[PATCH] bsps/raspberrypi: Add FDT defines to build options
Alan Cudmore
alan.cudmore at gmail.com
Sun Jun 27 14:04:03 UTC 2021
Hi,
This patch works for me. I can build and run the latest rtems master
branch samples on the RPI 2 and 3.
The samples do not run on the single core models, but it is not
related to this patch. I have a patch for the single core models, and
when combined with this patch I can get the samples to run on RPI
Zero, Zero W, Pi A+, Original Pi Model B+, Pi 2, and Pi 3.
Thanks,
Alan
On Fri, Jun 25, 2021 at 12:18 PM pranav <dangipranav at gmail.com> wrote:
> spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
> spec/build/bsps/arm/raspberrypi/optfdtcpyro.yml | 15 +++++++++++++++
> spec/build/bsps/arm/raspberrypi/optfdtmxsz.yml | 16 ++++++++++++++++
> spec/build/bsps/arm/raspberrypi/optfdtro.yml | 15 +++++++++++++++
> spec/build/bsps/arm/raspberrypi/optfdtuboot.yml | 15 +++++++++++++++
> 5 files changed, 69 insertions(+)
> create mode 100644 spec/build/bsps/arm/raspberrypi/optfdtcpyro.yml
> create mode 100644 spec/build/bsps/arm/raspberrypi/optfdtmxsz.yml
> create mode 100644 spec/build/bsps/arm/raspberrypi/optfdtro.yml
> create mode 100644 spec/build/bsps/arm/raspberrypi/optfdtuboot.yml
> diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
> index 7291e8b178..a810fdd529 100644
> --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> @@ -31,6 +31,14 @@ links:
> uid: optrpi2
> - role: build-dependency
> uid: optspiiomode
> +- role: build-dependency
> + uid: optfdtuboot
> + uid: optfdtcpyro
> + uid: optfdtmxsz
> + uid: optfdtro
> uid: ../start
> diff --git a/spec/build/bsps/arm/raspberrypi/optfdtcpyro.yml b/spec/build/bsps/arm/raspberrypi/optfdtcpyro.yml
> new file mode 100644
> index 0000000000..c26b1ae051
> --- /dev/null
> +++ b/spec/build/bsps/arm/raspberrypi/optfdtcpyro.yml
> @@ -0,0 +1,15 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-boolean: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +default: true
> +default-by-variant: []
> +description: |
> + copy the FDT blob into the read-only load area via bsp_fdt_copy()
> +enabled-by: true
> +links: []
> +name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> +type: build
> diff --git a/spec/build/bsps/arm/raspberrypi/optfdtmxsz.yml b/spec/build/bsps/arm/raspberrypi/optfdtmxsz.yml
> index 0000000000..14af766230
> --- /dev/null
> +++ b/spec/build/bsps/arm/raspberrypi/optfdtmxsz.yml
> @@ -0,0 +1,16 @@
> +actions:
> +- get-integer: null
> +- define: null
> +build-type: option
> +copyrights:
> +default: 262144
> +description: |
> + maximum size of the FDT blob in bytes
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: BSP_FDT_BLOB_SIZE_MAX
> +type: build
> diff --git a/spec/build/bsps/arm/raspberrypi/optfdtro.yml b/spec/build/bsps/arm/raspberrypi/optfdtro.yml
> index 0000000000..a61bb2924b
> --- /dev/null
> +++ b/spec/build/bsps/arm/raspberrypi/optfdtro.yml
> @@ -0,0 +1,15 @@
> +actions:
> +build-type: option
> +copyrights:
> +default: true
> +description: |
> + place the FDT blob into the read-only data area
> +enabled-by: true
> +links: []
> +name: BSP_FDT_BLOB_READ_ONLY
> +type: build
> diff --git a/spec/build/bsps/arm/raspberrypi/optfdtuboot.yml b/spec/build/bsps/arm/raspberrypi/optfdtuboot.yml
> index 0000000000..5805e912ff
> --- /dev/null
> +++ b/spec/build/bsps/arm/raspberrypi/optfdtuboot.yml
> @@ -0,0 +1,15 @@
> +actions:
> +build-type: option
> +copyrights:
> +default: true
> +description: |
> + copy the U-Boot provided FDT to an internal storage
> +enabled-by: true
> +links: []
> +name: BSP_START_COPY_FDT_FROM_U_BOOT
> +type: build
> 2.27.0
> devel mailing list
> devel at rtems.org
