[PATCH 2/4] validation: Add comments to signal tests
Sebastian Huber
Mon Mar 1 09:27:08 UTC 2021
testsuites/validation/tc-signal-catch.c | 106 ++++++++++++++++++++++++
testsuites/validation/tc-signal-send.c | 78 +++++++++++++++++
2 files changed, 184 insertions(+)
diff --git a/testsuites/validation/tc-signal-catch.c b/testsuites/validation/tc-signal-catch.c
index 9c14cc93a3..7c3292ba71 100644
--- a/testsuites/validation/tc-signal-catch.c
+++ b/testsuites/validation/tc-signal-catch.c
@@ -251,11 +251,17 @@ static void RtemsSignalReqCatch_Pre_Handler_Prepare(
switch ( state ) {
case RtemsSignalReqCatch_Pre_Handler_Invalid: {
+ * The ``asr_handler`` parameter shall be NULL.
ctx->handler = NULL;
break;
case RtemsSignalReqCatch_Pre_Handler_Valid: {
+ * The ``asr_handler`` parameter shall be a valid ASR handler.
ctx->handler = SignalHandler;
break;
@@ -272,6 +278,10 @@ static void RtemsSignalReqCatch_Pre_Preempt_Prepare(
switch ( state ) {
case RtemsSignalReqCatch_Pre_Preempt_Yes: {
+ * The ``mode_set`` parameter shall specify that
+ * preemption is enabled.
#if defined(RTEMS_SMP)
if ( rtems_configuration_get_maximum_processors() == 1 ) {
ctx->normal_mode |= RTEMS_NO_PREEMPT;
@@ -283,6 +293,10 @@ static void RtemsSignalReqCatch_Pre_Preempt_Prepare(
case RtemsSignalReqCatch_Pre_Preempt_No: {
+ * preemption is disabled.
ctx->mode |= RTEMS_NO_PREEMPT;
break;
@@ -299,11 +313,19 @@ static void RtemsSignalReqCatch_Pre_Timeslice_Prepare(
switch ( state ) {
case RtemsSignalReqCatch_Pre_Timeslice_Yes: {
+ * timeslicing is enabled.
ctx->mode |= RTEMS_TIMESLICE;
break;
case RtemsSignalReqCatch_Pre_Timeslice_No: {
+ * timeslicing is disabled.
ctx->normal_mode |= RTEMS_TIMESLICE;
break;
@@ -320,11 +342,19 @@ static void RtemsSignalReqCatch_Pre_ASR_Prepare(
switch ( state ) {
case RtemsSignalReqCatch_Pre_ASR_Yes: {
+ * ASR processing is enabled.
/* We cannot disable ASR processing at normal task level for this test */
break;
case RtemsSignalReqCatch_Pre_ASR_No: {
+ * ASR processing is disabled.
ctx->mode |= RTEMS_NO_ASR;
break;
@@ -341,6 +371,10 @@ static void RtemsSignalReqCatch_Pre_IntLvl_Prepare(
switch ( state ) {
case RtemsSignalReqCatch_Pre_IntLvl_Zero: {
+ * The ``mode_set`` parameter shall specify an interrupt
+ * level of zero.
#if !defined(RTEMS_SMP) && CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
ctx->normal_mode |= RTEMS_INTERRUPT_LEVEL( 1 );
#endif
@@ -348,6 +382,10 @@ static void RtemsSignalReqCatch_Pre_IntLvl_Prepare(
case RtemsSignalReqCatch_Pre_IntLvl_Positive: {
+ * The ``mode_set`` parameter shall specify a positive
+ * interrupt level.
ctx->mode |= RTEMS_INTERRUPT_LEVEL( 1 );
break;
@@ -364,11 +402,21 @@ static void RtemsSignalReqCatch_Post_Status_Check(
switch ( state ) {
case RtemsSignalReqCatch_Post_Status_Ok: {
+ * The return status of rtems_signal_catch() shall be
+ * RTEMS_SUCCESSFUL.
T_rsc_success( ctx->catch_status );
break;
case RtemsSignalReqCatch_Post_Status_NotImplNoPreempt: {
+ * Where the system is configured with SMP support, if the scheduler does
+ * not support the no-preempt mode, then the return status of
+ * rtems_signal_catch() shall be RTEMS_NOT_IMPLEMENTED,
+ * otherwise the return status shall be RTEMS_SUCCESSFUL.
if ( rtems_configuration_get_maximum_processors() > 1 ) {
T_rsc( ctx->catch_status, RTEMS_NOT_IMPLEMENTED );
@@ -382,6 +430,13 @@ static void RtemsSignalReqCatch_Post_Status_Check(
case RtemsSignalReqCatch_Post_Status_NotImplIntLvl: {
+ * Where the system is configured with SMP support and the configured
+ * processor maximum is greater than one, or the CPU port enabled robust
+ * thread dispatching, the return status of rtems_signal_catch() shall be
+ * RTEMS_NOT_IMPLEMENTED, otherwise the return status
+ * shall be RTEMS_SUCCESSFUL.
