About HEAP error
Gedare Bloom
gedare at rtems.org
Wed Mar 3 15:50:06 UTC 2021
On Wed, Mar 3, 2021 at 12:08 AM Richi Dubey <richidubey at gmail.com> wrote:
> What's the element written after the free? I set a watch at the exact block location, but it doesn't work:
> Hardware watchpoint 7: *0x202ba8
> (gdb) watch *0x206fec
> Hardware watchpoint 8: *0x206fec
That's just the first byte in the block. If you can figure out which
bytes/words in the block get accessed that would help you.
> (gdb) c
> Continuing.
> Thread 1 hit Breakpoint 6, Init (argument=2107944) at /home/richi/quick-start/LatestStrong/src/rtems/c/src/../../testsuites/sptests/sp02/init.c:26
> 26 TEST_BEGIN();
> (gdb)
> Continuing.
> Thread 1 hit Breakpoint 5, _Terminate (the_source=RTEMS_FATAL_SOURCE_HEAP, the_error=2125180) at /home/richi/quick-start/LatestStrong/src/rtems/c/src/../../cpukit/score/src/interr.c:38
> 38 _User_extensions_Fatal( the_source, the_error );
> (gdb)
> Continuing.
> Thread 1 hit Breakpoint 4, bsp_reset () at /home/richi/quick-start/LatestStrong/src/rtems/c/src/lib/libbsp/arm/realview-pbx-a9/../../../../../../bsps/arm/realview-pbx-a9/start/bspreset.c:19
> 19 volatile uint32_t *sys_lock = (volatile uint32_t *) 0x10000020;
> (gdb)
> On Wed, Mar 3, 2021 at 12:31 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 02/03/2021 05:44, Richi Dubey wrote:
>> > (gdb) p *(Heap_Error_context*)(0x00206d7c)
>> > $5 = {
>> > heap = 0x202ba8 <_Workspace_Area>,
>> > block = 0x206fec,
>> > reason = HEAP_ERROR_FREE_PATTERN
>> If it is always the same address, then you can set a watch point to an
>> element which is written after the free to catch the function which
>> writes into this area.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
