[PATCH] tester: Update for ZynqMP QEMU BSP name change
Kinsey Moore kinsey.moore at oarcorp.com
Thu Mar 4 17:03:15 UTC 2021
The ZynqMP QEMU BSPs were renamed to include _qemu for more consistent
identification. This updates the tester configurations to match.
 ...{xilinx_zynqmp_lp64.ini => xilinx_zynqmp_ilp32_qemu.ini} | 6 +++---
 ...{xilinx_zynqmp_ilp32.ini => xilinx_zynqmp_lp64_qemu.ini} | 6 +++---
 2 files changed, 6 insertions(+), 6 deletions(-)
 rename tester/rtems/testing/bsps/{xilinx_zynqmp_lp64.ini => xilinx_zynqmp_ilp32_qemu.ini} (92%)
 rename tester/rtems/testing/bsps/{xilinx_zynqmp_ilp32.ini => xilinx_zynqmp_lp64_qemu.ini} (92%)
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_qemu.ini
similarity index 92%
rename from tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
rename to tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_qemu.ini
index cd2d268..772709b 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32_qemu.ini
@@ -29,10 +29,10 @@
-# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) LP64 BSP.
+# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) ILP32 QEMU BSP.
-[xilinx_zynqmp_lp64]
-bsp           = xilinx_zynqmp_lp64
+[xilinx_zynqmp_ilp32_qemu]
+bsp           = xilinx_zynqmp_ilp32_qemu
 arch          = aarch64
 tester        = %{_rtscripts}/qemu.cfg
 bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine xlnx-zcu102 -m 4096
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_qemu.ini
rename from tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
rename to tester/rtems/testing/bsps/xilinx_zynqmp_lp64_qemu.ini
index 35869ed..80db9c5 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_qemu.ini
@@ -29,10 +29,10 @@
-# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) ILP32 BSP.
+# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) LP64 QEMU BSP.
-[xilinx_zynqmp_ilp32]
-bsp           = xilinx_zynqmp_ilp32
+[xilinx_zynqmp_lp64_qemu]
+bsp           = xilinx_zynqmp_lp64_qemu
 arch          = aarch64
2.20.1
