[PATCH v2] covoar/ Explanations.cc: Handle newline at end of file
Chris Johns
chrisj at rtems.org
Fri Jun 25 08:08:14 UTC 2021
OK
On 25/6/21 1:37 pm, Alex White wrote:
> tester/covoar/Explanations.cc | 24 +++++++++++-------------
> 1 file changed, 11 insertions(+), 13 deletions(-)
> diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
> index 1449fb2..4d177eb 100644
> --- a/tester/covoar/Explanations.cc
> +++ b/tester/covoar/Explanations.cc
> @@ -85,26 +85,24 @@ namespace Coverage {
> line++;
> // Get the explanation
> - while (1) {
> - explain.getline( inputBuffer, MAX_LINE_LENGTH );
> - // fprintf( stderr, "%d - %s\n", line, inputBuffer );
> - if (explain.fail()) {
> - std::ostringstream what;
> - what << "line " << line
> - << "out of sync at the explanation";
> - throw rld::error( what, "Explanations::load" );
> - inputBuffer[ strlen(inputBuffer) - 1] = '\0';
> + for (std::string input_line; std::getline( explain, input_line ); ) {
> line++;
> - const char delimiter[4] = "+++";
> - if (!strncmp( inputBuffer, delimiter, 3 )) {
> + const std::string delimiter = "+++";
> + if (input_line.compare( delimiter ) == 0) {
> break;
> // XXX only taking last line. Needs to be a vector
> - e.explanation.push_back( inputBuffer );
> + e.explanation.push_back( input_line );
> + if (explain.fail()) {
> + std::ostringstream what;
> + what << "line " << line
> + << "out of sync at the explanation";
> + throw rld::error( what, "Explanations::load" );
> // Add this to the set of Explanations
> set[ e.startingPoint ] = e;
