[PATCH 15/22] coverage/reports: Improve formatting and clarity
Alex White
alexanderjwhite at gmail.com
Mon Mar 1 20:01:22 UTC 2021
The coverage reports contain places where they display incorrect or
vague information particularly when some statistic is unavailable. This
has been fixed. The formatting and wording of various things has been
improved as well.
tester/covoar/ObjdumpProcessor.cc | 5 +
tester/covoar/ReportsBase.cc | 22 ++++-
tester/covoar/ReportsHtml.cc | 159 +++++++++++++++++-------------
tester/covoar/ReportsText.cc | 76 ++++++++------
tester/rt/coverage.py | 19 +++-
5 files changed, 174 insertions(+), 107 deletions(-)
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index f4769b5..00824f1 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -377,6 +377,11 @@ namespace Coverage {
break;
+ // Remove any extra line break
+ if (line.back() == '\n') {
+ line.erase(line.end() - 1);
lineInfo.line = line;
lineInfo.address = 0xffffffff;
lineInfo.isInstruction = false;
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index 0be5567..8252959 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -161,6 +161,24 @@ void ReportsBase::CloseSymbolSummaryFile(
CloseFile( aFile );
+void remove_tabs(const char* in, char* out, size_t max_len) {
+ size_t i = 0;
+ while (*in != 0 && i < max_len - 1) {
+ if (*in == '\t') {
+ in++;
+ out[i++] = ' ';
+ while (i % 4 != 0 && i < max_len - 1) {
+ out[i++] = ' ';
+ } else {
+ out[i++] = *in++;
+ out[i] = 0;
* Write annotated report
@@ -237,7 +255,9 @@ void ReportsBase::WriteAnnotatedReport(
- snprintf( textLine, LINE_LENGTH, "%-70s", itr->line.c_str() );
+ char textLineWithoutTabs[LINE_LENGTH];
+ remove_tabs( itr->line.c_str(), textLineWithoutTabs, LINE_LENGTH );
+ snprintf( textLine, LINE_LENGTH, "%-90s", textLineWithoutTabs );
line = textLine + annotation;
PutAnnotatedLine( aFile, state, line, id);
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index ebc6ee0..cce0a4f 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -89,7 +89,7 @@ namespace Coverage {
PRINT_ITEM( "Branch Report", "branch" );
PRINT_ITEM( "Annotated Assembly", "annotated" );
PRINT_ITEM( "Symbol Summary", "symbolSummary" );
- PRINT_ITEM( "Size Report", "sizes" );
+ PRINT_ITEM( "Uncovered Range Size Report", "sizes" );
PRINT_TEXT_ITEM( "Explanations Not Found", "ExplanationsNotFound.txt" );
@@ -176,7 +176,7 @@ namespace Coverage {
// Put header information into the file
fprintf(
aFile,
- "<title>Branch Report</title\n"
+ "<title>Branch Report</title>\n"
"<div class=\"heading-title\">"
@@ -321,7 +321,7 @@ namespace Coverage {
fprintf(
aFile,
- "<title>Size Report</title>\n"
+ "<title>Uncovered Range Size Report</title>\n"
@@ -334,7 +334,7 @@ namespace Coverage {
fprintf(
aFile,
- "Size Report</div>\n"
+ "Uncovered Range Size Report</div>\n"
"<div class =\"datetime\">%s</div>\n"
"<body>\n"
"<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
@@ -490,7 +490,7 @@ namespace Coverage {
FILE* report
- if ( BranchInfoAvailable )
+ if (BranchInfoAvailable && SymbolsToAnalyze->getNumberBranchesFound() != 0)
fprintf( report, "All branch paths taken.\n" );
else
fprintf( report, "No branch information found.\n" );
@@ -861,90 +861,107 @@ namespace Coverage {
symbol->first.c_str()
- // Total Size in Bytes
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
- symbol->second.stats.sizeInBytes
- // Total Size in Instructions
- fprintf(
- report,
- symbol->second.stats.sizeInInstructions
- // Total Uncovered Ranges
- fprintf(
- report,
- symbol->second.stats.uncoveredRanges
- // Uncovered Size in Bytes
- fprintf(
- report,
- symbol->second.stats.uncoveredBytes
- // Uncovered Size in Instructions
- fprintf(
- report,
- symbol->second.stats.uncoveredInstructions
+ if (symbol->second.stats.sizeInBytes == 0) {
+ // The symbol has never been seen. Write "unknown" for all columns.
