Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
Joel Sherrill
joel at rtems.org
Wed Mar 3 17:37:55 UTC 2021
On Wed, Mar 3, 2021 at 11:14 AM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> Hello Heinz, Joel,
> On Wed, Mar 3, 2021 at 7:03 AM Joel Sherrill <joel at rtems.org> wrote:
> > On Wed, Mar 3, 2021 at 3:39 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
> >> Dear Vijay,
> >> thank you very much for your effort to bring some order here ;-)
> >> I am currently trying to get EPICS to work on RTEMS6 as well.
> >> I already failed with the legacy stack because configuration variables
> like
> >> RTEMS_HAS_NETWORK are not set with the waf-builder.
> >> That's why I quite happily jumped on your legacy-net-extra
> >> (For the beatnik CPU on which I can test directly on the hardware).
> >> Unfortunately, it doesn't quite work yet:
> >> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> >> cd rsb
> >> cd rtems
> >> ../source-builder/sb-set-builder
> --prefix=/home/junkes/MVME6100_testing/rtems/6 6/rtems-powerpc
> >> cd ../..
> >> #RTEMS development
> >> export RTEMS_VERSION=6
> >> export RTEMS_ARCH=powerpc-rtems${RTEMS_VERSION}
> >> export RTEMS_ROOT=/home/junkes/MVME6100_testing/rtems/${RTEMS_VERSION}
> >> export PATH=${RTEMS_ROOT}/bin:${PATH}
> >> # building kernel
> >> #git clone git://git.rtems.org/rtems.git kernel
> >> git clone git://git.rtems.org/vijay/rtems.git kernel
> >> cd kernel
> A note: the updated branch is devel-no-libnet in my fork
> >> # build and install bsp
> >> # 1. Test with waf
> >> #-e "s|RTEMS_NETWORKING = False|RTEMS_NETWORKING = True|" \
> >> ./waf bsp_defaults --rtems-bsps=powerpc/beatnik > config.ini
> >> sed -i \
> >> -e "s|RTEMS_POSIX_API = False|RTEMS_POSIX_API = True|" \
> >> -e "s|BUILD_TESTS = False|BUILD_TESTS = True|" \
> >> config.ini
> >> ./waf configure --prefix=/home/junkes/MVME6100_testing/rtems/6
> >> ./waf
> >> ./waf install
> >> cd ..
> >> # building extra legacy net
> >> git clone git://git.rtems.org/vijay/rtems-net-legacy.git legacyNet
> Please pull from the main branch, I just pushed a fix.
> >> cd legacyNet
> >> git submodule init
> >> git submodule update
> >> Setting top to : /home/junkes/MVME6100_testing/legacyNet
> >> Setting out to : /home/junkes/MVME6100_testing/legacyNet/build
> >> RTEMS Version : 6
> >> Architectures : powerpc-rtems6
> >> Board Support Package (BSP) : powerpc-rtems6-beatnik
> >> Show commands : no
> >> Long commands : no
> >> Checking for program 'powerpc-rtems6-gcc' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-gcc
> >> Checking for program 'powerpc-rtems6-g++' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-g++
> >> Checking for program 'powerpc-rtems6-ld' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-ld
> >> Checking for program 'powerpc-rtems6-ar' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-ar
> >> Checking for program 'powerpc-rtems6-nm' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-nm
> >> Checking for program 'powerpc-rtems6-objdump' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-objdump
> >> Checking for program 'powerpc-rtems6-objcopy' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-objcopy
> >> Checking for program 'powerpc-rtems6-readelf' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-readelf
> >> Checking for program 'powerpc-rtems6-strip' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-strip
> >> Checking for program 'powerpc-rtems6-ranlib' :
> /home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-ranlib
