[PATCH v2 2/3] cpukit: Explicitly enforce alignment requirements
Wed Mar 3 08:52:53 UTC 2021
On 02/03/2021 21:00, Gedare Bloom wrote:
>> + * The use of explicit alignment is necessary below due to behavioral
>> + * expectations of GCC on which RTEMS has relied in the past. These
>> + * behaviors were consistent, but never guaranteed. Some newer platforms
>> + * violate this previous consistency. For more information, see GCC bug
>> + *https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99143
> I think the comment can be simplified, but I can tell you got bugged
> by this. (pun, intended)
> To summarize my understanding, GCC now optimizes space more
> aggressively, and if we want an explicit alignment, it has to be
> explicitly made on each variable that must be aligned. ("typedef"
> alignment now seems to be ignored.)
The problem is that GCC "optimizes" for speed (not size) aggressively
and may increase the alignment required by the type. The attribute is
required to force GCC to use specified requirement.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
