[PATCH 12/22] covoar: Fix NOP execution marking
Alex White
alexanderjwhite at gmail.com
Mon Mar 1 20:01:19 UTC 2021
Some NOP instructions were not being marked as executed because they
are located at the end of uncovered ranges. This has been fixed.
tester/covoar/CoverageMapBase.cc | 10 +++
tester/covoar/CoverageMapBase.h | 4 ++
tester/covoar/DesiredSymbols.cc | 38 ++++++++--
tester/covoar/DesiredSymbols.h | 10 ++-
tester/covoar/ObjdumpProcessor.cc | 112 +++++++++++++++++++++++-------
5 files changed, 139 insertions(+), 35 deletions(-)
diff --git a/tester/covoar/CoverageMapBase.cc b/tester/covoar/CoverageMapBase.cc
index ad0080d..6ca5cf7 100644
--- a/tester/covoar/CoverageMapBase.cc
+++ b/tester/covoar/CoverageMapBase.cc
@@ -142,6 +142,11 @@ namespace Coverage {
return size;
+ uint32_t CoverageMapBase::getSizeOfRange( size_t index ) const
+ return Ranges.at(index).size();
bool CoverageMapBase::getBeginningOfInstruction(
uint32_t address,
uint32_t* beginning
@@ -178,6 +183,11 @@ namespace Coverage {
return Ranges.front().lowAddress;
+ uint32_t CoverageMapBase::getLowAddressOfRange( size_t index ) const
+ return Ranges.at(index).lowAddress;
bool CoverageMapBase::getRange( uint32_t address, AddressRange& range ) const
for ( auto r : Ranges ) {
diff --git a/tester/covoar/CoverageMapBase.h b/tester/covoar/CoverageMapBase.h
index 6ad76d3..a58c696 100644
--- a/tester/covoar/CoverageMapBase.h
+++ b/tester/covoar/CoverageMapBase.h
@@ -156,6 +156,8 @@ namespace Coverage {
int32_t getFirstLowAddress() const;
+ uint32_t getLowAddressOfRange( size_t index ) const;
* This method returns true and sets the address range if
* the address falls with the bounds of an address range
@@ -177,6 +179,8 @@ namespace Coverage {
uint32_t getSize() const;
+ uint32_t getSizeOfRange( size_t index ) const;
* This method returns the address of the beginning of the
* instruction that contains the specified address.
diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
index b9a5bb7..c97b25c 100644
--- a/tester/covoar/DesiredSymbols.cc
+++ b/tester/covoar/DesiredSymbols.cc
@@ -142,7 +142,7 @@ namespace Coverage {
CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
if (theCoverageMap)
- // Increment the total sizeInBytes byt the bytes in the symbol
+ // Increment the total sizeInBytes by the bytes in the symbol
stats.sizeInBytes += s.second.stats.sizeInBytes;
// Now scan through the coverage map of this symbol.
@@ -202,6 +202,26 @@ namespace Coverage {
uint32_t count;
// Mark NOPs as executed
+ a = s.second.stats.sizeInBytes - 1;
+ count = 0;
+ while (a > 0) {
+ if (theCoverageMap->isStartOfInstruction( a )) {
+ break;
+ count++;
+ if (theCoverageMap->isNop( a )) {
+ for (la = a; la < (a + count); la++) {
+ theCoverageMap->setWasExecuted( la );
+ count = 0;
+ a--;
endAddress = s.second.stats.sizeInBytes - 1;
a = 0;
while (a < endAddress) {
@@ -223,12 +243,13 @@ namespace Coverage {
ha++;
if ( ha >= endAddress )
break;
- } while ( !theCoverageMap->isStartOfInstruction( ha ) );
+ } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
+ theCoverageMap->isNop( ha ) );
a = ha;
- endAddress = s.second.stats.sizeInBytes - 1;
+ endAddress = s.second.stats.sizeInBytesWithoutNops - 1;
a = 0;
while (a <= endAddress) {
// If an address was NOT executed, find consecutive unexecuted
@@ -316,7 +337,8 @@ namespace Coverage {
void DesiredSymbols::createCoverageMap(
const std::string& exefileName,
const std::string& symbolName,
- uint32_t size
+ uint32_t size,
+ uint32_t sizeWithoutNops
CoverageMapBase* aCoverageMap;
@@ -354,9 +376,10 @@ namespace Coverage {
<< '/' << size << ')'
<< std::endl;
- if ( itr->second.stats.sizeInBytes < size )
+ if ( itr->second.stats.sizeInBytes < size ) {
itr->second.stats.sizeInBytes = size;
- else
+ itr->second.stats.sizeInBytesWithoutNops = sizeWithoutNops;
+ } else
size = itr->second.stats.sizeInBytes;
@@ -376,6 +399,7 @@ namespace Coverage {
itr->second.unifiedCoverageMap = aCoverageMap;
@@ -479,7 +503,7 @@ namespace Coverage {
// are the same size.
