[PATCH rtems-libbsd 1/2] racoon/session: Honor file descriptor maximum
Christian MAUDERER
christian.mauderer at embedded-brains.de
Wed Mar 3 08:41:09 UTC 2021
Hello Chris,
Am 03.03.21 um 02:17 schrieb Chris Johns:
> On 2/3/21 7:26 pm, Christian MAUDERER wrote:
>> Hello Chris,
>> Am 02.03.21 um 01:03 schrieb Chris Johns:
>>> On 1/3/21 7:24 pm, Christian MAUDERER wrote:
>>>> Hello Chris,
>>>> thanks for the review.
>>>> Am 26.02.21 um 19:04 schrieb Chris Johns:
>>>>> On 26/2/21 2:01 am, Christian Mauderer wrote:
>>>>>> Dynamically allocate a big enough file descriptor set for select(). A
>>>>>> better solution would be to use kqueue() instead of select().
>>>>>> .../racoon/rtems-bsd-racoon-session-data.h | 6 +--
>>>>>> ipsec-tools/src/racoon/session.c | 40 +++++++++++++++++++
>>>>>> 2 files changed, 43 insertions(+), 3 deletions(-)
>>>>>> diff --git a/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
>>>>>> b/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
>>>>>> index b869a1518..196107a35 100644
>>>>>> --- a/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
>>>>>> +++ b/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
>>>>>> @@ -2,11 +2,11 @@
>>>>>> #include <rtems/linkersets.h>
>>>>>> #include "rtems-bsd-racoon-data.h"
>>>>>> /* session.c */
>>>>>> -RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static fd_set active_mask);
>>>>>> -RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static fd_set preset_mask);
>>>>>> +RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static _types_fd_set
>>>>>> *allocated_active_mask);
>>>>>> *allocated_preset_mask);
>>>>>> RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static int nfds);
>>>>>> RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static int signals[]);
>>>>>> RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static sig_atomic_t volatile
>>>>>> volatile sigreq[]);
>>>>>> -RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct fd_monitor
>>>>>> fd_monitors[]);
>>>>>> +RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct fd_monitor
>>>>>> *allocated_fd_monitors);
>>>>>> RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct fd_monitor_list
>>>>>> fd_monitor_tree[]);
>>>>>> RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct sched scflushsa);
>>>>>> diff --git a/ipsec-tools/src/racoon/session.c
>>>>>> b/ipsec-tools/src/racoon/session.c
>>>>>> index 65124c15e..90120c761 100644
>>>>>> --- a/ipsec-tools/src/racoon/session.c
>>>>>> +++ b/ipsec-tools/src/racoon/session.c
>>>>>> @@ -65,6 +65,10 @@
>>>>>> #include <sys/stat.h>
>>>>>> #include <paths.h>
>>>>>> #include <err.h>
>>>>>> +#ifdef __rtems__
>>>>>> +#include <sys/param.h>
>>>>>> +#include <rtems/libio_.h>
>>>>>> +#endif /* __rtems__ */
>>>>>> #include <netinet/in.h>
>>>>>> #include <resolv.h>
>>>>>> @@ -123,8 +127,16 @@ static void check_sigreq __P((void));
>>>>>> static void check_flushsa __P((void));
>>>>>> static int close_sockets __P((void));
>>>>>> +#ifndef __rtems__
>>>>>> static fd_set preset_mask, active_mask;
>>>>>> static struct fd_monitor fd_monitors[FD_SETSIZE];
>>>>>> +#else /* __rtems__ */
>>>>>> +static fd_set *allocated_preset_mask, *allocated_active_mask;
>>>>>> +static struct fd_monitor *allocated_fd_monitors;
>>>>>> +#define preset_mask (*allocated_preset_mask)
>>>>>> +#define active_mask (*allocated_active_mask)
>>>>>> +#define fd_monitors (allocated_fd_monitors)
>>>>>> static TAILQ_HEAD(fd_monitor_list, fd_monitor)
>>>>>> fd_monitor_tree[NUM_PRIORITIES];
>>>>>> static int nfds = 0;
>>>>>> @@ -134,7 +146,11 @@ static struct sched scflushsa = SCHED_INITIALIZER();
>>>>>> void
>>>>>> monitor_fd(int fd, int (*callback)(void *, int), void *ctx, int priority)
>>>>>> +#ifndef __rtems__
>>>>>> if (fd < 0 || fd >= FD_SETSIZE) {
>>>>>> + if (fd < 0 || fd >= rtems_libio_number_iops) {
>>>>>> plog(LLV_ERROR, LOCATION, NULL, "fd_set overrun");
>>>>>> exit(1);
>>>>>> @@ -158,7 +174,11 @@ monitor_fd(int fd, int (*callback)(void *, int), void
>>>>>> *ctx, int priority)
>>>>>> void
>>>>>> unmonitor_fd(int fd)
>>>>>> +#ifndef __rtems__
>>>>>> exit(1);
>>>>>> @@ -186,7 +206,22 @@ session(void)
>>>>>> struct fd_monitor *fdm;
>>>>>> nfds = 0;
>>>>>> +#ifndef __rtems__
>>>>>> FD_ZERO(&preset_mask);
>>>>>> + allocated_preset_mask = calloc(sizeof(fd_set),
>>>>>> + howmany(rtems_libio_number_iops, sizeof(fd_set) * 8));
>>>>> Does `maxfiles` work here?
