[PATCH 13/22] covoar: Handle periods in symbols from objdump
Alex White
alexanderjwhite at gmail.com
Mon Mar 1 20:01:20 UTC 2021
Occasionally the compiler will generate symbols that look similar to
symbols defined in RTEMS code except that they contain some suffix.
This looks to be related to compiler optimizations. Such symbols were
being treated as unique. For our purposes, they should be mapped to
the equivalent symbols in the DWARF info. This has been fixed.
tester/covoar/ExecutableInfo.cc | 35 ++++++++++++++++++++++++++++++-
tester/covoar/ObjdumpProcessor.cc | 6 ++++++
tester/covoar/SymbolTable.cc | 12 ++++++++---
3 files changed, 49 insertions(+), 4 deletions(-)
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index c4257f0..1396519 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -119,6 +119,22 @@ namespace Coverage {
itsSymbol = theSymbolTable.getSymbol( address );
if (itsSymbol != "") {
it = coverageMaps.find( itsSymbol );
+ if (it == coverageMaps.end()) {
+ size_t periodIndex = itsSymbol.find(".");
+ if (periodIndex == std::string::npos) {
+ // Symbol name has no '.', can't do another lookup.
+ throw rld::error (itsSymbol, "ExecutableInfo::getCoverageMap");
+ it = coverageMaps.find(
+ itsSymbol.substr(0, periodIndex)
aCoverageMap = (*it).second;
@@ -150,8 +166,25 @@ namespace Coverage {
CoverageMaps::iterator cmi = coverageMaps.find( symbolName );
- if ( cmi == coverageMaps.end() )
+ if ( cmi != coverageMaps.end() ) {
+ return *(cmi->second);
+ size_t periodIndex = symbolName.find(".");
throw rld::error (symbolName, "ExecutableInfo::findCoverageMap");
+ cmi = coverageMaps.find(
+ symbolName.substr(0, periodIndex)
+ if ( cmi == coverageMaps.end() ) {
+ throw rld::error (symbolName, "ExecutableInfo::findCoverageMap");
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index bf39fe9..f4769b5 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -420,6 +420,12 @@ namespace Coverage {
processSymbol = false;
theInstructions.clear();
+ // Look for a '.' character and strip everything after it.
+ char *periodIndex = strstr(symbol, ".");
+ if (periodIndex != NULL) {
+ *periodIndex = 0;
// See if the new symbol is one that we care about.
if (SymbolsToAnalyze->isDesired( symbol )) {
currentSymbol = symbol;
diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
index 53bc8af..00062cc 100644
--- a/tester/covoar/SymbolTable.cc
+++ b/tester/covoar/SymbolTable.cc
@@ -46,12 +46,18 @@ namespace Coverage {
symbolData.startingAddress = start;
symbolData.length = length;
- if ( info[ symbol ].empty() == false ) {
- if ( info[ symbol ].front().length != length ) {
+ for (auto& symData : info[ symbol ]) {
+ // The starting address could differ since we strip any suffixes beginning
+ // with a '.'
+ if (symData.startingAddress != start) {
+ continue;
+ if (symData.length != length) {
std::ostringstream what;
what << "Different lengths for the symbol "
<< symbol
- << " (" << info[ symbol ].front().length
+ << " (" << symData.length
<< " and " << length
throw rld::error( what, "SymbolTable::addSymbol" );
2.27.0