// Changed from ERROR msg to INFO, because size mismatch is not
// treated as error anymore. 2015-07-20
- uint32_t dMapSize = sinfo.stats.sizeInBytes;
+ uint32_t dMapSize = sinfo.stats.sizeInBytesWithoutNops;
uint32_t sBaseAddress = sourceCoverageMap->getFirstLowAddress();
uint32_t sMapSize = sourceCoverageMap->getSize();
if (dMapSize != 0 && dMapSize != sMapSize) {
diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
index 5c45af8..fb3efd6 100644
--- a/tester/covoar/DesiredSymbols.h
+++ b/tester/covoar/DesiredSymbols.h
@@ -57,7 +57,12 @@ namespace Coverage {
uint32_t sizeInBytes;
- * This member contains the size in Bytes.
+ * This member contains the size in Bytes not accounting for NOPs.
+ uint32_t sizeInBytesWithoutNops;
+ * This member contains the size in instructions.
uint32_t sizeInInstructions;
@@ -227,7 +232,8 @@ namespace Coverage {
void createCoverageMap(
- uint32_t size
+ uint32_t size,
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index 56ee219..bf39fe9 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -32,35 +32,95 @@ namespace Coverage {
ObjdumpProcessor::objdumpLines_t instructions
// Find the symbol's coverage map.
- CoverageMapBase& coverageMap = executableInfo->findCoverageMap( symbolName );
- uint32_t lowAddress = coverageMap.getFirstLowAddress();
- uint32_t size = coverageMap.getSize();
- uint32_t highAddress = lowAddress + size - 1;
- // If there are NOT already saved instructions, save them.
- SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
- if (symbolInfo->instructions.empty()) {
- symbolInfo->sourceFile = executableInfo;
- symbolInfo->baseAddress = lowAddress;
- symbolInfo->instructions = instructions;
+ try {
+ CoverageMapBase& coverageMap = executableInfo->findCoverageMap(symbolName);
- // Add the symbol to this executable's symbol table.
- SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
- theSymbolTable->addSymbol(
- symbolName, lowAddress, highAddress - lowAddress + 1
+ uint32_t firstInstructionAddress = -1;
- // Mark the start of each instruction in the coverage map.
- for (auto& instruction : instructions) {
- coverageMap.setIsStartOfInstruction( instruction.address );
+ // Find the address of the first instruction.
+ for (auto& line : instructions) {
+ if (!line.isInstruction) {
+ continue;
+ firstInstructionAddress = line.address;
+ break;
+ if (firstInstructionAddress == (uint32_t)-1) {
+ std::ostringstream what;
+ what << "Could not find first instruction address for symbol "
+ << symbolName << " in " << executableInfo->getFileName();
+ throw rld::error( what, "Coverage::finalizeSymbol" );
+ bool inRange = false;
+ int rangeIndex = 0;
+ uint32_t lowAddress = -1;
+ while (!inRange) {
+ lowAddress = coverageMap.getLowAddressOfRange(rangeIndex);
+ if (firstInstructionAddress == lowAddress) {
+ break;
+ rangeIndex++;
- // Create a unified coverage map for the symbol.
- SymbolsToAnalyze->createCoverageMap(
- executableInfo->getFileName().c_str(), symbolName, size
+ uint32_t sizeWithoutNops = coverageMap.getSizeOfRange(rangeIndex);
+ uint32_t size = sizeWithoutNops;
+ uint32_t highAddress = lowAddress + size - 1;
+ uint32_t computedHighAddress = highAddress;
+ // Find the high address as reported by the address of the last NOP
+ // instruction. This ensures that NOPs get marked as executed later.
+ for (auto instruction = instructions.rbegin();
+ instruction != instructions.rend();
+ instruction++) {
+ if (instruction->isInstruction) {
+ if (instruction->isNop) {
+ computedHighAddress = instruction->address + instruction->nopSize;
+ break;
+ if (highAddress != computedHighAddress) {
+ fprintf(
+ stderr,
+ "Function's high address differs between DWARF and objdump: "
+ "%s (0x%x and 0x%x)\n",
+ symbolName.c_str(), highAddress, computedHighAddress - 1
+ size = computedHighAddress - lowAddress;
+ // If there are NOT already saved instructions, save them.
+ SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
+ if (symbolInfo->instructions.empty()) {
+ symbolInfo->sourceFile = executableInfo;
+ symbolInfo->baseAddress = lowAddress;
+ symbolInfo->instructions = instructions;
+ // Add the symbol to this executable's symbol table.
+ SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
+ theSymbolTable->addSymbol(
+ symbolName, lowAddress, highAddress - lowAddress + 1
+ // Mark the start of each instruction in the coverage map.
+ for (auto& instruction : instructions) {
+ coverageMap.setIsStartOfInstruction( instruction.address );
+ // Create a unified coverage map for the symbol.
+ SymbolsToAnalyze->createCoverageMap(
+ executableInfo->getFileName().c_str(), symbolName, size, sizeWithoutNops
+ } catch (rld::error& e) {
+ throw rld::error( e.what, "Coverage::finalizeSymbol" );
ObjdumpProcessor::ObjdumpProcessor()
2.27.0