>>>> To be honest: I'm not sure.
>>>> According to the comment in file.h:
>>>> extern int maxfiles; /* kernel limit on number of open files */
>>> Yes.
>>>> Sounds like it _can_ be the same as the maximum file number but doesn't have to.
>>> I think we need to have them be the same value.
>>>> I didn't find where we implement it. It's declared as an extern int maxfiles but
>>>> I didn't find any definition. I found it only in libbsd in
>>>> freebsd/sys/kern/uipc_socket.c where it is defined like follows:
>>>> #define maxfiles rtems_libio_number_iops
>>> Ah OK. I knew it had been assigned somewhere and yes it looks like it is local
>>> to that file.
>>>> So question is: Where and how is maxfiles defined?
>>> I have provided a value in the rtemsbsd init file as part of the set og globals
>>> we need to maintained.
>> Somehow I missed that. Where can I find it?
> Again sorry, I was in a rush and I was not clear. I have add this in my new
> changes for NFSv4 support and this is what I sorted out.
Ah, OK. In that case I'll keep the rtems_libio_number_iops at the moment
if it is OK for you.
>>>>>> + if (allocated_preset_mask == NULL)
>>>>>> + errx(1, "failed to allocate preset_mask");
>>>>>> + allocated_active_mask = calloc(sizeof(fd_set),
>>>>>> + if (allocated_active_mask == NULL)
>>>>>> + errx(1, "failed to allocate active_mask");
>>>>>> + allocated_fd_monitors = calloc(
>>>>>> + rtems_libio_number_iops, sizeof(struct fd_monitor));
>>>>>> + if (allocated_fd_monitors == NULL)
>>>>>> + errx(1, "failed to allocate fd_monitors");
>>>>> At the core of this issue is the rotating fd allocation that we have in
>>>>> libio. A
>>>>> report from a FreeBSD machine I have is:
>>>>> $ sysctl -a | grep maxfiles
>>>>> kern.maxfiles: 1037243
>>>>> kern.maxfilesperproc: 933516
>>>>> I doubt a select process in FreeBSD needs a select array with that many bits. I
>>>>> have added similar code else where but I am wondering if this is really what we
>>>>> want to do. A side effect for us is the stack usage is not bounded and that
>>>>> is a
>>>>> problem. I think our newlib based max setting is too small.
>>>> I think we have to distinguish between FreeBSD kernel space and user space. If I
>>>> have seen it correctly, FreeBSD uses kqueues or maybe sometimes poll instead of
>>>> select in kernel space most of the time. That avoids the problem with big file
>>>> numbers.
>>> Yes kqueue is nice but we need to support existing code and this is a primary
>>> role libbsd needs to perform. The lack is signals in libbsd is another source of
>>> issue.
>> I didn't want to say that we should not support select. I only wanted to say
>> that FreeBSD most likely just avoids that problem in kernel space so that they
>> don't have to support a select with 1037243 files. In user space they limit a
>> select to 1024 files.
> Yes they do. My suggestion of us using 1024 is FreeBSD applications are fine
> with this then they should be portable to RTEMS and libbsd and the need for us
> to patch code is removed.
1024 for a select is quite much for an embedded system. It means that we
will need 128 bytes of stack for each select call in the future. It's a
quite big change.
Another possibility would be 256 (32 bytes) like some other *BSD do.
Maybe we should start a new discussion thread about the right FD_SETSIZE
so that more developers get involved?
>>>> Default for FreeBSD seems to be a FD_SETSIZE of 1024. See the Notes section in
>>>> the select man page:
>>>> https://www.freebsd.org/cgi/man.cgi?query=select&sektion=2&manpath=freebsd-release-ports#end
>>> Yes.