+ fprintf(
+ report,
+ "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
+ } else {
+ // Total Size in Bytes
+ fprintf(
+ report,
+ "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
+ symbol->second.stats.sizeInBytes
- // Total number of branches
- fprintf(
- report,
- symbol->second.stats.branchesNotExecuted + symbol->second.stats.branchesExecuted
+ // Total Size in Instructions
+ fprintf(
+ report,
+ symbol->second.stats.sizeInInstructions
- // Total Always Taken
- fprintf(
- report,
- symbol->second.stats.branchesAlwaysTaken
+ // Total Uncovered Ranges
+ fprintf(
+ report,
+ symbol->second.stats.uncoveredRanges
- // Total Never Taken
- fprintf(
- report,
- symbol->second.stats.branchesNeverTaken
+ // Uncovered Size in Bytes
+ fprintf(
+ report,
+ symbol->second.stats.uncoveredBytes
- // % Uncovered Instructions
- if ( symbol->second.stats.sizeInInstructions == 0 )
+ // Uncovered Size in Instructions
fprintf(
report,
- "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
+ symbol->second.stats.uncoveredInstructions
- else
+ // Total number of branches
fprintf(
report,
- "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
- (symbol->second.stats.uncoveredInstructions*100.0)/
+ symbol->second.stats.branchesNotExecuted + symbol->second.stats.branchesExecuted
- // % Uncovered Bytes
- if ( symbol->second.stats.sizeInBytes == 0 )
+ // Total Always Taken
fprintf(
report,
+ symbol->second.stats.branchesAlwaysTaken
- else
+ // Total Never Taken
fprintf(
report,
- (symbol->second.stats.uncoveredBytes*100.0)/
+ symbol->second.stats.branchesNeverTaken
+ // % Uncovered Instructions
+ if ( symbol->second.stats.sizeInInstructions == 0 )
+ fprintf(
+ report,
+ "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
+ else
+ fprintf(
+ report,
+ "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
+ (symbol->second.stats.uncoveredInstructions*100.0)/
+ // % Uncovered Bytes
+ if ( symbol->second.stats.sizeInBytes == 0 )
+ fprintf(
+ report,
+ else
+ fprintf(
+ report,
+ (symbol->second.stats.uncoveredBytes*100.0)/
fprintf( report, "</tr>\n");
return true;
diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
index 33d3509..a3923e6 100644
--- a/tester/covoar/ReportsText.cc
+++ b/tester/covoar/ReportsText.cc
@@ -52,7 +52,7 @@ bool ReportsText::PutNoBranchInfo(
FILE* report
+ if ( BranchInfoAvailable && SymbolsToAnalyze->getNumberBranchesFound() != 0 )
else
@@ -235,38 +235,52 @@ bool ReportsText::PutSymbolSummaryLine(
float uncoveredBytes;
float uncoveredInstructions;
- uncoveredInstructions = 0;
- else
- uncoveredInstructions = (symbol->second.stats.uncoveredInstructions*100.0)/
- symbol->second.stats.sizeInInstructions;
+ fprintf(
+ report,
+ "============================================\n"
+ "Symbol : %s\n"
+ " *** NEVER REFERENCED ***\n\n"
+ "This symbol was never referenced by an analyzed executable.\n"
+ "Therefore there is no size or disassembly for this symbol.\n"
+ "This could be due to symbol misspelling or lack of a test for\n"
+ "this symbol.\n",
+ symbol->first.c_str()
+ } else {
+ uncoveredInstructions = 0;
+ else
+ uncoveredInstructions = (symbol->second.stats.uncoveredInstructions*100.0)/
+ symbol->second.stats.sizeInInstructions;
- uncoveredBytes = 0;
- else
- uncoveredBytes = (symbol->second.stats.uncoveredBytes*100.0)/
- symbol->second.stats.sizeInBytes;
+ uncoveredBytes = 0;
+ else
