[PATCH 4/4] score: Ensure stack alignment requirement
Sebastian Huber
Wed Mar 3 08:40:22 UTC 2021
Make sure we meet the stack aligment requirement also for CPU ports with
CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
cpukit/include/rtems/score/context.h | 3 +--
cpukit/include/rtems/score/stackimpl.h | 9 +++++++++
cpukit/score/src/threadinitialize.c | 9 +++++++++
cpukit/score/src/tlsallocsize.c | 14 +++++++++++---
4 files changed, 30 insertions(+), 5 deletions(-)
diff --git a/cpukit/include/rtems/score/context.h b/cpukit/include/rtems/score/context.h
index 46e04e9600..b65c15e73b 100644
--- a/cpukit/include/rtems/score/context.h
+++ b/cpukit/include/rtems/score/context.h
@@ -49,8 +49,7 @@ extern "C" {
#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
#define CONTEXT_FP_SIZE \
- ( ( CPU_CONTEXT_FP_SIZE + CPU_HEAP_ALIGNMENT - 1 ) \
- & ~( CPU_HEAP_ALIGNMENT - 1 ) )
+ RTEMS_ALIGN_UP( CPU_CONTEXT_FP_SIZE, CPU_STACK_ALIGNMENT )
#else
#define CONTEXT_FP_SIZE 0
#endif
diff --git a/cpukit/include/rtems/score/stackimpl.h b/cpukit/include/rtems/score/stackimpl.h
index 43b7c8151e..4ff56eea93 100644
--- a/cpukit/include/rtems/score/stackimpl.h
+++ b/cpukit/include/rtems/score/stackimpl.h
@@ -149,6 +149,15 @@ RTEMS_INLINE_ROUTINE size_t _Stack_Extend_size(
stack_size += extra_size;
+#if CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT
+ * If the heap allocator does not meet the stack alignment requirement, then
+ * we have to do the stack alignment manually in _Thread_Initialize() and
+ * need to allocate extra space for this.
+ stack_size += CPU_STACK_ALIGNMENT - 1;
+#endif
if ( stack_size < extra_size ) {
* In case of an unsigned integer overflow, saturate at the maximum value.
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 3a331ed269..a672c02911 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -107,6 +107,9 @@ static bool _Thread_Try_initialize(
size_t i;
char *stack_begin;
char *stack_end;
+ uintptr_t stack_align;
+#endif
Scheduler_Node *scheduler_node;
#if defined(RTEMS_SMP)
Scheduler_Node *scheduler_node_for_index;
@@ -131,6 +134,12 @@ static bool _Thread_Try_initialize(
stack_begin = config->stack_area;
stack_end = stack_begin + config->stack_size;
+ stack_align = CPU_STACK_ALIGNMENT;
+ stack_begin = (char *) RTEMS_ALIGN_UP( (uintptr_t) stack_begin, stack_align );
+ stack_end = (char *) RTEMS_ALIGN_DOWN( (uintptr_t) stack_end, stack_align );
+#endif
/* Allocate floating-point context in stack area */
if ( config->is_fp ) {
diff --git a/cpukit/score/src/tlsallocsize.c b/cpukit/score/src/tlsallocsize.c
index e7854c677a..cba5bdcfba 100644
--- a/cpukit/score/src/tlsallocsize.c
+++ b/cpukit/score/src/tlsallocsize.c
@@ -59,14 +59,16 @@ uintptr_t _TLS_Get_allocation_size( void )
allocation_size = _TLS_Allocation_size;
if ( allocation_size == 0 ) {
- allocation_size = _TLS_Heap_align_up( size );
- alignment = _TLS_Heap_align_up( (uintptr_t) _TLS_Alignment );
+ uintptr_t stack_alignment;
+ stack_alignment = CPU_STACK_ALIGNMENT;
+ alignment = RTEMS_ALIGN_UP( (uintptr_t) _TLS_Alignment, stack_alignment );
* The stack allocator does not support aligned allocations. Allocate
* enough to do the alignment manually.
- if ( alignment > CPU_HEAP_ALIGNMENT ) {
+ if ( alignment > stack_alignment ) {
allocation_size += alignment;
@@ -76,6 +78,12 @@ uintptr_t _TLS_Get_allocation_size( void )
allocation_size += sizeof(TLS_Dynamic_thread_vector);
#endif
+ * The TLS area is allocated in the thread storage area. Each allocation
+ * shall meet the stack alignment requirement.
+ allocation_size = RTEMS_ALIGN_UP( allocation_size, stack_alignment );
if ( _Thread_Maximum_TLS_size != 0 ) {
if ( allocation_size <= _Thread_Maximum_TLS_size ) {
allocation_size = _Thread_Maximum_TLS_size;
2.26.2
