(struct greth_softc *sc)
>> >> - struct ifnet *ifp = &sc->arpcom.ac_if;
>> >> - uint32_t hash_msb, hash_lsb, ctrl;
>> >> - SPIN_IRQFLAGS(flags);
>> >> - hash_msb = 0;
>> >> - hash_lsb = 0;
>> >> - ctrl = 0;
>> >> - if (ifp->if_flags & IFF_PROMISC) {
>> >> - /* No need to enable multi-cast when promiscous mode accepts all */
>> >> - ctrl |= GRETH_CTRL_PRO;
>> >> - } else if(!sc->mc_available) {
>> >> - return EINVAL; /* no hardware support for multicast filtering. */
>> >> - } else if (ifp->if_flags & IFF_ALLMULTI) {
>> >> - /* We should accept all multicast addresses */
>> >> - ctrl |= GRETH_CTRL_MCE;
>> >> - hash_msb = 0xFFFFFFFF;
>> >> - hash_lsb = 0xFFFFFFFF;
>> >> - } else if (greth_mac_filter_calc(&sc->arpcom, &hash_msb, &hash_lsb) > 0) {
>> >> - /* Generate hash for MAC filtering out multicast addresses */
>> >> - } else {
>> >> - /* Multicast list is empty .. disable multicast */
>> >> - SPIN_LOCK_IRQ(&sc->devlock, flags);
>> >> - sc->regs->ht_msb = hash_msb;
>> >> - sc->regs->ht_lsb = hash_lsb;
>> >> - sc->regs->ctrl = (sc->regs->ctrl & ~(GRETH_CTRL_PRO | GRETH_CTRL_MCE)) |
>> >> - ctrl;
>> >> - SPIN_UNLOCK_IRQ(&sc->devlock, flags);
>> >> - return 0;
>> >> -static void
>> >> -greth_initialize_hardware (struct greth_softc *sc)
>> >> - struct mbuf *m;
>> >> - int i;
>> >> - int phyaddr;
>> >> - int phyctrl;
>> >> - int phystatus;
>> >> - int tmp1;
>> >> - int tmp2;
>> >> - struct timespec tstart, tnow;
>> >> - greth_regs *regs;
>> >> - unsigned int advmodes, speed, tabsize;
>> >> - regs = sc->regs;
>> >> - /* Reset the controller. */
>> >> - sc->rxInterrupts = 0;
>> >> - sc->rxPackets = 0;
>> >> - if (sc->greth_rst) {
>> >> - /* Reset ON */
>> >> - regs->ctrl = GRETH_CTRL_RST | GRETH_CTRL_DD | GRETH_CTRL_ED;
>> >> - for (i = 0; i<100 && (regs->ctrl & GRETH_CTRL_RST); i++)
>> >> - speed = 0; /* probe mode below */
>> >> - } else {
>> >> - /* inherit EDCL mode for now */
>> >> - speed = sc->regs->ctrl & (GRETH_CTRL_GB|GRETH_CTRL_SP|GRETH_CTRL_FULLD);
>> >> - /* Reset OFF and RX/TX DMA OFF. SW do PHY Init */
>> >> - regs->ctrl = GRETH_CTRL_DD | GRETH_CTRL_ED | speed;
>> >> - /* Check if mac is gbit capable*/
>> >> - sc->gbit_mac = (regs->ctrl >> 27) & 1;
>> >> - /* Get the phy address which assumed to have been set
>> >> - correctly with the reset value in hardware*/
>> >> - if ( sc->phyaddr == -1 ) {
>> >> - phyaddr = (regs->mdio_ctrl >> 11) & 0x1F;
>> >> - } else {
>> >> - phyaddr = sc->phyaddr;
>> >> - sc->phy_read_access = 0;
>> >> - sc->phy_write_access = 0;
>> >> - /* As I understand the PHY comes back to a good default state after
>> >> - * Power-down or Reset, so we do both just in case. Power-down bit should
>> >> - * be cleared.
>> >> - * Wait for old reset (if asserted by boot loader) to complete, otherwise
>> >> - * power-down instruction might not have any effect.