#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
#elif defined(RTEMS_SMP)
@@ -408,6 +463,11 @@ static void RtemsSignalReqCatch_Post_Send_Check(
switch ( state ) {
case RtemsSignalReqCatch_Post_Send_New: {
+ * When a signal set is sent to the caller of rtems_signal_catch() and the
+ * call was successful, the ASR processing shall be done with the specified
+ * handler, otherwise the ASR information of the caller shall be unchanged.
T_rsc_success( ctx->send_status );
if ( ctx->catch_status == RTEMS_SUCCESSFUL ) {
@@ -423,6 +483,12 @@ static void RtemsSignalReqCatch_Post_Send_Check(
case RtemsSignalReqCatch_Post_Send_NotDef: {
+ * call was successful, the ASR processing shall be deactivated and all
+ * pending signals shall be cleared, otherwise the ASR information of the
+ * caller shall be unchanged.
T_rsc( ctx->send_status, RTEMS_NOT_DEFINED );
T_eq_u32( ctx->default_handler_calls, 0 );
@@ -449,11 +515,21 @@ static void RtemsSignalReqCatch_Post_Preempt_Check(
switch ( state ) {
case RtemsSignalReqCatch_Post_Preempt_Yes: {
+ * call with a valid handler was successful, the ASR processing shall be
+ * done with preemption enabled.
CheckHandlerMode( ctx, RTEMS_PREEMPT_MASK, RTEMS_PREEMPT );
break;
case RtemsSignalReqCatch_Post_Preempt_No: {
+ * done with preemption disabled.
CheckHandlerMode( ctx, RTEMS_PREEMPT_MASK, RTEMS_NO_PREEMPT );
break;
@@ -470,11 +546,21 @@ static void RtemsSignalReqCatch_Post_Timeslice_Check(
switch ( state ) {
case RtemsSignalReqCatch_Post_Timeslice_Yes: {
+ * done with timeslicing enabled.
CheckHandlerMode( ctx, RTEMS_TIMESLICE_MASK, RTEMS_TIMESLICE );
break;
case RtemsSignalReqCatch_Post_Timeslice_No: {
+ * done with timeslicing disabled.
CheckHandlerMode( ctx, RTEMS_TIMESLICE_MASK, RTEMS_NO_TIMESLICE );
break;
@@ -491,11 +577,21 @@ static void RtemsSignalReqCatch_Post_ASR_Check(
switch ( state ) {
case RtemsSignalReqCatch_Post_ASR_Yes: {
+ * done with ASR processing enabled.
CheckHandlerMode( ctx, RTEMS_ASR_MASK, RTEMS_ASR );
break;
case RtemsSignalReqCatch_Post_ASR_No: {
+ * done with ASR processing disabled.
CheckHandlerMode( ctx, RTEMS_ASR_MASK, RTEMS_NO_ASR );
break;
@@ -512,11 +608,21 @@ static void RtemsSignalReqCatch_Post_IntLvl_Check(
switch ( state ) {
case RtemsSignalReqCatch_Post_IntLvl_Zero: {
+ * done with interrupts enabled.
CheckHandlerMode( ctx, RTEMS_INTERRUPT_MASK, RTEMS_INTERRUPT_LEVEL( 0 ) );
break;
case RtemsSignalReqCatch_Post_IntLvl_Positive: {
+ * done with interrupts disabled according to the specified interrupt level.
CheckHandlerMode( ctx, RTEMS_INTERRUPT_MASK, RTEMS_INTERRUPT_LEVEL( 1 ) );
break;
diff --git a/testsuites/validation/tc-signal-send.c b/testsuites/validation/tc-signal-send.c
index a4232efbae..cf5235f752 100644
--- a/testsuites/validation/tc-signal-send.c
+++ b/testsuites/validation/tc-signal-send.c
@@ -371,16 +371,27 @@ static void RtemsSignalReqSend_Pre_Task_Prepare(
switch ( state ) {
case RtemsSignalReqSend_Pre_Task_NoObj: {
+ * The ``id`` parameter shall be invalid.
ctx->id = 0xffffffff;
break;
case RtemsSignalReqSend_Pre_Task_Self: {
+ * The ``id`` parameter shall be associated with
+ * the calling task.
ctx->id = RTEMS_SELF;
break;
case RtemsSignalReqSend_Pre_Task_Other: {
+ * The ``id`` parameter shall be associated with a
+ * task other than the calling task.
ctx->id = ctx->worker_id;
break;
@@ -397,11 +408,17 @@ static void RtemsSignalReqSend_Pre_Set_Prepare(
switch ( state ) {
case RtemsSignalReqSend_Pre_Set_Zero: {
+ * The ``signal_set`` parameter shall be zero.
