[PATCH 1/3] fdt_rw.c: Fix Unchecked return value (CID #1047324)
Gedare Bloom
gedare at rtems.org
Mon Mar 1 16:56:34 UTC 2021
On Mon, Mar 1, 2021 at 9:24 AM Ryan Long <thisisryanlong at gmail.com> wrote:
> CID 1047324: Unchecked return value in fdt_add_subnode_namelen().
> Updates #4256
> cpukit/dtc/libfdt/fdt_rw.c | 6 +++++-
> 1 file changed, 5 insertions(+), 1 deletion(-)
> diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
I think it was suggested to attempt to provide this in the upstream for dtc?
> index 1385425..d6f7d93 100644
> --- a/cpukit/dtc/libfdt/fdt_rw.c
> +++ b/cpukit/dtc/libfdt/fdt_rw.c
> @@ -348,7 +348,11 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset,
> return offset;
> /* Try to place the new node after the parent's properties */
> - fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */
> + #ifdef __rtems__
> + (void)fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */
I think we usually put a space after (void)
(void) fdt...
but, it should be consistent with the upstream
> + #else
> + fdt_next_tag(fdt, parentoffset, &nextoffset);
> + #endif
> do {
> offset = nextoffset;
> tag = fdt_next_tag(fdt, offset, &nextoffset);
> 1.8.3.1
> devel mailing list
> devel at rtems.org
