[PATCH v1 1/2] ReportsBase.cc: Remove possible division by zero
Ryan Long
ryan.long at oarcorp.com
Tue Jun 29 17:26:08 UTC 2021
No good reason. I'll make those changes and send V2.
-----Original Message-----
Sent: Tuesday, June 29, 2021 12:13 PM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH v1 1/2] ReportsBase.cc: Remove possible division by zero
On Tue, Jun 29, 2021 at 11:06 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 1503709: Division or modulo by float zero
> Closes #4415
> tester/covoar/ReportsBase.cc | 10 +++++++---
> 1 file changed, 7 insertions(+), 3 deletions(-)
> diff --git a/tester/covoar/ReportsBase.cc
> b/tester/covoar/ReportsBase.cc index b4a755c..31dc429 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -482,9 +482,13 @@ void ReportsBase::WriteSummaryReport(
> - percentage = (double) notExecuted;
> - percentage /= (double) totalBytes;
> - percentage *= 100.0;
> + if (totalBytes == 0) {
> + percentage = 0;
> + } else {
> + percentage = (double) notExecuted;
> + percentage /= (double) totalBytes;
> + percentage *= 100.0;
ok, any good reason not to use one line? Just curious.
percentage = 100.0 * (double) notExecuted / totalBytes;
> percentageBranches = (double) (
> SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
> 1.8.3.1
> devel mailing list
> devel at rtems.org