>> >> - while (read_mii(sc, phyaddr, 0) & 0x8000) {}
>> >> - write_mii(sc, phyaddr, 0, 0x0800); /* Power-down */
>> >> - write_mii(sc, phyaddr, 0, 0x0000); /* Power-Up */
>> >> - write_mii(sc, phyaddr, 0, 0x8000); /* Reset */
>> >> - /* We wait about 30ms */
>> >> - rtems_task_wake_after(rtems_clock_get_ticks_per_second()/32);
>> >> - /* Wait for reset to complete and get default values */
>> >> - while ((phyctrl = read_mii(sc, phyaddr, 0)) & 0x8000) {}
>> >> - /* Set up PHY advertising modes for auto-negotiation */
>> >> - advmodes = sc->advmodes;
>> >> - if (advmodes == 0)
>> >> - advmodes = GRETH_ADV_ALL;
>> >> - if (!sc->gbit_mac)
>> >> - advmodes &= ~(GRETH_ADV_1000_FD | GRETH_ADV_1000_HD);
>> >> - /* Enable/Disable GBit auto-neg advetisement so that the link partner
>> >> - * know that we have/haven't GBit capability. The MAC may not support
>> >> - * Gbit even though PHY does...
>> >> - phystatus = read_mii(sc, phyaddr, 1);
>> >> - if (phystatus & 0x0100) {
>> >> - tmp1 = read_mii(sc, phyaddr, 9);
>> >> - tmp1 &= ~0x300;
>> >> - if (advmodes & GRETH_ADV_1000_FD)
>> >> - tmp1 |= 0x200;
>> >> - if (advmodes & GRETH_ADV_1000_HD)
>> >> - tmp1 |= 0x100;
>> >> - write_mii(sc, phyaddr, 9, tmp1);
>> >> - /* Optionally limit the 10/100 modes as configured by user */
>> >> - tmp1 = read_mii(sc, phyaddr, 4);
>> >> - tmp1 &= ~0x1e0;
>> >> - if (advmodes & GRETH_ADV_100_FD)
>> >> - tmp1 |= 0x100;
>> >> - if (advmodes & GRETH_ADV_100_HD)
>> >> - tmp1 |= 0x080;
>> >> - if (advmodes & GRETH_ADV_10_FD)
>> >> - tmp1 |= 0x040;
>> >> - if (advmodes & GRETH_ADV_10_HD)
>> >> - tmp1 |= 0x020;
>> >> - write_mii(sc, phyaddr, 4, tmp1);
>> >> - /* If autonegotiation implemented we start it */
>> >> - if (phystatus & 0x0008) {
>> >> - write_mii(sc, phyaddr, 0, phyctrl | 0x1200);
>> >> - phyctrl = read_mii(sc, phyaddr, 0);
>> >> - /* Check if PHY is autoneg capable and then determine operating mode,
>> >> - otherwise force it to 10 Mbit halfduplex */
>> >> - sc->gb = 0;
>> >> - sc->fd = 0;
>> >> - sc->sp = 0;
>> >> - sc->auto_neg = 0;
>> >> - timespecclear(&sc->auto_neg_time);
>> >> - if ((phyctrl >> 12) & 1) {
>> >> - /*wait for auto negotiation to complete*/
>> >> - sc->auto_neg = 1;
>> >> - if (rtems_clock_get_uptime(&tstart) != RTEMS_SUCCESSFUL)
>> >> - printk("rtems_clock_get_uptime failed\n");
>> >> - while (!(((phystatus = read_mii(sc, phyaddr, 1)) >> 5) & 1)) {
>> >> - if (rtems_clock_get_uptime(&tnow) != RTEMS_SUCCESSFUL)
>> >> - timespecsub(&tnow, &tstart, &sc->auto_neg_time);
>> >> - if (timespeccmp(&sc->auto_neg_time, &greth_tan, >)) {
>> >> - sc->auto_neg = -1; /* Failed */
>> >> - tmp1 = read_mii(sc, phyaddr, 0);