> >> Checking for program 'rtems-ld' :
> /home/junkes/MVME6100_testing/rtems/6/bin/rtems-ld
> >> Checking for program 'rtems-tld' :
> /home/junkes/MVME6100_testing/rtems/6/bin/rtems-tld
> >> Checking for program 'rtems-syms' :
> /home/junkes/MVME6100_testing/rtems/6/bin/rtems-syms
> >> Checking for program 'rtems-bin2c' :
> /home/junkes/MVME6100_testing/rtems/6/bin/rtems-bin2c
> >> Checking for program 'tar' : /usr/bin/tar
> >> Checking for program 'gcc, cc' :
> >> Checking for program 'ar' :
> >> Checking for program 'g++, c++' :
> >> Checking for program 'gas, gcc' :
> >> Checking for c flags '-MMD' : yes
> >> Checking for cxx flags '-MMD' : yes
> >> Compiler version (powerpc-rtems6-gcc) : 10.2.1 20210205 (RTEMS 6, RSB
> 61dcadee0825867ebe51f9f367430ef75b8fe9c0, Newlib d4a756f)
> >> Checking for a valid RTEMS BSP installation : yes
> >> Checking for RTEMS_DEBUG : no
> >> Checking for RTEMS_MULTIPROCESSING : no
> >> Checking for RTEMS_NEWLIB : yes
> >> Checking for RTEMS_POSIX_API : yes
> >> Checking for RTEMS_SMP : no
> >> Checking for RTEMS_NETWORKING : no
> >> 'configure' finished successfully (0.840s)
> >> ./waf build --rtems-archs=powerpc --rtems-bsps=beatnik
> >> Waf: Entering directory
> `/home/junkes/MVME6100_testing/legacyNet/build/powerpc-rtems6-beatnik'
> >> [ 1/229] Compiling bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c
> >> [ 2/229] Compiling bsps/powerpc/beatnik/net/porting/if_xxx.modini.c
> >> [ 3/229] Compiling librpc/src/rpc/pmap_getport.c
> >> [ 4/229] Compiling netinet/ip_icmp.c
> >> [ 5/229] Compiling libc/getservbyname.c
> >> [ 6/229] Compiling libc/base64.c
> >> [ 7/229] Compiling libc/ns_ttl.c
> >> [ 8/229] Compiling libc/inet_makeaddr.c
> >> [ 9/229] Compiling librpc/src/rpc/auth_none.c
> >> [ 10/229] Compiling librpc/src/rpc/get_myaddress.c
> >> [ 11/229] Compiling netinet/tcp_debug.c
> >> [ 12/229] Compiling librpc/src/rpc/netnamer.c
> >> [ 13/229] Compiling librpc/src/rpc/svc_auth.c
> >> [ 14/229] Compiling librpc/src/rpc/rtems_portmapper.c
> >> [ 15/229] Compiling netinet/tcp_subr.c
> >> [ 16/229] Compiling librpc/src/rpc/svc_simple.c
> >> ../../libc/getservbyname.c: In function 'getservbyname_r':
> >> ../../libc/getservbyname.c:54:4: warning: #warning "implement a proper
> getservbyport_r" [-Wcpp]
> >> 54 | #warning "implement a proper getservbyport_r"
> > This is expected. getservbyport_r() just calls getservbyport() in the
> legacy
> > implementation so is not reentrant.
> >> [ 17/229] Compiling rtems/rtems_bootp.c
> >> [ 18/229] Compiling net/if.c
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx.modini.c:2:10: fatal
> error: porting/rtemscompat.h: No such file or directory
> >> 2 | #include <porting/rtemscompat.h>
> >> compilation terminated.
> > This looks like an include directory needs to be added to the build.
> > The code in question is part of the pattern for an adapter kit Till
> > tended to include to port newer BSD drivers to the legacy stack.
> > At this point, the "newer BSD" is quite old and the BSD version in
> > the legacy stack is ancient. Lesson is using old, new, future, next
> > generation, etc with technology is inevitable to be wrong eventually.
> >> In file included from
> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:1:
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:164:2: error:
> #error rtemscompat_defs.h must define either NET_CHIP_LE or NET_CHIP_BE
> >> 164 | #error rtemscompat_defs.h must define either NET_CHIP_LE or
> NET_CHIP_BE
> > Hopefully this is fixed by adding the include directory or something
> > similar.
