[PATCH] defaults.mc: Remove any checks for objdump and objcopy
Joel Sherrill
joel at rtems.org
Wed Jun 30 14:31:26 UTC 2021
On Wed, Jun 30, 2021 at 3:28 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - FreeBSD is removing any dependence on binutils and release 13
> has remove objdump. This is fine as we build our own version.
removed. :)
> source-builder/defaults.mc | 5 ++---
> 1 file changed, 2 insertions(+), 3 deletions(-)
> diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
> index 8ed7003..98775e8 100644
> --- a/source-builder/defaults.mc
> +++ b/source-builder/defaults.mc
> @@ -184,13 +184,12 @@ __mkdir: exe, required, '/bin/mkdir'
> __mkdir_p: exe, none, '/bin/mkdir -p'
> __mv: exe, required, '/bin/mv'
> __nm: exe, required, '/usr/bin/nm'
> -__objcopy: exe, optional, '/usr/bin/objcopy'
> -__objdump: exe, optional, '/usr/bin/objdump'
> +__objcopy: exe, none, '/usr/bin/objcopy'
> +__objdump: exe, none, '/usr/bin/objdump'
Looks like you are also removing objcopy.
Why would we have ever needed the native versions of either?
And what's the alternative on FreeBSD if someone did need that
functionality?
> __patch_bin: exe, required, '/usr/bin/patch'
> __patch_opts: none, none, '%{nil}'
> __patch: exe, none, '%{__patch_bin} %{__patch_opts}'
> __perl: exe, optional, 'perl'
> -__svn: exe, optional, '/usr/bin/svn'
> __ranlib: exe, required, 'ranlib'
> __rm: exe, required, '/bin/rm'
> __rmfile: exe, none, '%{__rm} -f'
> 2.31.1
> devel mailing list
> devel at rtems.org