>> >> - sc->gb = ((phyctrl >> 6) & 1) && !((phyctrl >> 13) & 1);
>> >> - sc->sp = !((phyctrl >> 6) & 1) && ((phyctrl >> 13) & 1);
>> >> - sc->fd = (phyctrl >> 8) & 1;
>> >> - goto auto_neg_done;
>> >> - /* Wait about 30ms, time is PHY dependent */
>> >> - sc->phydev.adv = read_mii(sc, phyaddr, 4);
>> >> - sc->phydev.part = read_mii(sc, phyaddr, 5);
>> >> - if ((phystatus >> 8) & 1) {
>> >> - sc->phydev.extadv = read_mii(sc, phyaddr, 9);
>> >> - sc->phydev.extpart = read_mii(sc, phyaddr, 10);
>> >> - if ( (sc->phydev.extadv & GRETH_MII_EXTADV_1000HD) &&
>> >> - (sc->phydev.extpart & GRETH_MII_EXTPRT_1000HD)) {
>> >> - sc->gb = 1;
>> >> - sc->fd = 0;
>> >> - if ( (sc->phydev.extadv & GRETH_MII_EXTADV_1000FD) &&
>> >> - (sc->phydev.extpart & GRETH_MII_EXTPRT_1000FD)) {
>> >> - sc->gb = 1;
>> >> - sc->fd = 1;
>> >> - if ((sc->gb == 0) || ((sc->gb == 1) && (sc->gbit_mac == 0))) {
>> >> - if ( (sc->phydev.adv & GRETH_MII_100TXFD) &&
>> >> - (sc->phydev.part & GRETH_MII_100TXFD)) {
>> >> - sc->sp = 1;
>> >> - sc->fd = 1;
>> >> - } else if ( (sc->phydev.adv & GRETH_MII_100TXHD) &&
>> >> - (sc->phydev.part & GRETH_MII_100TXHD)) {
>> >> - sc->sp = 1;
>> >> - sc->fd = 0;
>> >> - } else if ( (sc->phydev.adv & GRETH_MII_10FD) &&
>> >> - (sc->phydev.part & GRETH_MII_10FD)) {
>> >> - sc->fd = 1;
>> >> -auto_neg_done:
>> >> - sc->phydev.vendor = 0;
>> >> - sc->phydev.device = 0;
>> >> - sc->phydev.rev = 0;
>> >> - /* Read out PHY info if extended registers are available */
>> >> - if (phystatus & 1) {
>> >> - tmp1 = read_mii(sc, phyaddr, 2);
>> >> - tmp2 = read_mii(sc, phyaddr, 3);
>> >> - sc->phydev.vendor = (tmp1 << 6) | ((tmp2 >> 10) & 0x3F);
>> >> - sc->phydev.rev = tmp2 & 0xF;
>> >> - sc->phydev.device = (tmp2 >> 4) & 0x3F;
>> >> - /* Force to 10 mbit half duplex if the 10/100 MAC is used with a 1000 PHY */
>> >> - if (((sc->gb) && !(sc->gbit_mac)) || !((phyctrl >> 12) & 1)) {
>> >> - write_mii(sc, phyaddr, 0, sc->sp << 13);
>> >> - /* check if marvell 88EE1111 PHY. Needs special reset handling */
>> >> - if ((phystatus & 1) && (sc->phydev.vendor == 0x005043) &&
>> >> - (sc->phydev.device == 0x0C))
>> >> - sc->gb = 0;
>> >> - sc->sp = 0;
>> >> - sc->fd = 0;
>> >> - while ((read_mii(sc, phyaddr, 0)) & 0x8000) {}
>> >> - /* Reset ON */
>> >> - for (i = 0; i < 100 && (regs->ctrl & GRETH_CTRL_RST); i++)
>> >> - /* Reset OFF. Set mode matching PHY settings. */
>> >> - speed = (sc->gb << 8) | (sc->sp << 7) | (sc->fd << 4);
>> >> - regs->ctrl = GRETH_CTRL_DD | sc->edcl_dis | speed;
>> >> - /* Initialize rx/tx descriptor table pointers. Due to alignment we
>> >> - * always allocate maximum table size.
