[PATCH 3/3] main_edit.c: Fix Unchecked return value (CID #1255318)
Gedare Bloom
gedare at rtems.org
Mon Mar 1 16:58:01 UTC 2021
On Mon, Mar 1, 2021 at 9:24 AM Ryan Long <thisisryanlong at gmail.com> wrote:
> CID 1255318: Unchecked return value in display_line().
> Updates #4257
> cpukit/libmisc/shell/main_edit.c | 6 +++++-
> 1 file changed, 5 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
> index a011049..8730b21 100644
> --- a/cpukit/libmisc/shell/main_edit.c
> +++ b/cpukit/libmisc/shell/main_edit.c
> @@ -1089,7 +1089,11 @@ static void display_line(struct editor *ed, int pos, int fullline) {
> int selstart, selend, ch;
> char *s;
> - get_selection(ed, &selstart, &selend);
> + #ifdef __rtems__
We own this code? no need to ifdef it?
> + (void)get_selection(ed, &selstart, &selend);
add whitespace
> + #else
> + get_selection(ed, &selstart, &selend);
> + #endif
> while (col < maxcol) {
> if (margin == 0) {
> if (!hilite && pos >= selstart && pos < selend) {
> 1.8.3.1
> devel mailing list
> devel at rtems.org
