[PATCH] Addded test for timer_create with clock_monotonic
Zack
zakthertemsdev at gmail.com
Tue Jun 29 15:19:39 UTC 2021
cpukit/include/rtems/posix/timer.h | 1 +
cpukit/posix/src/psxtimercreate.c | 5 +-
cpukit/posix/src/timergettime.c | 79 ++++++++++++++++-------
testsuites/psxtests/psxtimer02/psxtimer.c | 38 ++++++++++-
4 files changed, 98 insertions(+), 25 deletions(-)
diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
index bcbf07a65a..839fe3293c 100644
--- a/cpukit/include/rtems/posix/timer.h
+++ b/cpukit/include/rtems/posix/timer.h
@@ -48,6 +48,7 @@ typedef struct {
uint32_t ticks; /* Number of ticks of the initialization */
uint32_t overrun; /* Number of expirations of the timer */
struct timespec time; /* Time at which the timer was started */
+ clockid_t clock_type;
} POSIX_Timer_Control;
diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
index a63cf1d100..b60be3f229 100644
--- a/cpukit/posix/src/psxtimercreate.c
+++ b/cpukit/posix/src/psxtimercreate.c
@@ -40,7 +40,7 @@ int timer_create(
POSIX_Timer_Control *ptimer;
- if ( clock_id != CLOCK_REALTIME )
+ if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
rtems_set_errno_and_return_minus_one( EINVAL );
if ( !timerid )
@@ -91,7 +91,8 @@ int timer_create(
ptimer->timer_data.it_value.tv_nsec = 0;
ptimer->timer_data.it_interval.tv_sec = 0;
ptimer->timer_data.it_interval.tv_nsec = 0;
+ ptimer->clock_type=clock_id;
_Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
_Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
_Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
index ee2a566f0e..57b0ab4918 100644
--- a/cpukit/posix/src/timergettime.c
+++ b/cpukit/posix/src/timergettime.c
@@ -6,6 +6,14 @@
* @brief Function Fetches State of POSIX Per-Process Timers
+ * @file
+ * @ingroup POSIXAPI
+ * @brief Function Fetches State of POSIX Per-Process Timers
* 14.2.4 Per-Process Timers, P1003.1b-1993, p. 267
@@ -21,13 +29,13 @@
#include "config.h"
#endif
-#include <time.h>
#include <rtems/posix/timerimpl.h>
#include <rtems/seterr.h>
+#include <rtems/timespec.h>
+#include <time.h>
* - When a timer is initialized, the value of the time in
@@ -36,38 +44,65 @@
* between the current time and the initialization time.
-int timer_gettime(
- timer_t timerid,
- struct itimerspec *value
+int timer_gettime(timer_t timerid, struct itimerspec *value) {
- ISR_lock_Context lock_context;
- uint64_t now;
- uint32_t remaining;
+ ISR_lock_Context lock_context;
+ uint32_t remaining;
+ Per_CPU_Control *cpu;
+ struct timespec *now; // get time now either with
+ struct timespec *expire; // expire
+ struct timespec *result;
+ if (!value)
+ rtems_set_errno_and_return_minus_one(EINVAL);
- if ( !value )
- rtems_set_errno_and_return_minus_one( EINVAL );
+ ptimer = _POSIX_Timer_Get(timerid, &lock_context);
+ if (ptimer == NULL) {
+ if (ptimer->clock_type == CLOCK_REALTIME) {
- ptimer = _POSIX_Timer_Get( timerid, &lock_context );
- if ( ptimer != NULL ) {
- Per_CPU_Control *cpu;
+ cpu = _POSIX_Timer_Acquire_critical(ptimer, &lock_context);
- cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
- now = cpu->Watchdog.ticks;
+ _TOD_Get(now); // get current time
+ rtems_timespec_from_ticks(ptimer->Timer.expire,
+ expire);
- if ( now < ptimer->Timer.expire ) {
- remaining = (uint32_t) ( ptimer->Timer.expire - now );
+ if (now->tv_nsec + now->tv_sec >
+ expire->tv_nsec + expire->tv_sec) {
+ rtems_timespec_subtract(now, expire, result);
+ remaining = (uint32_t)result->tv_nsec + result->tv_sec;
} else {
remaining = 0;
- _Timespec_From_ticks( remaining, &value->it_value );
+ _Timespec_From_ticks(remaining, &value->it_value);
value->it_interval = ptimer->timer_data.it_interval;
+ _POSIX_Timer_Release(cpu, &lock_context);
+ return 0;
+ if (ptimer->clock_type == CLOCK_MONOTONIC) {
+ rtems_timespec_from_ticks(ptimer->Timer.expire, expire);
- _POSIX_Timer_Release( cpu, &lock_context );
+ if (now->tv_nsec + now->tv_sec > expire->tv_nsec + expire->tv_sec) {
+ } else {
+ remaining = 0;
+ value->it_interval = ptimer->timer_data.it_interval;
return 0;
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 9f79d33c42..6aea61c498 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -20,6 +20,7 @@
* http://www.rtems.org/license/LICENSE.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
@@ -63,7 +64,7 @@ void *POSIX_Init (
fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
puts( "timer_create - OK" );
- status = timer_create( CLOCK_REALTIME, NULL, &timer );
+ status = timer_create( CLOCK_REALTIME , NULL, &timer );
posix_service_failed( status, "timer_create OK" );
puts( "timer_create - too many - EAGAIN" );
@@ -127,6 +128,41 @@ void *POSIX_Init (
status = timer_delete( timer );
fatal_posix_service_status_errno( status, EINVAL, "bad id" );
+ * If these are not filled in correctly, we don't pass its error checking.
+puts( "timer_create - bad timer id pointer - EINVAL" );
+ status = timer_create( CLOCK_MONOTONIC, &event, NULL );
+ fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
+ puts( "timer_create - OK" );
+ status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
+ posix_service_failed( status, "timer_create OK" );
+ puts( "timer_create - too many - EAGAIN" );
+ status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
+ fatal_posix_service_status_errno( status, EAGAIN, "too many" );
+ clock_gettime( CLOCK_MONOTONIC, &now );
+ itimer.it_value = now;
+ itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
+ puts( "timer_settime - bad itimer value - previous time - EINVAL" );
+ status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
+ fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
+ itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
+ puts( "timer_settime - bad id - EINVAL" );
+ status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
+ fatal_posix_service_status_errno( status, EINVAL, "bad id" );
TEST_END();
rtems_test_exit (0);
2.32.0