>> >> - tabsize = sc->num_descs * 8;
>> >> - sc->txdesc = (greth_rxtxdesc *) almalloc(tabsize * 2, tabsize);
>> >> - sc->rxdesc = (greth_rxtxdesc *) (tabsize + (void *)sc->txdesc);
>> >> - sc->tx_ptr = 0;
>> >> - sc->tx_dptr = 0;
>> >> - sc->tx_cnt = 0;
>> >> - sc->rx_ptr = 0;
>> >> - /* Translate the Descriptor DMA table base address into an address that
>> >> - * the GRETH core can understand
>> >> - drvmgr_translate_check(
>> >> - sc->dev,
>> >> - CPUMEM_TO_DMA,
>> >> - (void *)sc->txdesc,
>> >> - (void **)&sc->txdesc_remote,
>> >> - tabsize * 2);
>> >> - sc->rxdesc_remote = sc->txdesc_remote + tabsize;
>> >> - regs->txdesc = (int) sc->txdesc_remote;
>> >> - regs->rxdesc = (int) sc->rxdesc_remote;
>> >> - sc->rxmbuf = grlib_calloc(sc->rxbufs, sizeof(*sc->rxmbuf));
>> >> - sc->txmbuf = grlib_calloc(sc->txbufs, sizeof(*sc->txmbuf));
>> >> - for (i = 0; i < sc->txbufs; i++)
>> >> - sc->txdesc[i].ctrl = 0;
>> >> - if (!(sc->gbit_mac)) {
>> >> - sc->dev,
>> >> - CPUMEM_TO_DMA,
>> >> - (void *)grlib_malloc(GRETH_MAXBUF_LEN),
>> >> - (void **)&sc->txdesc[i].addr,
>> >> - GRETH_MAXBUF_LEN);
>> >> -#ifdef GRETH_DEBUG
>> >> - /* printf("TXBUF: %08x\n", (int) sc->txdesc[i].addr); */
>> >> -#endif
>> >> - for (i = 0; i < sc->rxbufs; i++)
>> >> - MGETHDR (m, M_WAIT, MT_DATA);
>> >> - MCLGET (m, M_WAIT);
>> >> - if (sc->gbit_mac)
>> >> - m->m_data += 2;
>> >> - m->m_pkthdr.rcvif = &sc->arpcom.ac_if;
>> >> - sc->rxmbuf[i] = m;
>> >> - sc->dev,
>> >> - CPUMEM_TO_DMA,
>> >> - (void *)mtod(m, uint32_t *),
>> >> - (void **)&sc->rxdesc[i].addr,
>> >> - sc->rxdesc[i].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ;
>> >> -#ifdef GRETH_DEBUG
>> >> -/* printf("RXBUF: %08x\n", (int) sc->rxdesc[i].addr); */
>> >> -#endif
>> >> - sc->rxdesc[sc->rxbufs - 1].ctrl |= GRETH_RXD_WRAP;
>> >> - /* set ethernet address. */
>> >> - regs->mac_addr_msb =
>> >> - sc->arpcom.ac_enaddr[0] << 8 | sc->arpcom.ac_enaddr[1];
>> >> - regs->mac_addr_lsb =
>> >> - sc->arpcom.ac_enaddr[2] << 24 | sc->arpcom.ac_enaddr[3] << 16 |
>> >> - sc->arpcom.ac_enaddr[4] << 8 | sc->arpcom.ac_enaddr[5];
>> >> - if ( sc->rxbufs < 10 ) {
>> >> - sc->tx_int_gen = sc->tx_int_gen_cur = 1;
>> >> - }else{
>> >> - sc->tx_int_gen = sc->tx_int_gen_cur = sc->txbufs/2;
>> >> - sc->next_tx_mbuf = NULL;
>> >> - if ( !sc->gbit_mac )
>> >> - sc->max_fragsize = 1;
>> >> - /* clear all pending interrupts */
>> >> - regs->status = 0xffffffff;
>> >> - /* install interrupt handler */
>> >> - drvmgr_interrupt_register(sc->dev, 0, "greth", greth_interrupt, sc);
>> >> - regs->ctrl |= GRETH_CTRL_RXEN | GRETH_CTRL_RXIRQ;
>> >> - print_init_info(sc);
>> >> -#ifdef CPU_U32_FIX
>> >> - * Routine to align the received packet so that the ip header
>> >> - * is on a 32-bit boundary. Necessary for cpu's that do not
>> >> - * allow unaligned loads and stores and when the 32-bit DMA
>> >> - * mode is used.
