[PATCH 01/22] tester: Update to support new build system
Gedare Bloom
gedare at rtems.org
Tue Mar 2 15:45:50 UTC 2021
On Mon, Mar 1, 2021 at 1:01 PM Alex White <alexanderjwhite at gmail.com> wrote:
> The tester configurations had not been updated to match the paths and
> conventions used by the new build system. These have been updated,
> and a few more libraries have been enabled in symbol-sets.ini.
> tester/rtems/testing/bsps/griscv-sis-cov.ini | 4 +-
> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 4 +-
> tester/rtems/testing/bsps/leon3-sis-cov.ini | 4 +-
> tester/rtems/testing/coverage/symbol-sets.ini | 91 ++++++++++---------
> 4 files changed, 52 insertions(+), 51 deletions(-)
> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> index 7249af6..e8de95f 100644
> --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> @@ -35,7 +35,7 @@
> bsp = griscv-sis
> arch = riscv
> tester = %{_rtscripts}/run.cfg
> -target = riscv-rtems5
> +target = riscv
These are the only ini files that define this target? With this
change, target is same as arch. Is target needed? I can't immediately
tell where it gets used later? 'target' is usually understood as the
binutil/gcc target triplet, so if the triplet is not being used, the
variable should be less misleading. covoar_target might be better if
this variable is needed in covar? I don't see it in any other
non-coverage ini files though, so maybe it is not needed at all?
> bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
> -bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
> +bsp_covoar_cmd = -T riscv-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
what about:
-T %{arch}-rtems%{rtems_version}
We should be limiting hard-coding version numbers.
> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> index 3b183e6..3d558db 100644
> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> @@ -34,8 +34,8 @@
> [leon3-qemu-cov]
> bsp = leon3-qemu
> arch = sparc
> -target = sparc-rtems5
> +target = sparc
> tester = %{_rtscripts}/qemu.cfg
> bsp_qemu_opts = %{qemu_opts_base} %{qemu_opts_serial} -M leon3_generic
> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> +bsp_covoar_cmd = -T sparc-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations}
> diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> index 626d314..66dae87 100644
> --- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> @@ -35,7 +35,7 @@
> bsp = leon3-sis
> arch = sparc
> +target = sparc
> bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -cov
> +bsp_covoar_cmd = -T sparc-rtems6 -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
> index 8f85533..9617dd8 100644
> --- a/tester/rtems/testing/coverage/symbol-sets.ini
> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> @@ -29,50 +29,51 @@
> [symbol-sets]
> -sets = score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
> +sets = score,rtems,sapi,posix,librfs,libpipe,libdosfs,libimfs,libjffs2,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libuntar,libblock,libcrypt,libmd,libstdthreads
> [libraries]
> -score = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
> -rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
> -sapi = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
> -libdl = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
> -posix = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
> -librfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
> -libdosfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
> -libdevfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
> -libimfs = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
> -#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
> -#libjffs2 = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
> -#dtc = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
> -#libdrvmgr = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
> -#libi2c = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
> -#libcsupport = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
> -libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
> -libcpuuse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
> -libstackchk = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
> -libfsmount = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
> -libstringto = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
> -libdevnull = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
> -libdumpbuf = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
> -#libcapture = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libdummy = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libmonitor = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libmouse = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libmw-fb = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#librtemsfdt = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libserdbg = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libshell = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libuntar = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libutf8proc = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libuuid = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -#libxz = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> -libblock = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
> -#libpci = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
> -#librpc = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
> -#libxdr = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
> -#libcrypt = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
> -#libmd = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
> -#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
> -#zlib = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
> +score = @BUILD-TARGET@/@BSP@/cpukit/score/src
> +rtems = @BUILD-TARGET@/@BSP@/cpukit/rtems/src
> +sapi = @BUILD-TARGET@/@BSP@/cpukit/sapi/src
> +libdl = @BUILD-TARGET@/@BSP@/cpukit/libdl
> +posix = @BUILD-TARGET@/@BSP@/cpukit/posix/src
> +librfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/rfs
> +libpipe = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/pipe
> +libdosfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/dosfs
> +#libdevfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/devfs
> +libimfs = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/imfs
> +#libdefaultsfs = @BUiLD-TARGET@/@BSP@/cpukit/libfs
> +libjffs2 = @BUILD-TARGET@/@BSP@/cpukit/libfs/src/jffs2/src
> +#dtc = @BUILD-TARGET@/@BSP@/cpukit/libfdt
> +#libdrvmgr = @BUILD-TARGET@/@BSP@/cpukit/libdrvmgr
> +#libi2c = @BUILD-TARGET@/@BSP@/cpukit/libi2c
> +libcsupport = @BUILD-TARGET@/@BSP@/cpukit/libcsupport/src
> +libbspcmdline = @BUILD-TARGET@/@BSP@/cpukit/libmisc/bspcmdline
> +libcpuuse = @BUILD-TARGET@/@BSP@/cpukit/libmisc/cpuuse
> +libstackchk = @BUILD-TARGET@/@BSP@/cpukit/libmisc/stackchk
> +libfsmount = @BUILD-TARGET@/@BSP@/cpukit/libmisc/fsmount
> +libstringto = @BUILD-TARGET@/@BSP@/cpukit/libmisc/stringto
> +libdevnull = @BUILD-TARGET@/@BSP@/cpukit/libmisc/devnull
> +libdumpbuf = @BUILD-TARGET@/@BSP@/cpukit/libmisc/dumpbuf
> +#libcapture = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libdummy = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libmonitor = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libmouse = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libmw-fb = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libredirector = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#librtemsfdt = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libserdbg = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libshell = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libtestsupport= @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +libuntar = @BUILD-TARGET@/@BSP@/cpukit/libmisc/untar
> +#libutf8proc = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libuuid = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +#libxz = @BUILD-TARGET@/@BSP@/cpukit/libmisc
> +libblock = @BUILD-TARGET@/@BSP@/cpukit/libblock/src
> +#libpci = @BUILD-TARGET@/@BSP@/cpukit/libpci
> +#librpc = @BUILD-TARGET@/@BSP@/cpukit/librpc
> +#libxdr = @BUILD-TARGET@/@BSP@/cpukit/librpc
> +libcrypt = @BUILD-TARGET@/@BSP@/cpukit/libcrypt
> +libmd = @BUILD-TARGET@/@BSP@/cpukit/libmd
> +libstdthreads = @BUILD-TARGET@/@BSP@/cpukit/libstdthreads
> +#zlib = @BUILD-TARGET@/@BSP@/cpukit/zlib
> 2.27.0
> devel mailing list
> devel at rtems.org
