[PATCH] covoar/Explanations.cc: Remove unnecessary newline strip
Chris Johns
chrisj at rtems.org
Fri Jun 25 08:08:28 UTC 2021
OK
On 25/6/21 1:40 pm, Alex White wrote:
> This corrects an issue where the starting line numbers of explanations
> had their last digit removed. This was caused by code left over for
> handling C file IO where the newline was included in the buffer.
> tester/covoar/Explanations.cc | 2 --
> 1 file changed, 2 deletions(-)
> diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
> index 4d177eb..91e65f2 100644
> --- a/tester/covoar/Explanations.cc
> +++ b/tester/covoar/Explanations.cc
> @@ -55,7 +55,6 @@ namespace Coverage {
> if (explain.fail()) {
> return;
> - inputBuffer[ strlen(inputBuffer) - 1] = '\0';
> line++;
> } while ( inputBuffer[0] == '\0' );
> @@ -80,7 +79,6 @@ namespace Coverage {
> << "out of sync at the classification";
> throw rld::error( what, "Explanations::load" );
> e.classification = inputBuffer;
> line++;