>> >> - * Transfers are done on word basis to avoid possibly slow byte
>> >> - * and half-word writes.
>> >> - unsigned int *first, *last, data;
>> >> - unsigned int tmp = 0;
>> >> - if ((((int) m->m_data) & 2) && (m->m_len)) {
>> >> -#if CPU_LITTLE_ENDIAN == TRUE
>> >> - memmove((caddr_t)(((int) m->m_data) + 2), m->m_data, m->m_len);
>> >> -#else
>> >> - last = (unsigned int *) ((((int) m->m_data) + m->m_len + 8) & ~3);
>> >> - first = (unsigned int *) (((int) m->m_data) & ~3);
>> >> - /* tmp = *first << 16; */
>> >> - tmp = GRETH_MEM_LOAD(first);
>> >> - tmp = tmp << 16;
>> >> - first++;
>> >> - do {
>> >> - /* When snooping is not available the LDA instruction must be used
>> >> - * to avoid the cache to return an illegal value.
>> >> - ** Load with forced cache miss
>> >> - * data = *first;
>> >> - data = GRETH_MEM_LOAD(first);
>> >> - *first = tmp | (data >> 16);
>> >> - tmp = data << 16;
>> >> - first++;
>> >> - } while (first <= last);
>> >> -#endif
>> >> - m->m_data = (caddr_t)(((int) m->m_data) + 2);
>> >> -#endif
>> >> -static void
>> >> -greth_Daemon (void *arg)
>> >> - struct ether_header *eh;
>> >> - struct greth_softc *dp = (struct greth_softc *) arg;
>> >> - struct ifnet *ifp = &dp->arpcom.ac_if;
>> >> - struct mbuf *m;
>> >> - unsigned int len, len_status, bad;
>> >> - rtems_event_set events;
>> >> - int first;
>> >> - int tmp;
>> >> - for (;;)
>> >> - rtems_bsdnet_event_receive (INTERRUPT_EVENT | GRETH_TX_WAIT_EVENT,
>> >> - RTEMS_WAIT | RTEMS_EVENT_ANY,
>> >> - RTEMS_NO_TIMEOUT, &events);
>> >> - if ( events & GRETH_TX_WAIT_EVENT ){
>> >> - /* TX interrupt.
