[PATCH] bsps/zynqmp: Allow any or all CGEMs to be enabled
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jun 29 16:19:59 UTC 2021
On 6/29/2021 11:10, Gedare Bloom wrote:
> On Tue, Jun 29, 2021 at 6:34 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
>> I suppose this could have been configured in libbsd (possibly
>> config.inc) instead if that's what you're getting at. The overall goal
>> is to be able to run the tests that use the network on any one of the
>> board variants that this BSP supports. My takeaway from the earlier
>> conversation on the list is that this was the preferred method of
>> switching the ethernet interface for those tests.
> I acked this patch, and then I also dug into the cgem code. It seems
> we should leave the decision of which GEM to use to the application.
> This patch and way of doing that accomplishes the configuration by the
> application as a BSP option. However, there's no code in the BSP that
> actually gets controlled by the option. So, I think we should probably
> find a better way to allow the application to select which GEM it
> uses, and to provide the glue in the BSP to allow all the possible
> GEMs to be available.
This patch was primarily targeted at the tests themselves. The
application can always provide its own nexus definitions instead of
using the ones baked into libbsd for testing (this was brought up in the
initial thread where I asked about how this was typically done).
Unfortunately, this is hard to do with the tests because the tests are
the application and can't be changed for those overrides/alternatives.
Kinsey
