Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
junkes
junkes at fhi-berlin.mpg.de
Wed Mar 3 17:09:59 UTC 2021
>> In file included from
>> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:1:
>> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:164:2: error:
>> #error rtemscompat_defs.h must define either NET_CHIP_LE or
>> NET_CHIP_BE
>> 164 | #error rtemscompat_defs.h must define either NET_CHIP_LE or
>> NET_CHIP_BE
> Hopefully this is fixed by adding the include directory or something
> similar.
> Vijay should speak up on his desired solution.
> Heinz, how did the code find this when it was built in the tree? Did it
> have
> a -I for this source directory?
> --joel
>> 8:04:57 runner
>> ['/home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-gcc',
>> '-mcpu=7400',
>> '-I/home/junkes/MVME6100_testing/rtems/6/powerpc-rtems6/beatnik/lib/include',
>> '-MMD', '-I.', '-I../..', '-Iinclude', '-I../../include',
>> '-I../rtems/6', '-I../../../rtems/6', '-Itestsuites/include',
>> '-I../../testsuites/include', '-I../rtems/6/include',
>> '-I../../../rtems/6/include', '-Ibsps/include',
>> '-I../../bsps/include', '-I../rtems/6/powerpc-rtems6/beatnik/lib',
>> '-I../../../rtems/6/powerpc-rtems6/beatnik/lib',
>> '-I../rtems/6/powerpc-rtems6/beatnik/lib/include',
>> '-I../../../rtems/6/powerpc-rtems6/beatnik/lib/include',
>> '-Ibsps/include/libchip', '-I../../bsps/include/libchip',
>> '-Ibsps/powerpc/beatnik/net/porting',
>> '-I../../bsps/powerpc/beatnik/net/porting', '../../net/radix.c', '-c',
>> '-o/home/junkes/MVME6100_testing/legacyNet/build/powerpc-rtems6-beatnik/net/radix.c.2.o']
>> Heinz
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210303/58a029b7/attachment-0001.html>