>> >> - * We only end up here when all TX descriptors has been used,
>> >> - * and
>> >> - if ( dp->gbit_mac )
>> >> - greth_process_tx_gbit(dp);
>> >> - else
>> >> - greth_process_tx(dp);
>> >> - /* If we didn't get a RX interrupt we don't process it */
>> >> - if ( (events & INTERRUPT_EVENT) == 0 )
>> >> - continue;
>> >> -#ifdef GRETH_ETH_DEBUG
>> >> - printf ("r\n");
>> >> -#endif
>> >> - first=1;
>> >> - /* Scan for Received packets */
>> >> -again:
>> >> - while (!((len_status =
>> >> - GRETH_MEM_LOAD(&dp->rxdesc[dp->rx_ptr].ctrl)) & GRETH_RXD_ENABLE))
>> >> - bad = 0;
>> >> - if (len_status & GRETH_RXD_TOOLONG)
>> >> - dp->rxLengthError++;
>> >> - bad = 1;
>> >> - if (len_status & GRETH_RXD_DRIBBLE)
>> >> - dp->rxNonOctet++;
>> >> - bad = 1;
>> >> - if (len_status & GRETH_RXD_CRCERR)
>> >> - dp->rxBadCRC++;
>> >> - bad = 1;
>> >> - if (len_status & GRETH_RXD_OVERRUN)
>> >> - dp->rxOverrun++;
>> >> - bad = 1;
>> >> - if (len_status & GRETH_RXD_LENERR)
>> >> - bad = 1;
>> >> - if (!bad)
>> >> - /* pass on the packet in the receive buffer */
>> >> - len = len_status & 0x7FF;
>> >> - m = dp->rxmbuf[dp->rx_ptr];
>> >> -#ifdef GRETH_DEBUG
>> >> - int i;
>> >> - printf("RX: 0x%08x, Len: %d : ", (int) m->m_data, len);
>> >> - for (i=0; i<len; i++)
>> >> - printf("%x%x", (m->m_data[i] >> 4) & 0x0ff, m->m_data[i] & 0x0ff);
>> >> - printf("\n");
>> >> -#endif
>> >> - m->m_len = m->m_pkthdr.len =
>> >> - len - sizeof (struct ether_header);
>> >> - eh = mtod (m, struct ether_header *);
>> >> - m->m_data += sizeof (struct ether_header);
>> >> -#ifdef CPU_U32_FIX
>> >> - if(!dp->gbit_mac) {
>> >> - /* OVERRIDE CACHED ETHERNET HEADER FOR NON-SNOOPING SYSTEMS */
>> >> - tmp = GRETH_MEM_LOAD((uintptr_t)eh);
>> >> - tmp = GRETH_MEM_LOAD(4+(uintptr_t)eh);
>> >> - tmp = GRETH_MEM_LOAD(8+(uintptr_t)eh);
>> >> - tmp = GRETH_MEM_LOAD(12+(uintptr_t)eh);
>> >> - (void)tmp;
>> >> - ipalign(m); /* Align packet on 32-bit boundary */
>> >> -#endif
>> >> - if(!(dp->gbit_mac) && !CPU_SPARC_HAS_SNOOPING) {
>> >> - rtems_cache_invalidate_entire_data();
>> >> - ether_input (ifp, eh, m);
>> >> - if (dp->gbit_mac)
>> >> - m->m_data += 2;
>> >> - dp->rxmbuf[dp->rx_ptr] = m;
>> >> - m->m_pkthdr.rcvif = ifp;
>> >> - dp->dev,
>> >> - CPUMEM_TO_DMA,
>> >> - (void *)mtod (m, uint32_t *),
>> >> - (void **)&dp->rxdesc[dp->rx_ptr].addr,
>> >> - dp->rxPackets++;
>> >> - if (dp->rx_ptr == dp->rxbufs - 1) {
>> >> - dp->rxdesc[dp->rx_ptr].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ | GRETH_RXD_WRAP;
>> >> - } else {
>> >> - dp->rxdesc[dp->rx_ptr].ctrl = GRETH_RXD_ENABLE | GRETH_RXD_IRQ;
>> >> - SPIN_LOCK_IRQ(&dp->devlock, flags);
>> >> - dp->regs->ctrl |= GRETH_CTRL_RXEN;
>> >> - SPIN_UNLOCK_IRQ(&dp->devlock, flags);
>> >> - dp->rx_ptr = (dp->rx_ptr + 1) % dp->rxbufs;
>> >> - /* Always scan twice to avoid deadlock */
>> >> - if ( first ){
>> >> - first=0;
>> >> - dp->regs->ctrl |= GRETH_CTRL_RXIRQ;
>> >> - goto again;
>> >> -static int
>> >> -sendpacket (struct ifnet *ifp, struct mbuf *m)
>> >> - struct greth_softc *dp = ifp->if_softc;
>> >> - unsigned char *temp;
>> >> - struct mbuf *n;
>> >> - unsigned int len;
>> >> - * Is there a free descriptor available?
