[PATCH 04/12] gr_rasta_spw_router.c: Fix Unchecked return value from library (CID #1399760)
Ryan Long thisisryanlong at gmail.com
Thu Mar 4 14:05:05 UTC 2021
CID 1399760: Unchecked return value from library in gr_rasta_spw_router_init1().
Closes #4283
 bsps/shared/grlib/pci/gr_rasta_spw_router.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/bsps/shared/grlib/pci/gr_rasta_spw_router.c b/bsps/shared/grlib/pci/gr_rasta_spw_router.c
index 6efbaa4..33168cf 100644
--- a/bsps/shared/grlib/pci/gr_rasta_spw_router.c
+++ b/bsps/shared/grlib/pci/gr_rasta_spw_router.c
@@ -394,6 +394,7 @@ int gr_rasta_spw_router_init1(struct drvmgr_dev *dev)
 	uint32_t bar0, bar0_size;
 	union drvmgr_key_value *value;
 	int resources_cnt;
+	int sc;
 	priv = dev->priv;
 	if (!priv)
@@ -410,7 +411,8 @@ int gr_rasta_spw_router_init1(struct drvmgr_dev *dev)
 	strcpy(priv->prefix, "/dev/spwrouter0");
 	priv->prefix[14] += dev->minor_drv;
-	mkdir(priv->prefix, S_IRWXU | S_IRWXG | S_IRWXO);
+	sc = mkdir(priv->prefix, S_IRWXU | S_IRWXG | S_IRWXO);
+	_Assert_Unused_variable_equals(sc, 0);
 	priv->prefix[15] = '/';
 	priv->prefix[16] = '\0';
1.8.3.1
