[PATCH rtems-libbsd v2] aarch64/nexus: add GEM definitions for Versal
Gedare Bloom
gedare at rtems.org
Fri Jun 25 19:07:33 UTC 2021
I pushed this v2, thanks Joel.
On Fri, Jun 25, 2021 at 1:04 PM Gedare Bloom <gedare at rtems.org> wrote:
> rtemsbsd/include/bsp/nexus-devices.h | 7 +++++++
> rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 11 +++++++++++
> 2 files changed, 18 insertions(+)
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index efe4fcb4..e6487470 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -115,6 +115,13 @@ RTEMS_BSD_DRIVER_E1000PHY;
> RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM0(ZYNQMP_IRQ_ETHERNET_0);
> +#elif defined(LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
> +#include <bsp/irq.h>
> +RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0(VERSAL_IRQ_ETHERNET_0);
> +RTEMS_BSD_DRIVER_E1000PHY;
> #elif defined(LIBBSP_ARM_ATSAM_BSP_H)
> RTEMS_BSD_DRIVER_USB;
> diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> index 5902c58c..50a43873 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> @@ -409,6 +409,17 @@ extern "C" {
> #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(_irq) \
> RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(3, 0xff0e0000, _irq)
> #endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3 */
> + * Versal has a similar GEM as the CGEM. This should work for now.
> +#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0)
> + #define RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0(_irq) \
> + RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(0, 0xff0c0000, _irq)
> +#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0 */
> +#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM1)
> + #define RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM1(_irq) \
> + RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(1, 0xff0d0000, _irq)
> +#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM1 */
> * Designware/Synopsys Ethernet MAC Controller.
> 2.25.1