>> >> - if (GRETH_MEM_LOAD(&dp->txdesc[dp->tx_ptr].ctrl) & GRETH_TXD_ENABLE){
>> >> - /* No. */
>> >> - return 1;
>> >> - /* Remember head of chain */
>> >> - n = m;
>> >> - len = 0;
>> >> - temp = (unsigned char *) GRETH_MEM_LOAD(&dp->txdesc[dp->tx_ptr].addr);
>> >> - drvmgr_translate(dp->dev, CPUMEM_FROM_DMA, (void *)temp, (void **)&temp);
>> >> -#ifdef GRETH_DEBUG
>> >> - printf("TXD: 0x%08x : BUF: 0x%08x\n", (int) m->m_data, (int) temp);
>> >> -#endif
>> >> - for (;;)
>> >> -#ifdef GRETH_DEBUG
>> >> - int i;
>> >> - printf("MBUF: 0x%08x : ", (int) m->m_data);
>> >> - for (i=0;i<m->m_len;i++)
>> >> - printf("\n");
>> >> -#endif
>> >> - len += m->m_len;
>> >> - if (len <= RBUF_SIZE)
>> >> - memcpy ((void *) temp, (char *) m->m_data, m->m_len);
>> >> - temp += m->m_len;
>> >> - if ((m = m->m_next) == NULL)
>> >> - break;
>> >> - m_freem (n);
>> >> - /* don't send long packets */
>> >> - if (len <= GRETH_MAXBUF_LEN) {
>> >> - if (dp->tx_ptr < dp->txbufs-1) {
>> >> - dp->txdesc[dp->tx_ptr].ctrl = GRETH_TXD_IRQ |
>> >> - GRETH_TXD_ENABLE | len;
>> >> - } else {
>> >> - GRETH_TXD_WRAP | GRETH_TXD_ENABLE | len;
>> >> - dp->tx_ptr = (dp->tx_ptr + 1) % dp->txbufs;
>> >> - dp->regs->ctrl = dp->regs->ctrl | GRETH_CTRL_TXEN;
>> >> - return 0;
>> >> -static int
>> >> -sendpacket_gbit (struct ifnet *ifp, struct mbuf *m)
>> >> - unsigned int len;
>> >> - unsigned int ctrl;
>> >> - int frags;
>> >> - struct mbuf *mtmp;
>> >> - int int_en;
>> >> - len = 0;
>> >> -#ifdef GRETH_DEBUG
>> >> - printf("TXD: 0x%08x\n", (int) m->m_data);
>> >> -#endif
>> >> - /* Get number of fragments too see if we have enough
>> >> - * resources.
>> >> - frags=1;
>> >> - mtmp=m;
>> >> - while(mtmp->m_next){
>> >> - frags++;
>> >> - mtmp = mtmp->m_next;
>> >> - if ( frags > dp->max_fragsize )
>> >> - dp->max_fragsize = frags;
>> >> - if ( frags > dp->txbufs ){
>> >> - printf("GRETH: MBUF-chain cannot be sent. Increase descriptor count.\n");
>> >> - return -1;
>> >> - if ( frags > (dp->txbufs-dp->tx_cnt) ){
>> >> - /* Return number of fragments */
>> >> - return frags;
>> >> - /* Enable interrupt from descriptor every tx_int_gen
>> >> - * descriptor. Typically every 16 descriptor. This
>> >> - * is only to reduce the number of interrupts during
>> >> - * heavy load.
