[PATCH rtems 5 v2] powerpc/beatnik/net: Remove unused files
Vijay Kumar Banerjee vijay at rtems.org
Wed Mar 3 22:34:08 UTC 2021
Close #4293
 .../beatnik/net/if_mve/mve_smallbuf_tst.c     | 145 --------
 bsps/powerpc/beatnik/net/if_mve/testing.c     | 324 ------------------
 .../beatnik/net/porting/if_xxx.modini.c       |  34 --
 3 files changed, 503 deletions(-)
 delete mode 100644 bsps/powerpc/beatnik/net/if_mve/mve_smallbuf_tst.c
 delete mode 100644 bsps/powerpc/beatnik/net/if_mve/testing.c
 delete mode 100644 bsps/powerpc/beatnik/net/porting/if_xxx.modini.c
diff --git a/bsps/powerpc/beatnik/net/if_mve/mve_smallbuf_tst.c b/bsps/powerpc/beatnik/net/if_mve/mve_smallbuf_tst.c
deleted file mode 100644
index 721ade30d1..0000000000
--- a/bsps/powerpc/beatnik/net/if_mve/mve_smallbuf_tst.c
+++ /dev/null
@@ -1,145 +0,0 @@
-#include <rtems.h>
-#include <bsp.h>
-#include <bsp/if_mve_pub.h>
-#include <stdlib.h>
-#include <stdio.h>
-/* Demo for the mv64360 ethernet quirk:
- * $$ buffer segments < 8 bytes must be aligned $$
- * $$ to 8 bytes but larger segments are not    $$
- * $$ sensitive to alignment.                   $$
- * How to use:
- *   Init MVE driver on (unused) unit 2:
- *    mve = mvtst_init(2)
- *    data = { 1,2,3,4,5,6,7,8,9,0xa,0xb, ... }
- *   Alloc 2-element mbuf chain (1st holds an
- *   ethernet header which is > 8bytes so we can't
- *   test this with only 1 mbuf. The 2nd mbuf holds
- *   a small fragment of data).
- *     mb  = mvtst_getbuf(mve)
- *   Copy data into aligned area inside 2nd mbuf,
- *   (so that you can see if the chip starts using
- *   the aligned area rather than the unaligned
- *   buffer pointer). Point mbuf's data pointer
- *   at 'off'set from the aligned area:
- *     mvtst_putbuf(mb, data, len, offset)
- *   Send chain off:
- *    BSP_mve_send_buf(mve, mb, 0, 0)
- *   Watch raw data:
- *    tcpdump -XX -vv -s0 ether host <my-ether-addr>
- *   E.g, if offset = 1, len = 2 then we would like
- *   to see
- *   GOOD:
- *           < 14 header bytes > 0x02, 0x03
- *   but if the chip starts DMA at aligned address
- *   we see instead
- *   BAD:
- *           < 14 header bytes > 0x01, 0x02
-static inline void *rmalloc(size_t l) { return malloc(l); }
-static inline void  rfree(void *p) { return free(p); }
-#define _KERNEL
-#include <sys/param.h>
-#include <sys/mbuf.h>
-static void
-cleanup_buf(void *u_b, void *closure, int error)
-rtems_bsdnet_semaphore_obtain();
-	m_freem((struct mbuf*)u_b);
-rtems_bsdnet_semaphore_release();
-struct mbuf *mvtst_getbuf(struct mveth_private *mp)
-struct mbuf *m,*n;
-	if ( !mp ) {
-		printf("need driver ptr arg\n");
-		return 0;
-	MGETHDR(m, M_DONTWAIT, MT_DATA);
-	MGET(n, M_DONTWAIT, MT_DATA);
-	m->m_next = n;
-	/* Ethernet header */
-	memset( mtod(m, unsigned char*), 0xff, 6);
-	BSP_mve_read_eaddr(mp, mtod(m, unsigned char*) + 6);
-	/* Arbitrary; setting to IP but we don't bother
-	 * to setup a real IP header. We just watch the
-	 * raw packet contents...
