[PATCH 04/22] covoar/Target_i386: Add NOP patterns
Alex White
alexanderjwhite at gmail.com
Mon Mar 1 20:01:11 UTC 2021
A couple of NOP patterns found with the pc686 BSP were not detected.
This has been fixed.
tester/covoar/Target_i386.cc | 9 +++++++++
1 file changed, 9 insertions(+)
diff --git a/tester/covoar/Target_i386.cc b/tester/covoar/Target_i386.cc
index e0c9c0f..4567c1e 100644
--- a/tester/covoar/Target_i386.cc
+++ b/tester/covoar/Target_i386.cc
@@ -87,6 +87,15 @@ namespace Target {
size = 3;
return true;
+ if (!strncmp( &line[strlen(line)-28], "lea 0x0(%esi,%eiz,1),%esi", 28)) {
+ // Could be 4 or 7 bytes of padding.
+ if (!strncmp( &line[strlen(line)-32], "00", 2)) {
+ size = 7;
+ } else {
+ size = 4;
+ return true;
return false;
2.27.0