ctx->signal_set = 0;
break;
case RtemsSignalReqSend_Pre_Set_NonZero: {
+ * The ``signal_set`` parameter shall be non-zero.
ctx->signal_set = 0xdeadbeef;
break;
@@ -418,11 +435,19 @@ static void RtemsSignalReqSend_Pre_Handler_Prepare(
switch ( state ) {
case RtemsSignalReqSend_Pre_Handler_Invalid: {
+ * When the target task has no valid ASR handler installed, the
+ * rtems_signal_send() directive shall be called.
break;
case RtemsSignalReqSend_Pre_Handler_Valid: {
+ * When the target task has a valid ASR handler installed, the
break;
@@ -439,11 +464,19 @@ static void RtemsSignalReqSend_Pre_ASR_Prepare(
switch ( state ) {
case RtemsSignalReqSend_Pre_ASR_Enabled: {
+ * When the target task has ASR processing enabled, the rtems_signal_send()
+ * directive shall be called.
ctx->mode = RTEMS_DEFAULT_MODES;
break;
case RtemsSignalReqSend_Pre_ASR_Disabled: {
+ * When the target task has ASR processing disabled, the rtems_signal_send()
ctx->mode = RTEMS_NO_ASR;
break;
@@ -460,11 +493,19 @@ static void RtemsSignalReqSend_Pre_Nested_Prepare(
switch ( state ) {
case RtemsSignalReqSend_Pre_Nested_Yes: {
+ * When the target task processes an asynchronous signal set, the
ctx->nested = 1;
break;
case RtemsSignalReqSend_Pre_Nested_No: {
+ * When the target task does not process an asynchronous signal set, the
ctx->nested = 0;
break;
@@ -481,21 +522,37 @@ static void RtemsSignalReqSend_Post_Status_Check(
switch ( state ) {
case RtemsSignalReqSend_Post_Status_Ok: {
+ * The return status of rtems_signal_send() shall be
T_rsc_success( ctx->status );
break;
case RtemsSignalReqSend_Post_Status_InvNum: {
+ * RTEMS_INVALID_NUMBER.
T_rsc( ctx->status, RTEMS_INVALID_NUMBER );
break;
case RtemsSignalReqSend_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
T_rsc( ctx->status, RTEMS_INVALID_ID );
break;
case RtemsSignalReqSend_Post_Status_NotDef: {
+ * RTEMS_NOT_DEFINED.
T_rsc( ctx->status, RTEMS_NOT_DEFINED );
break;
@@ -516,6 +573,10 @@ static void RtemsSignalReqSend_Post_Handler_Check(
switch ( state ) {
case RtemsSignalReqSend_Post_Handler_NoCall: {
+ * While the ASR processing is disabled, the ASR handler shall not be
+ * called.
T_eq_sz( ctx->calls_after_send, ctx->nested );
T_eq_sz( ctx->calls_after_dispatch, ctx->nested );
T_eq_sz( ctx->calls_after_enable, ctx->nested );
@@ -523,6 +584,9 @@ static void RtemsSignalReqSend_Post_Handler_Check(
case RtemsSignalReqSend_Post_Handler_DuringSend: {
+ * The ASR handler shall be called during the rtems_signal_send() call.
++expected_calls;
T_eq_sz( ctx->calls_after_send, ctx->nested + 1 );
T_eq_sz( ctx->calls_after_dispatch, ctx->nested + 1 );
@@ -531,6 +595,10 @@ static void RtemsSignalReqSend_Post_Handler_Check(
case RtemsSignalReqSend_Post_Handler_AfterDispatch: {
+ * When the next thread dispatch of the target task of the
+ * rtems_signal_send() call takes place, the ASR handler shall be called.
++expected_calls;
@@ -539,6 +607,10 @@ static void RtemsSignalReqSend_Post_Handler_Check(
case RtemsSignalReqSend_Post_Handler_AfterEnable: {
+ * When the target task of the rtems_signal_send() call re-enables ASR
+ * processing, the ASR handler shall be called.
++expected_calls;
@@ -568,6 +640,9 @@ static void RtemsSignalReqSend_Post_Recursive_Check(
switch ( state ) {
case RtemsSignalReqSend_Post_Recursive_Yes: {
+ * The ASR handler shall be called recursively.
T_eq_sz( ctx->handler_calls, 2 );
T_ne_uptr( ctx->stack_pointers[ 0 ], 0 );
T_ne_uptr( ctx->stack_pointers[ 1 ], 0 );
@@ -576,6 +651,9 @@ static void RtemsSignalReqSend_Post_Recursive_Check(
case RtemsSignalReqSend_Post_Recursive_No: {
+ * The ASR handler shall not be called recursively.
if ( ctx->handler_calls == 2 ) {
2.26.2
