[PATCH v2 2/2] rtems-exeinfo.cpp: Fix division by zero errors
Ryan Long
ryan.long at oarcorp.com
Tue Jun 29 19:25:00 UTC 2021
I'll cast those. Sorry I missed that.
-----Original Message-----
Sent: Tuesday, June 29, 2021 2:03 PM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH v2 2/2] rtems-exeinfo.cpp: Fix division by zero errors
On Tue, Jun 29, 2021 at 11:50 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> CID 1503008: Division or modulo by zero CID 1503015: Division or
> modulo by zero
> Closes #4416
> linkers/rtems-exeinfo.cpp | 20 ++++++++++++++++----
> 1 file changed, 16 insertions(+), 4 deletions(-)
> diff --git a/linkers/rtems-exeinfo.cpp b/linkers/rtems-exeinfo.cpp
> index 1e6d4b4..ec51597 100644
> --- a/linkers/rtems-exeinfo.cpp
> +++ b/linkers/rtems-exeinfo.cpp
> @@ -755,6 +755,8 @@ namespace rld
> size_t total = 0;
> size_t total_size = 0;
> size_t inlined_size = 0;
> + double percentage;
> + double percentage_size;
> dwarf::functions funcs_inlined;
> dwarf::functions funcs_not_inlined;
> func_counts counts;
> @@ -798,14 +800,24 @@ namespace rld
> + if ( total == 0 ) {
> + percentage = 0;
> + } else {
> + percentage = ( funcs_inlined.size() * 100 ) / total;
> + if ( total_size == 0 ) {
> + percentage_size = 0;
> + } else {
> + percentage_size = ( inlined_size * 100 ) / total_size;
These are still integer results. If you want double, you should cast, if you want integer, you should use int type for the percentage and percentage_size variables.
> std::cout << "inlined funcs : " << funcs_inlined.size () << std::endl
> << " total funcs : " << total << std::endl
> - << " % inline funcs : " << (funcs_inlined.size () * 100) / total << '%'
> - << std::endl
> + << " % inline funcs : " << percentage << '%' <<
> + std::endl
> << " total size : " << total_size << std::endl
> << " inline size : " << inlined_size << std::endl
> - << " % inline size : " << (inlined_size * 100) / total_size << '%'
> - << std::endl;
> + << " % inline size : " << percentage_size << '%' <<
> + std::endl;
> auto count_compare = [](func_count const & a, func_count const & b) {
> return a.size != b.size? a.size < b.size : a.count >
> b.count;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