> > Vijay should speak up on his desired solution.
> This code was not being built by RTEMS source either, even If I fix
> the include directory path, it still searches for a header file that
> doesn't exist in the RTEMS source tree. I have pushed a fix that
> removes this file and fixes the build for all other files in beatnik.
> I have also fixed a fundamental error in my build script because of
> which this file got skipped when I tried it with the update branch.
Was this code built on 5? Or not by waf?
FWIW
> Currently the "devel-no-libnet" branch in RTEMS and "main" branch in
> rtems-net-legacy build successfully for beatnik.
> Heinz, could you please pull the changes and let me know if the fix works?
> Best regards,
> Vijay
> > Heinz, how did the code find this when it was built in the tree? Did it
> have
> > a -I for this source directory?
> > --joel
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h: In function
> 'bus_space_do_read_2':
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:267:9: warning:
> implicit declaration of function '_inp_word'
> [-Wimplicit-function-declaration]
> >> 267 | return _inp_word((volatile unsigned short*)((handle)+(reg)));
> 'bus_space_do_read_4':
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:272:9: warning:
> implicit declaration of function '_inp_long'
> >> 272 | return _inp_long((volatile unsigned *)((handle)+(reg)));
> 'bus_space_do_write_multi_2':
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:286:31: warning:
> implicit declaration of function '_out_word'
> >> 286 | int i; for (i=0; i<cnt; i++) _out_word( (handle) + (reg),
> (addr)[i]);
> 'bus_space_do_write_multi_4':
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:291:31: warning:
> implicit declaration of function '_out_long'
> >> 291 | int i; for (i=0; i<cnt; i++) _out_long( (handle) + (reg),
> (addr)[i]);
> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:40:
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat1.h: At top level:
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat1.h:16:19: error:
> field 'd_softc' has incomplete type
> >> 16 | struct NET_SOFTC d_softc; /* MUST BE FIRST FIELD */
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat1.h:28:38: error:
> 'NETDRIVER_SLOTS' undeclared here (not in a function)
> >> 28 | #define NETDEV_DECL netdev_t THEDEVS[NETDRIVER_SLOTS]
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat1.h:30:8: note: in
> expansion of macro 'NETDEV_DECL'
> >> 30 | extern NETDEV_DECL;
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat1.h: In function
> 'net_dev_get':
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat1.h:50:28: error:
> expected ')' before 'NETDRIVER'
> >> 50 | device_printf(dev, "Bad "NETDRIVER" unit number.\n");
> >> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:258:53: note: in
> definition of macro 'device_printf'
> >> 258 | #define device_printf(device,format,args...) printk(format,##
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c: In function
> 'rtems_NETDRIVER_PREFIX_attach':
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:131:21: error:
> 'NETDRIVER' undeclared (first use in this function)
> >> 131 | device_printf(dev,NETDRIVER" unit not configured; use
> 'rtems_"NETDRIVER"_setup()'\n");
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:131:21: note:
> each undeclared identifier is reported only once for each function it
> appears in
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:131:30: error:
> expected ')' before string constant
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:140:11: error:
> invalid use of undefined type 'struct NETDRIVER_PREFIX_softc'
> >> 140 | ifp = &sc->arpcom.ac_if;
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:151:31: error:
> >> 151 | device_printf(dev,NETDRIVER" Driver already attached.\n");
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:156:13: error:
> >> 156 | memcpy(sc->arpcom.ac_enaddr, config->hardware_address,
> ETHER_ADDR_LEN);
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:163:31: error:
> >> 163 | device_printf(dev,NETDRIVER"_attach() failed\n");
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:168:31: error:
> >> 168 | device_printf(dev,NETDRIVER" Driver not attached.\n");
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:173:32: error:
> >> 173 | device_printf(dev,NETDRIVER"_detach() failed\n");
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:177:31: error:
> >> 177 | device_printf(dev,NETDRIVER"_detach() not implemented\n");
> args)
