[PATCH v2] tests/validation: Fix 64bit test failure
Thu Mar 4 13:54:57 UTC 2021
On 04/03/2021 14:50, Joel Sherrill wrote:
>     I will fix the error condition in the specification and adjust the
>     implementation accordingly without changing the API.
> Can the calculation of allocated size be done in terms of uint64_t and
> then we can easily check if the allocation is to exceed UINT32_MAX.
> Then there are no changes to the API and the code doing this should
> be a lot simpler and less prone to error.
This turned out to be a simple shortcoming of the validation test. This
error case can happen also on 64-bit targets. There was no
specification, API, and implementation change necessary, just a fix in
the test code:
https://git.rtems.org/rtems/commit/?id=8fe59be236e7f2047adb6e393639bbf56bbd996d
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
