Question about Raspberry Pi bspstarthooks.c - potential patch
Alan Cudmore
alan.cudmore at gmail.com
Tue Jun 29 18:56:48 UTC 2021
Hi Sebastian,
I understand the move in that commit now.
Maybe it's not working on the single core models because the code is
conditional for ARMV7 + A or ARMV8?
https://git.rtems.org/rtems/tree/bsps/arm/shared/start/start.S#n485
I think the single core RPIs are ARM1176JZF-S (ARMv6Z).
Do the conditional defines come from the compiler?
Thanks,
Alan
On Tue, Jun 29, 2021 at 1:42 AM Sebastian Huber
> Hello Alan,
> On 29/06/2021 03:13, Alan Cudmore wrote:
> > The current RTEMS 6/master branch does not seem to work on the
> > Raspberry Pi single core models, while the 5 branch does.
> > I was able to track it down to a commit where it stopped working:
> > 272534eb725f2486b7a32b39d998202a101bd36e
> > In that commit, the call:
> > /* Clear Secure or Non-secure Vector Base Address Register */
> > arm_cp15_set_vector_base_address(bsp_vector_table_begin);
> > Was moved from bsp_start_hook_0 to rpi_start_rtems_on_secondary_processor.
> > If I add it back to bsp_start_hook_0, the single core models work again.
> I moved the VBAR setting to start.S. Maybe the problem is that TTBCR is
> no longer set to zero before the VBAR is set. The Raspberry Pi BSP is
> the only BSP which did this.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
