[PATCH 2/3] grspw.c: Fix Unchecked return value (CID #1399781)
Mon Mar 1 16:57:37 UTC 2021
Someone (Daniel) from Gaisler should review.
On Mon, Mar 1, 2021 at 9:24 AM Ryan Long <thisisryanlong at gmail.com> wrote:
> CID 1399781: Unchecked return value in grspw_device_init().
> Closes #4259
>  bsps/shared/grlib/spw/grspw.c | 7 +++++--
>  1 file changed, 5 insertions(+), 2 deletions(-)
> diff --git a/bsps/shared/grlib/spw/grspw.c b/bsps/shared/grlib/spw/grspw.c
> index 1b50cc6..74a0fc7 100644
> --- a/bsps/shared/grlib/spw/grspw.c
> +++ b/bsps/shared/grlib/spw/grspw.c
> @@ -465,6 +465,7 @@ int grspw_device_init(GRSPW_DEV *pDev)
>         struct amba_dev_info *ambadev;
>         struct ambapp_core *pnpinfo;
>         union drvmgr_key_value *value;
> +        rtems_status_code status;
>         /* Get device information from AMBA PnP information */
>         ambadev = (struct amba_dev_info *)pDev->dev->businfo;
> @@ -555,21 +556,23 @@ int grspw_device_init(GRSPW_DEV *pDev)
>                 return RTEMS_NO_MEMORY;
>         /* Create semaphores */
> -       rtems_semaphore_create(
> +       status = rtems_semaphore_create(
>                 rtems_build_name('T', 'x', 'S', '0' + pDev->minor),
>                 0,
>                 RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | RTEMS_NO_INHERIT_PRIORITY | \
>                 RTEMS_NO_PRIORITY_CEILING,
>                 0,
>                 &(pDev->txsp));
> +        _Assert_Unused_variable_equals(status,RTEMS_SUCCESSFUL);
space needed after comma
>                 rtems_build_name('R', 'x', 'S', '0' + pDev->minor),
>                 0,
>                 0,
>                 &(pDev->rxsp));
>         grspw_hw_init(pDev);
> 1.8.3.1
> devel mailing list
> devel at rtems.org