>> >> - dp->tx_int_gen_cur-=frags;
>> >> - if ( dp->tx_int_gen_cur <= 0 ){
>> >> - dp->tx_int_gen_cur = dp->tx_int_gen;
>> >> - int_en = GRETH_TXD_IRQ;
>> >> - }else{
>> >> - int_en = 0;
>> >> - /* At this stage we know that enough descriptors are available */
>> >> - for (;;)
>> >> -#ifdef GRETH_DEBUG
>> >> - int i;
>> >> - printf("MBUF: 0x%08x, Len: %d : ", (int) m->m_data, m->m_len);
>> >> - for (i=0; i<m->m_len; i++)
>> >> - printf("\n");
>> >> -#endif
>> >> - len += m->m_len;
>> >> - dp->dev,
>> >> - CPUMEM_TO_DMA,
>> >> - (void *)(uint32_t *)m->m_data,
>> >> - (void **)&dp->txdesc[dp->tx_ptr].addr,
>> >> - m->m_len);
>> >> - /* Wrap around? */
>> >> - ctrl = GRETH_TXD_ENABLE;
>> >> - }else{
>> >> - ctrl = GRETH_TXD_ENABLE | GRETH_TXD_WRAP;
>> >> - /* Enable Descriptor */
>> >> - if ((m->m_next) == NULL) {
>> >> - dp->txdesc[dp->tx_ptr].ctrl = ctrl | int_en | m->m_len;
>> >> - break;
>> >> - }else{
>> >> - dp->txdesc[dp->tx_ptr].ctrl = GRETH_TXD_MORE | ctrl | int_en | m->m_len;
>> >> - /* Next */
>> >> - dp->txmbuf[dp->tx_ptr] = m;
>> >> - dp->tx_cnt++;
>> >> - m = m->m_next;
>> >> - dp->tx_cnt++;
>> >> - /* Tell Hardware about newly enabled descriptor */
>> >> - return 0;
>> >> - struct mbuf *m;
>> >> - int first=1;
>> >> - * Send packets till queue is empty
>> >> - for (;;){
>> >> - /* Reap Sent packets */
>> >> - while((sc->tx_cnt > 0) && !(GRETH_MEM_LOAD(&sc->txdesc[sc->tx_dptr].ctrl) & GRETH_TXD_ENABLE)) {
>> >> - m_free(sc->txmbuf[sc->tx_dptr]);
>> >> - sc->tx_dptr = (sc->tx_dptr + 1) % sc->txbufs;
>> >> - sc->tx_cnt--;
>> >> - if ( sc->next_tx_mbuf ){
>> >> - /* Get packet we tried but faild to transmit last time */
>> >> - m = sc->next_tx_mbuf;
>> >> - sc->next_tx_mbuf = NULL; /* Mark packet taken */
>> >> - }else{
>> >> - * Get the next mbuf chain to transmit from Stack.
>> >> - IF_DEQUEUE (&ifp->if_snd, m);
>> >> - if (!m){
>> >> - /* Hardware has sent all schedule packets, this
>> >> - * makes the stack enter at greth_start next time
>> >> - * a packet is to be sent.
>> >> - ifp->if_flags &= ~IFF_OACTIVE;
>> >> - break;
>> >> - /* Are there free descriptors available? */
>> >> - /* Try to send packet, if it a negative number is returned. */
>> >> - if ( (sc->tx_cnt >= sc->txbufs) || sendpacket_gbit(ifp, m) ){
>> >> - /* Not enough resources */
>> >> - /* Since we have taken the mbuf out of the "send chain"
>> >> - * we must remember to use that next time we come back.
>> >> - * or else we have dropped a packet.
>> >> - sc->next_tx_mbuf = m;
>> >> - /* Not enough resources, enable interrupt for transmissions
>> >> - * this way we will be informed when more TX-descriptors are
>> >> - * available.
>> >> - if ( first ){
>> >> - first = 0;
>> >> - ifp->if_flags |= IFF_OACTIVE;
>> >> - sc->regs->ctrl |= GRETH_CTRL_TXIRQ;
>> >> - /* We must check again to be sure that we didn't
>> >> - * miss an interrupt (if a packet was sent just before
>> >> - * enabling interrupts)
>> >> - continue;
>> >> - return -1;
>> >> - }else{
>> >> - /* Sent Ok, proceed to process more packets if available */
>> >> - return 0;
>> >> - struct mbuf *m;
>> >> - int first=1;
>> >> - for (;;){
>> >> - /* Get packet we tried but failed to transmit last time */
>> >> - }else{
>> >> - if (!m){
>> >> - break;
>> >> - /* Try to send packet, failed if it a non-zero number is returned. */
>> >> - if ( sendpacket(ifp, m) ){