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:183:10: error:
> >> 183 | if ( !sc->tid )
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:184:5: error:
> >> 184 | sc->tid = rtems_bsdnet_newproc(NETDRIVER"d", 4096, net_daemon,
> sc);
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:184:43: error:
> sc);
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:184:13: error:
> too few arguments to function 'rtems_bsdnet_newproc'
> sc);
> ../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:42,
> >> from ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:1:
> >> ../../rtems/rtems_bsdnet_internal.h:169:10: note: declared here
> >> 169 | rtems_id rtems_bsdnet_newproc (
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:194:23: error:
> >> 194 | irq_data.name = sc->irq_no;
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:203:28: error:
> >> 203 | fprintf(stderr,NETDRIVER": unable to install ISR\n");
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:207:10: error:
> >> 207 | if ( sc->irq_no ) {
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:215:23: error:
> >> 215 | irq_data.name = sc->irq_no;
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:222:28: error:
> >> 222 | fprintf(stderr,NETDRIVER": unable to uninstall ISR\n");
> 'the_net_isr':
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:242:2: warning:
> implicit declaration of function 'NET_DISABLE_IRQS'
> >> 242 | NET_DISABLE_IRQS(sc);
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:244:29: error:
> >> 244 | rtems_bsdnet_event_send( sc->tid, EX_EVENT );
> 'net_daemon':
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:262:3: warning:
> implicit declaration of function 'NET_ENABLE_IRQS'
> >> 262 | NET_ENABLE_IRQS(sc);
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c: At top level:
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:286:2: error:
> 'NETDRIVER' undeclared here (not in a function)
> >> 286 | NETDRIVER"1",
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:286:11: error:
> expected '}' before string constant
> >> 286 | NETDRIVER"1",
> >> ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:285:74: note: to
> match this '{'
> >> 285 | struct rtems_bsdnet_ifconfig
> NET_EMBEMB(NETDRIVER_PREFIX,_dbg,_config) = {
> >> Waf: Leaving directory
> >> Build failed
> >> -> task in 'bsp_objs' failed with exit status 1 (run with -v to display
> more information)
> more information)
> >> Viele Grüße und Danke,
> >> Heinz
> >> On 1. Mar 2021, at 22:48, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> >> Hello all,
> >> In RTEMS 6, there will be no cpukit/libnetworking in the RTEMS
> repository and it will be moved to its own separate repository. There are
> ongoing efforts in this direction and it is very close to completion.
> What's remaining, is to collect feedback from the users of the
> libnetworking stack.
> >> I request you to test the new standalone legacy networking repository
> with your regular targets and let me know if I have broken something in
> RTEMS or in the new repository. The legacy repo, in its current state, has
> been tested with pc-qemu and it can successfully run the legacy networking
> tests.
> >> The following are the links to the repositories with the latest version
> of changes:
> >> RTEMS: https://git.rtems.org/vijay/rtems.git/log/?h=devel-no-libnet
> >> Legacy Network:
> https://git.rtems.org/vijay/rtems-net-legacy.git/log/?h=main
> >> The following BSP family in RTEMS has been used with the old legacy
> networking stack:
> >> Zynq, PC, Motorola Shared, Beatnik, mvme3100, mvme5500, gen68360,
> uc5282, mvme 162/167
> >> If anyone is maintaining/working with one (or more) of these BSPs,
> please let me know if you're able to test the separate legacy-net
> repository and if you have any feedback. If you're planning to test it,
> please add your comments here so that we know someone is going to do it and
> wait for your feedback. The changes will not be pushed right away and we'll
> wait for some feedback.
> >> What's next?
> >> The legacy networking repository will stay at git.rtems.org for any
> projects that are still using it. It is recommended that the new projects
> use the libbsd networking stack which is more full-featured.
> >> Thank you for your patient reading. Any suggestion is welcome and I'm
> more than happy to work with you to get it more thoroughly tested before
> getting it merged.
> >> Best regards,
> >> Vijay
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210303/9bd36e6d/attachment-0001.html>
