[PATCH] bsps/zynqmp: Allow any or all CGEMs to be enabled
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jun 29 12:33:59 UTC 2021
I suppose this could have been configured in libbsd (possibly
config.inc) instead if that's what you're getting at. The overall goal
is to be able to run the tests that use the network on any one of the
board variants that this BSP supports. My takeaway from the earlier
conversation on the list is that this was the preferred method of
switching the ethernet interface for those tests.
Kinsey
On 6/28/2021 20:49, Chris Johns wrote:
> Hi,
> I am just catching up and missed this one until I saw the patch was pushed. I am
> sorry but I am confused by this patch.
> Could someone please explain this reason for this addition to the BSP and
> approach being taken? Is there something in the BSP that requires this
> information be provided here?
> Chris
> On 9/6/21 6:18 am, Kinsey Moore wrote:
>> Provide the options necessary to enable any combination of CGEM ethernet
>> interfaces in LibBSD. The default is still CGEM3, so this should
>> continue to operate as expected on typical Zynq Ultrascale+ MPSoC
>> development hardware.
>> spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 8 ++++++++
>> .../bsps/aarch64/xilinx-zynqmp/optcgem0.yml | 16 ++++++++++++++++
>> .../bsps/aarch64/xilinx-zynqmp/optcgem1.yml | 16 ++++++++++++++++
>> .../bsps/aarch64/xilinx-zynqmp/optcgem2.yml | 16 ++++++++++++++++
>> .../bsps/aarch64/xilinx-zynqmp/optcgem3.yml | 16 ++++++++++++++++
>> 5 files changed, 72 insertions(+)
>> create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
>> create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
>> create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
>> create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
>> index 16e2b8a7e9..1b6b756912 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
>> @@ -27,6 +27,14 @@ links:
>> uid: optramori
>> - role: build-dependency
>> uid: optclkuart
>> +- role: build-dependency
>> + uid: optcgem0
>> + uid: optcgem1
>> + uid: optcgem2
>> + uid: optcgem3
>> uid: ../../optconminor
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
>> new file mode 100644
>> index 0000000000..fc878fda60
>> --- /dev/null
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem0.yml
>> @@ -0,0 +1,16 @@
>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> +actions:
>> +- get-boolean: null
>> +- env-enable: null
>> +- define-condition: null
>> +build-type: option
>> +copyrights:
>> +- Copyright (C) 2021 On-Line Applications Research
>> +default: false
>> +default-by-variant: []
>> +description: |
>> + Enable support for CGEM0
>> +enabled-by: true
>> +links: []
>> +name: BSP_XILINX_ZYNQMP_USE_CGEM0
>> +type: build
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
>> index 0000000000..6d5096bbde
>> --- /dev/null
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem1.yml
>> @@ -0,0 +1,16 @@
>> +actions:
>> +- env-enable: null
>> +build-type: option
>> +copyrights:
>> +default: false
>> +description: |
>> + Enable support for CGEM1
>> +enabled-by: true
>> +links: []
>> +name: BSP_XILINX_ZYNQMP_USE_CGEM1
>> +type: build
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
>> index 0000000000..a8aca3ebbd
>> --- /dev/null
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem2.yml
>> @@ -0,0 +1,16 @@
>> +actions:
>> +- env-enable: null
>> +build-type: option
>> +copyrights:
>> +default: false
>> +description: |
>> + Enable support for CGEM2
>> +enabled-by: true
>> +links: []
>> +name: BSP_XILINX_ZYNQMP_USE_CGEM2
>> +type: build
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
>> index 0000000000..8275ad3440
>> --- /dev/null
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optcgem3.yml
>> @@ -0,0 +1,16 @@
>> +actions:
>> +- env-enable: null
>> +build-type: option
>> +copyrights:
>> +default: true
>> +description: |
>> + Enable support for CGEM3
>> +enabled-by: true
>> +links: []
>> +name: BSP_XILINX_ZYNQMP_USE_CGEM3
>> +type: build