-	mtod(m, unsigned char*)[12] = 0x08;
-	mtod(m, unsigned char*)[13] = 0x00;
-	m->m_pkthdr.len = m->m_len = 14;
-	n->m_len = 0;
-	return m;
-int
-mvtst_putbuf(struct mbuf *m, void *data, int len, int off)
-int i;
-	if ( m ) {
-		m->m_pkthdr.len += len;
-	if ( ( m= m->m_next ) ) {
-		m->m_len = len;
-		memcpy(mtod(m, void*), data, 32);
-		m->m_data += off;
-		printf("m.dat: 0x%08x, m.data: 0x%08x\n", m->m_dat, m->m_data);
-		for ( i=0; i< 16; i++ ) {
-			printf(" %02x,",mtod(m, unsigned char*)[i]);
-		printf("\n");
-	return 0;
-static void *alloc_rxbuf(int *p_size, unsigned long *paddr)
-	return *(void**)paddr = rmalloc((*p_size = 1800));
-static void consume_buf(void *buf, void *closure, int len)
-	rfree(buf);
-void *
-mvtst_init(int unit)
-struct mveth_private *mp;
-	mp = BSP_mve_setup(
-		unit, 0,
-		cleanup_buf, 0,
-		alloc_rxbuf,
-		consume_buf, 0,
-		10, 10,
-		0);
-	if ( mp )
-		BSP_mve_init_hw(mp, 0, 0);
-	return mp;
diff --git a/bsps/powerpc/beatnik/net/if_mve/testing.c b/bsps/powerpc/beatnik/net/if_mve/testing.c
index a1233bdb0b..0000000000
--- a/bsps/powerpc/beatnik/net/if_mve/testing.c
+++ /dev/null
@@ -1,324 +0,0 @@
-#ifndef KERNEL
-#define KERNEL
-#endif
-#include <rtems.h>
-#include <rtems/rtems_bsdnet_internal.h>
-#include <bsp.h>
-#include "mv64340_eth_ll.h"
-#include <string.h>
-#include <assert.h>
-#include <netinet/in.h>
-#include <stdio.h>
-#define RX_SPACING 1
-#define TX_SPACING 1
-#define RX_RING_SIZE (MV64340_RX_QUEUE_SIZE*RX_SPACING)
-#define TX_RING_SIZE (MV64340_TX_QUEUE_SIZE*TX_SPACING)
-struct eth_rx_desc rx_ring[RX_RING_SIZE] __attribute__((aligned(32)));
-struct eth_rx_desc rx_ring[RX_RING_SIZE] = {{0},};
-struct eth_tx_desc tx_ring[TX_RING_SIZE] __attribute__((aligned(32)));
-struct eth_tx_desc tx_ring[TX_RING_SIZE] = {{0},};
-/* packet buffers */
-char rx_buf[MV64340_RX_QUEUE_SIZE][2048] __attribute__((aligned(8)));
-char rx_buf[MV64340_RX_QUEUE_SIZE][2048];
-char tx_buf[MV64340_RX_QUEUE_SIZE][2048] __attribute__((aligned(8)));
-char tx_buf[MV64340_RX_QUEUE_SIZE][2048];
-char BcHeader[22] = {
-	0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* dst */
-	0x00, 0x01, 0xaf, 0x13, 0xb5, 0x3e, /* src */
-	00, 00, /* len */
-	0xAA,	/* dsap */
-	0xAA,	/* ssap */
-	0x03,	/* ctrl */
-	0x08, 0x00, 0x56,	/* snap_org [stanford] */
-	0x80, 0x5b,			/* snap_type (stanford kernel) */
-struct mv64340_private mveth = {
-	port_num: 0,
-	port_mac_addr: {0x00,0x01,0xAF,0x13,0xB5,0x3C},
-	/* port_config .. tx_resource_err are set by port_init */
-	0
-struct pkt_info p0,p1;
-static inline void rx_stopq(int port)
-	MV_WRITE(MV64340_ETH_RECEIVE_QUEUE_COMMAND_REG(port), 0x0000ff00);
-static inline void tx_stopq(int port)
-	MV_WRITE(MV64340_ETH_TRANSMIT_QUEUE_COMMAND_REG(port), 0x0000ff00);
-#define MV64360_ENET2MEM_SNOOP_NONE 0x0000
-#define MV64360_ENET2MEM_SNOOP_WT	0x1000
-#define MV64360_ENET2MEM_SNOOP_WB	0x2000
-#if 0
-int
-mveth_init(struct mv64340_private *mp)
-int i;
-	mp->p_rx_desc_area = rx_ring;
-	mp->p_tx_desc_area = tx_ring;
-	rx_stopq(mp->port_num);
-	tx_stopq(mp->port_num);
-	/* MotLoad has cache snooping disabled on the ENET2MEM windows.