+ uncoveredBytes = (symbol->second.stats.uncoveredBytes*100.0)/
+ symbol->second.stats.sizeInBytes;
- fprintf(
- report,
- "============================================\n"
- "Symbol : %s\n"
- "Total Size in Bytes : %d\n"
- "Total Size in Instructions : %d\n"
- "Total number Branches : %d\n"
- "Total Always Taken : %d\n"
- "Total Never Taken : %d\n"
- "Percentage Uncovered Instructions : %.2f\n"
- "Percentage Uncovered Bytes : %.2f\n",
- symbol->first.c_str(),
- symbol->second.stats.sizeInBytes,
- symbol->second.stats.sizeInInstructions,
- symbol->second.stats.branchesNotExecuted + symbol->second.stats.branchesExecuted,
- symbol->second.stats.branchesAlwaysTaken,
- symbol->second.stats.branchesNeverTaken,
- uncoveredInstructions,
- uncoveredBytes
+ fprintf(
+ report,
+ "Symbol : %s\n"
+ "Total Size in Bytes : %d\n"
+ "Total Size in Instructions : %d\n"
+ "Total number Branches : %d\n"
+ "Total Always Taken : %d\n"
+ "Total Never Taken : %d\n"
+ "Percentage Uncovered Instructions : %.2f\n"
+ "Percentage Uncovered Bytes : %.2f\n",
+ symbol->first.c_str(),
+ symbol->second.stats.sizeInBytes,
+ symbol->second.stats.sizeInInstructions,
+ symbol->second.stats.branchesNotExecuted + symbol->second.stats.branchesExecuted,
+ symbol->second.stats.branchesAlwaysTaken,
+ symbol->second.stats.branchesNeverTaken,
+ uncoveredInstructions,
+ uncoveredBytes
fprintf(report, "============================================\n");
return true;
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 9d628ba..3dd7a32 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -121,7 +121,7 @@ class report_gen_html:
def _prepare_head_section(self):
head_section = '<head>' + os.linesep
- head_section += ' <title>RTEMS coverage report</title>' + os.linesep
+ head_section += ' <title>RTEMS Coverage Report</title>' + os.linesep
head_section += ' <style type="text/css">' + os.linesep
head_section += ' progress[value] {' + os.linesep
head_section += ' -webkit-appearance: none;' + os.linesep
@@ -129,17 +129,28 @@ class report_gen_html:
head_section += ' width: 150px;' + os.linesep
head_section += ' height: 15px;' + os.linesep
head_section += ' }' + os.linesep
+ head_section += ' table, th, td {' + os.linesep
+ head_section += ' border: 1px solid black;' + os.linesep
+ head_section += ' border-collapse: collapse;' + os.linesep
+ head_section += ' }' + os.linesep
+ head_section += ' td {' + os.linesep
+ head_section += ' text-align:center;' + os.linesep
head_section += ' </style>' + os.linesep
head_section += '</head>' + os.linesep
return head_section
def _prepare_index_content(self, partial_reports):
- header = "<h1> RTEMS coverage analysis report </h1>" + os.linesep
+ header = "<h1> RTEMS Coverage Analysis Report </h1>" + os.linesep
header += "<h3>Coverage reports by symbols sets:</h3>" + os.linesep
- table = "<table>" + os.linesep
+ table = "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd\">" + os.linesep
+ table += "<thead>" + os.linesep
table += self._header_row()
- for symbol_set in partial_reports:
+ table += "</thead>" + os.linesep
+ table += "<tbody>" + os.linesep
+ for symbol_set in sorted(partial_reports.keys()):
table += self._row(symbol_set, partial_reports[symbol_set])
+ table += "</tbody>" + os.linesep
table += "</table> </br>"
timestamp = "Analysis performed on " + datetime.datetime.now().ctime()
return "<body>\n" + header + table + timestamp + "\n</body>"
2.27.0
