[PATCH v2 1/3] fdt_rw.c: Fix Unchecked return value (CID #1047324)
Ryan Long
thisisryanlong at gmail.com
Mon Mar 1 18:47:01 UTC 2021
CID 1047324: Unchecked return value in fdt_add_subnode_namelen().
Updates #4256
cpukit/dtc/libfdt/fdt_rw.c | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 1385425..41abd8c 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -348,7 +348,11 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset,
return offset;
/* Try to place the new node after the parent's properties */
- fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */
+ #ifdef __rtems__
+ (void) fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */
+ #else
+ fdt_next_tag(fdt, parentoffset, &nextoffset);
+ #endif
do {
offset = nextoffset;
tag = fdt_next_tag(fdt, offset, &nextoffset);
1.8.3.1