>>>> I think select is used in user space applications most of the time. I would
>>>> guess that FreeBSD has some file number mapping between kernel and user space
>>>> that would allow every application to open 1024 files.
>>> Yes. There are other checks and arrays in the kernel's select that handle the
>>> size of 1024 or smaller. We should align ourselves with FreeBSD. A select call
>>> uses a lot of stack.
>> I have no problem if we align more with FreeBSD. But I'm not sure how much
>> effort that would be. And we have to be careful not to increase the memory usage
>> for small targets too much.
> We need to find a path between that sort of space optimization and the
> functionality libbsd brings. The select call is costly in terms of stack size as
> the kern_select call has:
> * The magic 2048 here is chosen to be just enough for FD_SETSIZE
> * infds with the new FD_SETSIZE of 1024, and more than enough for
> * FD_SETSIZE infds, outfds and exceptfds with the old FD_SETSIZE
> * of 256.
> fd_mask s_selbits[howmany(2048, NFDBITS)];
> I do not know if this means we need to be more concerned about the size of less.
Hm. They could have used FD_SETSIZE instead of the magic value with a
comment...
I think a big problem for RTEMS is that we have shared file numbers for
all processes. This makes 1024 a lot less compared to starting from 0
for every process.
>>>>> FYI I have a major set of changes to libbsd that enables FreeBSD descriptor
>>>>> support and moves the libio support to specific interfaces.
>>>> OK. When do you plan to add that and to which branches?
>>> I am looking 6-freebsd-12 and master. Thses changes are a major rework and not
>>> suitable for 5.
>> I assumed that.
>>>> I would like to add this
>>>> patch set to 5 sooner or later because it fixes a potential bug in racoon for
>>>> that branch too.
>>> Sorry I missed this for 5. I will need to think about this on 5. I do not think
>>> it is a problem but I am not sure about it on 6 and beyond. I would prefer we
>>> consider a better fix for select that the limited 64 descriptors we currently
>>> have.
>> Maybe we should take a multi step approach:
>> Use the workaround like I suggested for 5 and (at the moment) for master. A
>> similar workaround is already used in quite some other locations in libbsd. So
>> it's not a new method.
>> Start a ticket and a discussion for a better solution.
> Sounds a good approach. I am fine with the changes because it is what we have to
> do and this was not meant to halt the progress, rather I wanted to have the
> discussion and raise the concerns.
OK. Thanks. Like I said: Maybe we should create a ticket and start an
extra discussion thread to get more ideas?
>> I'm not sure yet how that
>> could look like. Some impressions from other systems:
>> - FreeBSD, OpenBSD, NetBSD and DragonFly BSD are using the same method we use
>> (or most likely the other way round) only with different FD_SETSIZEs:
>> https://cgit.freebsd.org/src/tree/sys/sys/select.h
>> https://github.com/NetBSD/src/blob/trunk/sys/sys/fd_set.h
>> https://github.com/openbsd/src/blob/master/sys/sys/select.h
>> https://gitweb.dragonflybsd.org/dragonfly.git/blob/HEAD:/sys/sys/_fd_set.h
>> - Linux Kernels nolibc.h used in Tests does the same again (GPL or MIT):
>> https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/tools/include/nolibc/nolibc.h#n2522
>> - Apple is the same again. I'm not sure about the Apple license therefore no
>> link here so I don't spoil anyone beneath myself.
>> There are others that could be worth a look like Haiku, Musl-Libc, and so on.
>> But my general impression is that there is no much better solution at least in
>> the bigger systems except for avoiding select or setting a bigger FD_SETSIZE.
>> The most common ones seem to be 256 or 1024. But that only moves the problem a
>> bit further away.
> Yes select does not offer a great range of solutions. As Sebastian has stated a
> number of times kqueue does and this should be encouraged. And kqueue by passes
> the signal issue that seems to acompany select, eg timer signals.
> I see the central quesiton being the role libbsd plays and I feel it is to aid
> porting code to RTEMS and easily as possible. New code written for RTEMS should
> avoid select.
Agreed: Select is evil ;-)
Just kidding: It's clear that we have to handle application that use
select too due to portability reasons. I'm just not sure what a good
solution would be. It feels like every solution is a bad one: If we
increase FD_SETSIZE to typical values on desktop systems (256 or 1024),
we will need a lot of stack and only cover a part of the applications.
If we change every location in the libraries it increases maintenance
effort.
Best regards
Christian
> Chris
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