-	 * Some comments in (linux) indicate that there are errata
-	 * which cause problems which is a real bummer.
-	 * We try it anyways...
-	unsigned long disbl, bar;
-	disbl = MV_READ(MV64340_ETH_BASE_ADDR_ENABLE_REG);
-	/* disable all 6 windows */
-	MV_WRITE(MV64340_ETH_BASE_ADDR_ENABLE_REG, 0x3f);
-	/* set WB snooping */
-	for ( i=0; i<6*8; i+=8 ) {
-		if ( (bar = MV_READ(MV64340_ETH_BAR_0 + i)) && MV_READ(MV64340_ETH_SIZE_REG_0 + i) ) {
-			MV_WRITE(MV64340_ETH_BAR_0 + i, bar | MV64360_ENET2MEM_SNOOP_WB);
-			/* read back to flush fifo [linux comment] */
-			(void)MV_READ(MV64340_ETH_BAR_0 + i);
-	/* restore/re-enable */
-	MV_WRITE(MV64340_ETH_BASE_ADDR_ENABLE_REG, disbl);
-	eth_port_init(mp);
-	sleep(1);
-	mveth_init_tx_desc_ring(mp);
-	mveth_init_rx_desc_ring(mp);
-#if 0
-	for ( i = 0; i<MV64340_RX_QUEUE_SIZE; i++ ) {
-		p0.byte_cnt 	= sizeof(rx_buf[0]);
-		p0.buf_ptr  	= (dma_addr_t)rx_buf[i];
-		p0.return_info  = (void*)i;
-		/* other fields are not used by ll driver */
-		assert ( ETH_OK == eth_rx_return_buff(mp,&p0) );
-	memset(&p0, 0, sizeof(p0));
-#endif
-	return eth_port_start(mp);
-#endif
-void
-mveth_stop(struct mv64340_private *mp)
-extern void mveth_stop_hw();
-	rtems_bsdnet_semaphore_obtain();
-		mveth_stop_hw(mp);
-	rtems_bsdnet_semaphore_release();
-extern int mveth_send_mbuf();
-extern int mveth_swipe_tx();
-int
-mveth_tx(struct mv64340_private *mp, char *data, int len, int nbufs)
-int rval = -1,l;
-char        *p;
-struct mbuf *m;
-char 	*emsg = 0;
-	MGETHDR(m, M_WAIT, MT_DATA);
-	if ( !m ) {
-		emsg="Unable to allocate header\n";
-		goto bail;
-	MCLGET(m, M_WAIT);
-	if ( !(m->m_flags & M_EXT) ) {
-		m_freem(m);
-		emsg="Unable to allocate cluster\n";
-		goto bail;
-	p = mtod(m, char *);
-	l = 0;
-	switch (nbufs) {
-		case 3:
-		default:
-			emsg="nbufs arg must be 1..3\n";
-			goto bail;
-		case 1:
-			l += sizeof(BcHeader);
-			memcpy(p, &BcHeader, sizeof(BcHeader));
-			p += sizeof(BcHeader);
-		case 2:
-			memcpy(p,data,len);
-			l += len;
-			m->m_len = m->m_pkthdr.len = l;
-			if ( 2 == nbufs ) {
-    			M_PREPEND(m, sizeof (BcHeader), M_WAIT);
-				if (!m) {
-					emsg = "Unable to prepend\n";
-					goto bail;
-				p = mtod(m, char*);
-				memcpy(p,&BcHeader,sizeof(BcHeader));
-		break;
-	*(short*)(mtod(m, char*) + 12) = htons(l-14);
-	rval = mveth_send_mbuf(mp,m);
-bail:
-	if (emsg)
-		printf(emsg);
-#if 0
-     * Add local net header.  If no space in first mbuf,
-     * allocate another.
