[PATCH 18/22] covoar: Add option to create named objdumps
Tue Mar 2 23:37:45 UTC 2021
On 2/3/21 7:01 am, Alex White wrote:
> This adds a new macro USE_TEMPLFILE which allows the creation of named
> objdump outputs in the /tmp directory. This allows the outputs to be
> reused on subsequent runs of covoar rather than running objdump again.
Is the USE_TEMPLFILE macro a debugging aid?
If it is and it is useful could it be a command line argument to select a mode
that allows debugging? It means the code is always seen by the compiler and
built and anyone needing to chase down an issue has it available without needing
the code and rebuilding it. Plus as an argument the command will have some help
and that can be the documentation for this option.
>  rtemstoolkit/rld-process.cpp      | 12 ++++++++++++
>  rtemstoolkit/rld-process.h        |  9 +++++++++
>  tester/covoar/ObjdumpProcessor.cc | 16 +++++++++++-----
>  tester/covoar/app_common.cc       | 10 ++++++++++
>  tester/covoar/app_common.h        |  1 +
>  tester/covoar/covoar.cc           | 20 ++++++++++++++++++++
>  6 files changed, 63 insertions(+), 5 deletions(-)
> diff --git a/rtemstoolkit/rld-process.cpp b/rtemstoolkit/rld-process.cpp
> index 30e0605..d0352cb 100644
> --- a/rtemstoolkit/rld-process.cpp
> +++ b/rtemstoolkit/rld-process.cpp
> @@ -169,6 +169,18 @@ namespace rld
>        _name = temporaries.get (suffix, _keep);
> +    tempfile::tempfile (
> +      const std::string& name,
> +      const std::string& suffix,
> +      bool _keep
> +    ) : _name(name + suffix),
> +        suffix(suffix),
> +        overridden (false),
> +        fd (-1),
> +        level (0)
>      tempfile::~tempfile ()
>        try
> diff --git a/rtemstoolkit/rld-process.h b/rtemstoolkit/rld-process.h
> index fc9b7bc..16e0322 100644
> --- a/rtemstoolkit/rld-process.h
> +++ b/rtemstoolkit/rld-process.h
> @@ -114,6 +114,15 @@ namespace rld
>        tempfile (const std::string& suffix = ".rldxx", bool keep = false);
> +       * Get a temporary file name given a name and a suffix.
> +      tempfile (
> +        bool _keep = false
The addition is fine but there is a minor nit, the coding format I used in this
code from long ago is:
     tempfile (const std::string& name,
               bool _keep = false);
Would it be possible to keep it consistent with the other code, eg see `output`
further down in this file?
Should this also be a separate patch?
>         * Clean up the temporary file.
> diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
> index 00824f1..f130819 100644
> --- a/tester/covoar/ObjdumpProcessor.cc
> +++ b/tester/covoar/ObjdumpProcessor.cc
> @@ -245,12 +245,18 @@ namespace Coverage {
>                                           fileName };
>      try
> -      status = rld::process::execute( TargetInfo->getObjdump(),
> -                                      args, objdumpFile.name(), err.name() );
> -      if ( (status.type != rld::process::status::normal)
> -           || (status.code != 0) ) {
> -        throw rld::error( "Objdump error", "generating objdump" );
> +      #ifndef USE_TEMPFILE
> +      if (FileIsNewer( fileName.c_str(), objdumpFile.name().c_str() )) {
> +      #endif
> +        status = rld::process::execute( TargetInfo->getObjdump(),
> +                                        args, objdumpFile.name(), err.name() );
> +        if ( (status.type != rld::process::status::normal)
> +             || (status.code != 0) ) {
> +          throw rld::error( "Objdump error", "generating objdump" );
> +      #endif
>      } catch( rld::error& err )
>          std::cout << "Error while running " << TargetInfo->getObjdump()
> diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
> index 8b490ed..0f3c8e2 100644
> --- a/tester/covoar/app_common.cc
> +++ b/tester/covoar/app_common.cc
> @@ -116,3 +116,13 @@ bool ReadUntilFound( FILE *file, const char *line )
>    } while (1);
> +std::string GetFileNameFromPath( const std::string& path )
> +  size_t idx = path.rfind('/', path.length());
> +  if (idx == std::string::npos) {
> +    return "";
> +  return path.substr(idx + 1, path.length() - idx);
> diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
> index ac32bbd..21e8cfa 100644
> --- a/tester/covoar/app_common.h
> +++ b/tester/covoar/app_common.h
> @@ -30,5 +30,6 @@ extern char                         inputBuffer2[MAX_LINE_LENGTH];
>  bool FileIsNewer( const char *f1, const char *f2 );
>  bool FileIsReadable( const char *f1 );
>  bool ReadUntilFound( FILE *file, const char *line );
> +std::string GetFileNameFromPath( const std::string& path );
>  #endif
> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
> index bf95cb4..bc1b7cf 100644
> --- a/tester/covoar/covoar.cc
> +++ b/tester/covoar/covoar.cc
> @@ -162,7 +162,9 @@ int covoar(
>    FILE*                         gcnosFile = NULL;
>    Gcov::GcovData*               gcovFile;
>    const char*                   singleExecutable = NULL;
> +  #ifdef USE_TEMPFILE
>    rld::process::tempfile        objdumpFile( ".dmp" );
> +  #endif
>    rld::process::tempfile        err( ".err" );
>    rld::process::tempfile        syms( ".syms" );
>    bool                          debug = false;
> @@ -373,6 +375,22 @@ int covoar(
>        exe->setLoadAddress( objdumpProcessor->determineLoadAddress( exe ) );
> +    std::string name;
> +    if ( !exe->hasDynamicLibrary() ) {
> +      name = exe->getFileName();
> +    } else {
> +      name = exe->getLibraryName();
> +    name = GetFileNameFromPath( name );
> +    name = buildTarget + "-" + name;
> +    name.insert( 0, "/tmp/" );
> +    rld::process::tempfile objdumpFile( name, ".dmp", true );
> +    #endif
>      // Load the objdump for the symbols in this executable.
>      objdumpProcessor->load( exe, objdumpFile, err );
> @@ -486,8 +504,10 @@ int covoar(
>    //Leave tempfiles around if debug flag (-d) is enabled.
>    if ( debug ) {
>      objdumpFile.override( "objdump_file" );
>      objdumpFile.keep();
> +    #endif
>      err.override( "objdump_exec_log" );
>      err.keep();
>      syms.override( "symbols_list" );
