[PATCH] bsps/zynqmp: Allow any or all CGEMs to be enabled
Tue Jun 29 13:50:27 UTC 2021
On 29/06/2021 15:48, Kinsey Moore wrote:
> On 6/9/2021 00:27, Sebastian Huber wrote:
>> On 08/06/2021 22:18, Kinsey Moore wrote:
>>> Provide the options necessary to enable any combination of CGEM ethernet
>>> interfaces in LibBSD. The default is still CGEM3, so this should
>>> continue to operate as expected on typical Zynq Ultrascale+ MPSoC
>>> development hardware.
>> An alternative to this configuration approach would be to enable the
>> device tree support for this BSP.
> Sorry, I missed this earlier due to travel. Device tree support in
> libbsd for if_cgem.c is currently #ifdef'd out and has been since it was
> introduced. I had assumed that was the case for other FDT support as
> well based on the comments in that initial commit.
The device tree support is disabled since the original Zynq BSP was
added before RTEMS had support for device trees in general. Nobody had
the time/budget/need to change the BSP to support device trees so far.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