-    M_PREPEND(m, sizeof (struct ether_header), M_DONTWAIT);
-    if (m == 0)
-        senderr(ENOBUFS);
-    eh = mtod(m, struct ether_header *);
-    (void)memcpy(&eh->ether_type, &type,
-        sizeof(eh->ether_type));
-    (void)memcpy(eh->ether_dhost, edst, sizeof (edst));
-    (void)memcpy(eh->ether_shost, ac->ac_enaddr,
-        sizeof(eh->ether_shost));
-#endif
-	return rval;
-int
-mveth_protected(int (*p)(struct mv64340_private*), struct mv64340_private *mp)
-int rval;
-		rval = p(mp);
-	return rval;
-int
-mveth_rx(struct mv64340_private *mp)
-extern int mveth_swipe_rx();
-	return mveth_protected(mveth_swipe_rx,mp);
-int
-mveth_reclaim(struct mv64340_private *mp)
-	return mveth_protected(mveth_swipe_tx,mp);
-int preth(FILE *f, char *p)
-int i;
-	for (i=0; i<4; i++)
-		fprintf(f,"%02X:",p[i]);
-	fprintf(f,"%02X",p[i]);
-	return 6;
-char *errcode2str(st)
-char *rval;
-	switch(st) {
-		case ETH_OK:
-			rval = "OK";
-		break;
-		case ETH_ERROR:
-			rval = "Fundamental error.";
-		break;
-		case ETH_RETRY:
-			rval = "Could not process request. Try later.";
-		break;
-		case ETH_END_OF_JOB:
-			rval = "Ring has nothing to process.";
-		break;
-		case ETH_QUEUE_FULL:
-			rval = "Ring resource error.";
-		break;
-		case ETH_QUEUE_LAST_RESOURCE:
-			rval = "Ring resources about to exhaust.";
-		break;
-		default:
-			rval = "UNKNOWN"; break;
-	return rval;
-#if 0
-int
-int st;
-struct pkt_info p;
-	if ( ETH_OK != (st=eth_port_receive(mp, &p)) ) {
-		fprintf(stderr,"receive: %s\n", errcode2str(st));
-		return -1;
-	printf("%i bytes received from ", p.byte_cnt);
-	preth(stdout,(char*)p.buf_ptr+6);
-	printf(" (desc. stat: 0x%08x)\n", p.cmd_sts);
-	p.byte_cnt = sizeof(rx_buf[0]);
-	p.buf_ptr -= RX_BUF_OFFSET;
-	if ( ETH_OK != (st=eth_rx_return_buff(mp,&p) ) ) {
-		fprintf(stderr,"returning buffer: %s\n", errcode2str(st));
-		return -1;
-	return 0;
-#endif
-int
-dring()
-int i;
-if (1) {
-struct eth_rx_desc *pr;
-printf("RX:\n");
-	for (i=0, pr=rx_ring; i<RX_RING_SIZE; i+=RX_SPACING, pr+=RX_SPACING) {
-		dcbi(pr);
-		printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
-			pr->byte_cnt, pr->buf_size, pr->cmd_sts, pr->next_desc_ptr, pr->buf_ptr);
-if (1) {
-struct eth_tx_desc *pt;
-printf("TX:\n");
-	for (i=0, pt=tx_ring; i<TX_RING_SIZE; i+=TX_SPACING, pt+=TX_SPACING) {
-		dcbi(pt);
-		printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
-			pt->byte_cnt, pt->cmd_sts, pt->next_desc_ptr, pt->buf_ptr);
-	return 0;
diff --git a/bsps/powerpc/beatnik/net/porting/if_xxx.modini.c b/bsps/powerpc/beatnik/net/porting/if_xxx.modini.c
index 1abad7dc22..0000000000
--- a/bsps/powerpc/beatnik/net/porting/if_xxx.modini.c
+++ /dev/null
@@ -1,34 +0,0 @@
-#include <rtems.h>
-#include <porting/rtemscompat.h>
-/* CEXP module initialization/finalization */
-/* Copyright: Till Straumann <strauman at slac.stanford.edu>, 2005;
- * License:   see LICENSE file.
-void
-_cexpModuleInitialize(void *unused)
-extern void NET_EMBEMB(rtems_,NETDRIVER_PREFIX,_bringup)(char *);
-	METHODSPTR = &METHODS;
-#ifdef DEBUG
-	NET_EMBEMB(rtems_,NETDRIVER_PREFIX,_bringup)("192.168.2.13/255.255.255.0");
-#endif
-int
-_cexpModuleFinalize(void *unused)
-#ifdef DEBUG
-extern int NET_EMBEMB(rtems_,NETDRIVER_PREFIX,_bringdown)();
-	if (NET_EMBEMB(rtems_,NETDRIVER_PREFIX,_bringdown)())
-		return -1;
-	METHODSPTR = 0;
-	return 0;
-#else
-	return -1;
-#endif
2.26.2
